IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 3 of 65
Posted Aug 06, 2009 · 03:39 UTC#51
Thanks "ill.die.trying" ,
i just recently added the 3.0 FW and now this ....
Really thanks for all the hard work you guys have put in to making our systems work the way the should of been since the first day i purchased the deck. i had Modded my DATA before but just screwed everything up , i don't have an complains and its the best look so far not to say the easier it is to navigate with it . THANKS AGAIN
Posted Aug 06, 2009 · 03:58 UTC#52
no prob
Posted Aug 06, 2009 · 04:32 UTC#53
Hey IDT, I want the defaul tilt to show a little less sky, which one of the variables do I adjust?
3d_max_tiltlevel=10000
3d_max_zoomlevel=1500
I'd like to zoom in a bit more and adjust so I see about half as much sky, then make the arrow larger.
To do this, should I adjust the zoom level to 1200, then the tilt level to about 8000?
Then I'll make the 3dcarsizemin=3500 to increase the size of the arrow?
Thanks in advance!
Posted Aug 07, 2009 · 01:17 UTC#54
i get no blue arrow? tried other schemes but i get errors?
Posted Aug 07, 2009 · 01:49 UTC#55
Keep getting prompted to input a password on the FTP link, any suggestions?
Posted Aug 07, 2009 · 01:59 UTC#56
was the software bypass implemented on the data.zip file? It does not seem so as I get the error message telling me to check my wiring. Other than that it all seems to work well.
Posted Aug 07, 2009 · 02:40 UTC#57
sorry i forgot to add that part, v2 will be up soon, if you're comfortable with changing it please do so
Posted Aug 07, 2009 · 02:42 UTC#58
wht do the screnn shots show blue arrow but still get red after install?
Posted Aug 07, 2009 · 02:49 UTC#59
it's because of the scheme i'm using, go to the ftp site and on the main level you'll find schemes that you can download
Posted Aug 07, 2009 · 02:49 UTC#60
Hey IDT do you know if it is possible to put a shortcut for contacts on the nav screen?
Posted Aug 07, 2009 · 02:50 UTC#61
it's possible but no one has hacked the part of the unit that handles that,
Posted Aug 07, 2009 · 02:58 UTC#62
What exactly am i looking for?
Posted Aug 07, 2009 · 03:31 UTC#63
Not a problem. I thought I would put that out there incant someone else was having problems.
Posted Aug 07, 2009 · 03:45 UTC#64
IDT, Just loaded it with a fresh reload of my unit again. Works good. All we need now is a favorites shortcut. Thanks for your time.
Posted Aug 07, 2009 · 04:23 UTC#65
i'll make a shortcut menu option in the nav setting so that you can select what you see on the nav screen, it might not be on the second release but for sure i'll add that some time next week,
Posted Aug 07, 2009 · 11:08 UTC#66
Is this Modding only for IGO 8.3 or can be used with 8.0?
info: my USA unit is uptodate but APL2 is with hacked ezrider+Europe maps
does it have the hacked 3.0 update?
It runs with 3.01... But APL2 folder is from fw 2.xxx with IGO 8.0
Posted Aug 07, 2009 · 13:19 UTC#67
Why is it the brake setting is set to 16, instead of the 256 requested by many.
For some reason, every time I make a change, my system does notting but reboot, so I must leave the data.zip file as I get it.
Posted Aug 07, 2009 · 13:23 UTC#68
Hey IDT love the mod and thank you for the work you do. I used the fly over and now my 2d/3d button is gone. I tried to recopy the data file and it is still not showing up any ideas?
Posted Aug 07, 2009 · 13:25 UTC#69
leave it alone for now, i'll have an update later in the afternoon with the software bypass
Posted Aug 07, 2009 · 14:44 UTC#70
IDT,
I installed the mod as instructed but when i turn on the speedcam in the Warning Option, i do not see the speedcam icons on the map nor a voice warning (which is also turned on in the options). Are we missing any of the speedcam files?
Posted Aug 07, 2009 · 14:47 UTC#71
IDT,
do you have a speedcam text file? if not then you have to add that to myflashdisk/apl2/igo/content/speedcam
Posted Aug 07, 2009 · 15:06 UTC#72
IDT,
That's prob the problem, i'll just have to load the speedcam.spud file from CMH's mod. Thanks for the reminder.
Posted Aug 07, 2009 · 15:11 UTC#73
IDT,
no prob, also, it may take a while to boot after you put the speedcam file as the unit converts the file to spud
Posted Aug 07, 2009 · 15:14 UTC#74
Just an FYI, I deleted the entire "Speedcams" folder in "My Flash Disk\APL2\iGo\CONTENT..." and replaced it with the files and the .spud files from my last saved V2.0 setup and now everything seems to be well. No more re-boots :P
I changed the slider bar increments in the "speedcam_800_480.ui" file from this:
To this:
I also had to uncomment this line of text in the "Speedcam.ui" file:
SETFORMATTED_UNIT_TEXT txtSC_SpeedUnit "km/h"
Now it displays the correct units and the speed selected jives with the correct spoken alert.
But still, the smaller "SpeedUnitMI" value , that is the 20 Font, directly below the larger text that is displayed for the appropriate speed now does not jive as they are now both displaying "MPH" units so I am trying to remove it from the slider bar display entirely. I have commented it out in a few places but it just hangs the system up so I will keep working. It is just one of those annoyances I want to delete. All in all very good! Any suggestions?
Thanx for the hard work, bro.,
Bud
Posted Aug 07, 2009 · 15:24 UTC#75
To this:
Bud
i'll try to have a fix for this, some like hiding the kmh and showing MPH/MPY depending on the unit setting,
glad you had fixed the reboot problem
Page 3 of 65
