Great!
How about on the next go-round you can get the speedcams to be selectable in just MPH and not the KPH/MPH Big and small fonts when you go to add a cam?
Thanx again, IDT..keep up the great work!
Bud
Great!
Bud
Great!How about on the next go-round you can get the speedcams to be selectable in just MPH and not the KPH/MPH Big and small fonts when you go to add a cam?
Bud
i'll take another look at it
IDT,First thanks for all the hard work. Your mods are great. I don't know if this is useful info on the TC problems everyone is having but, I have noticed that as long as I shut down my unit (F900) with the nav displayed the TC will work. If I shut it down with anything else on the display (XM, IPod, radio). The TC will not work.
not sure if that will help but they'll lose nothing by trying it
Love your mods IDT! However, curiosity got the best of me and I installed the Gurjon skin. It was WAY too complicated for me (good mod but too many options to choose from). Anyways, I have gone back to using yours but I can't seem to get your red car back in 3d mode. I have the blue arrow. What do I need to change to get the car image back? I thought I replaced all the files that the other skin had, but apparently not. Thanks for anyone's help. Again, your mod is the greatest!!
the car images are still there and you just have to rename them to daycar.bmp and nightcar.bmp in the common folder,
Hi, I use the mod recently IDT3.5euro. Your work is really great.I noticed 2 problems:
- Can not select the speed for the addition of a MobileCam.
i will take a look at it again, ever since my mod for 2.0 i haven't been able to set any speed for it
- Adjustment "Audible Warning" does not remain in memory.
What are the lines of script to be added to correct this (I did not find myself).
Is it possible to add a "test" mode for spokenAlerte
thank's
speedcam.ui for Audible Warning :
BTW...you've got Paypal cash, bro! ![]()
thanks for the donation bro
..in the meantime, I do this to the files:
In the speedcam_800_480.ui------
; ***MPH Units_BW***
And in the common/speedcam.ui, I uncomment this:-----
SETFORMATTED_UNIT_TEXT txtSC_SpeedUnit "km/h"
I can at least set the cams to the correct US increments.
You are very welcome for the donation. I much rather give it to you because YOU have done so much more forALL OF US!!
Hey IDT,
you are faster programming than we can test ![]()
Some feedback on the 3.03.5 EU version anyhow:
1) I think I found the reason for the reboot at a certain location: It must have to do with the format setting for the coordinates in local settings. I choose a different one and no reboots anymore.
2) The problem with the 3D view sometimes not beeing direction up you can forget about this. When you press a softbutton in 3d it sometimes also sets the cursor, causing the Map to act weird when you go back to the map screen. Pressing the Map button solves this.
3) Thanks to give us the Arrow back, in my opinion much more precise than the car.
4) Thanks for the TMC button, very much appreciated
5) To be really honest, I like the colours and font size from the stock for the Navi direction, the 2 cofigurable fields and the 2 bottom lines much better, as I'm getting old they are much better to read then yours.
6) When in the route window, there are 2 simulation buttons at the bottom, but no show rout anymore
7) Speedcam warning not always correct.
Don't take these pionts as an offence, I could never do something like this, but do think it may save you some testing if i let you know.
good night
Jörg
Hello,
I'm your man, I will try this at same spot than the 1st pic tomorrow (actually, it's 1 a.m. in Belgium so please allow 8 hours for feedback, as now I'm going to sleep...)
Franck
Hey IDT,
Jörg
i definitely have to try this one out
no prob
i'll figure out a way to be able to set different colors as per users preference
cou you post pics of this happening
could you clarify what and when this is happening
like i've said before, it's you guys using the mod makes me fix bugs/implement request faster, i don't have a whole lot of time on my hands so without you guys i'm pretty much nothing, thanks a lot
Hello,
Franck
thanks
I've had issues with 3.5 and 4.0
Both have to do with the schemes. My AVIC crashes when going from day to night or night to day, or when changing from one color scheme to the next. It just reboots. i'm going to try the 2 lines of code in the ui file of each scheme and see if that fixes it. Any other thoughts in case it does not?
Things were working fine in 3.2, and I delete the whole save data folder (only 2 stored favorites) before each install.
I've had issues with 3.5 and 4.0Both have to do with the schemes. My AVIC crashes when going from day to night or night to day, or when changing from one color scheme to the next. It just reboots. i'm going to try the 2 lines of code in the ui file of each scheme and see if that fixes it. Any other thoughts in case it does not?
are you using the schemes attached to the download? i'm just trying to narrow it down to what might be causing it
Copying the whole download to the SD (including the schemes) and installing after deleting the saved folder contents.
I've had issues with 3.5 and 4.0Both have to do with the schemes. My AVIC crashes when going from day to night or night to day' date=' or when changing from one color scheme to the next. It just reboots. i'm going to try the 2 lines of code in the ui file of each scheme and see if that fixes it. Any other thoughts in case it does not?
Things were working fine in 3.2, and I delete the whole save data folder (only 2 stored favorites) before each install.[/quote']
what two lines are you planning on fixing?
anyone else having the same problem?
how can I fix this problem?
thank's
in advance, thank's ![]()
In version 4, is it possible to have the speed and elevation at all times (no mod browsing and navigation).
The new radar warning no longer displays the distance to radar? is it possible to add this to the final version?
1) i will have to take a look at it first, there are two line in the speedcam.ui under st_speedcam
runif vTmp 1 'txtSC_SpeedValueMI.HIDE, txtSC_SpeedUnitMI.HIDE, txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE, txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE' runif vTmp 4 'txtSC_SpeedValueMI.HIDE, txtSC_SpeedUnitMI.HIDE, txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE, txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE'
commenting them out will show the options for speed setting on mobile camera but the problem there is even if you have the speed setting for it it would not show the proper display on the speedcam warning box and it would not say the spoken alert
2) haven't looked at it yet
The last mod CMH928 (for version 2xxx), alerts and radar settings worked really well. Maybe that can help? ![]()
the last mod CMH928 (for version 2xxx), alerts and radar régalges worked really well. Peut_être that can help?
i'll check it out
in cmh mod, speedcam.ui
Hey IDT,
I really can't tell with the emulator, but does the current speed sign stay visible without being enroute to a specific location. Meaning can I just travel around and notice the current speed at a glance. Thx, also loving the mod so far. ![]()
Hey IDT,I really can't tell with the emulator, but does the current speed sign stay visible without being enroute to a specific location. Meaning can I just travel around and notice the current speed at a glance. Thx, also loving the mod so far.
it's not visible with a route,if you're just navigating it should show up, the reason why it's not showing up on the emulator is because we don't have a gps signal while using it
everything is going A O K.... no problem like always .
the only thing is when i come up to known speedcams nothing comes up on the screen. i guess they're just not on the maps.
are the settings turned on?
