Hi!
I just installed the mod and when i press on the map button (In the screen) , the unit just reboot in loop....I have to turn the ignition off and then on to be able to use the radio (Without GPS)
Any ideas?
Thank you for you good work
Martin
did you install everything (including the font file) ?
what unit do you have?
I took the file in your FTP server (The last one) and i also replaced the DATA file for the "final release"
I followed the instructions carefully ... I probably made a mistake somewhere
I have a F7010BT
Thank you again
Martin
Restore your backup and start over.
Make sure you took this file:
ftp://avic:[email protected] ... vFINAL.zip
If you took the TMN or MSN files, your unit could have some trouble. Then, open the file and extact it to your unit via testmode. Then, come back with the new data.zip located here:
ftp://avic:[email protected] ... h/DATA.zip
(Assuming you're usiong MPH, not KPH)
Copy that file on top of the data.zip in apl2/igo
