IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 55 of 65
Posted Oct 13, 2009 · 03:53 UTC#1351
Hi IDT are you planing to add more scheme and also how can i change the sky picture .Thanks
Posted Oct 13, 2009 · 18:08 UTC#1352
Hey. Not sure if this was already asked. The elevation shows .2 on my unit any time I got over 1000 feet.
Posted Oct 13, 2009 · 18:18 UTC#1353
we'll see
Posted Oct 13, 2009 · 20:58 UTC#1354
Great mod, thank you for all your work!
I have a couple of questions:
- is there any way to set the speed limit sign to European style (white circle with red border)?
- after the unit boots, the map starts always in 2D mode, even if it was in 3D when it was turned off. It used to remember the last setting before using this mod. Is there any way in having the map remember its last setting, or to start in 3D mode?
Thank you again for the hard work!
Posted Oct 13, 2009 · 21:24 UTC#1355
what unit do you have and where are you located?
Posted Oct 13, 2009 · 21:32 UTC#1356
Sorry, I have an F900 and I live in Europe - that's why I'm interested in having European style speed sign. My unit is an US one though - I've been able to load all European maps on it and iGo 8.3.
Posted Oct 13, 2009 · 22:21 UTC#1357
are you using the TMC version?
Posted Oct 14, 2009 · 04:01 UTC#1358
No, I'm using the simple one, since the US unit doesn't have TMC.
Posted Oct 14, 2009 · 04:15 UTC#1359
Yes, but I enabled all of the TMC stuff on my US version and my MSN traffic works just fine!
I just replaced the TMC icon with the one that was for the screen off (same location) and enabled the alpha dimming so it works in conjunction with the rest and all is well!
Posted Oct 15, 2009 · 04:00 UTC#1360
Hi, sorry for the question...i live in Argentina, here our stock cars have units with RDS and TMC. I have an US f900bt unit, with IDT's perfect mod, but...can we make this work in our units? RDS mainly??
Posted Oct 15, 2009 · 04:03 UTC#1361
Another thing, IDT...how can I make the unit completely off the screen (as when we do it from the menu CONFIGURATION -> SISTEM SETUP) when i press the screen off button of your navigation mod (which shows the time)???
is this possible??
thanx a lot!!
Posted Oct 15, 2009 · 04:26 UTC#1362
is this possible??
thanx a lot!!
for both your questions it's possible but you have to hack the system.exe to make it work, i have no clue on how to do it though
Posted Oct 15, 2009 · 10:59 UTC#1363
Any help with this?
Posted Oct 15, 2009 · 12:44 UTC#1364
Hey, IDT, is there any way to change the color of the car (arrow) from light blue to red? I have been looking, but cannot find it.
Posted Oct 15, 2009 · 15:02 UTC#1365
have you tried doing what 69sixpack suggested?
Posted Oct 15, 2009 · 18:15 UTC#1366
Hi -> just thinking
RDS is from the European Broadcast Union, in the US the Radio Broadcast Data System (RBDS) is used. Actually RBDS works for AM and FM, in Europe (RDS) it only works for FM. To make a long story short: Different protocoll. But I think, the hardware is identical, because befor you can use Radio in Europe, you have to adjust the kilohertz-stepping to 50 (100 is default - the US-Settting!)
So you should Download the European version of the firmware and RDS should work. Since both, the US and the European defelopers tryied hard to be compatible to each other.
It is not a matter of the skin. But the European TMC get's stuck, when reaching the traffic-information from MSN-button... Can be fixed, when setting ALL regional settings in the SYS.TXT to Europe (default location, units, multitimezone...). You could do that first and try. In general, the "1" represents US-settings and the "0" stands for Europe. the letters "tmc" mus not be followed by a "2" looking "tmc2".
Sorry for the short explanation, but I am currently typing on the iPhone.
Posted Oct 15, 2009 · 18:36 UTC#1367
i'll try...if anyone has an 3.01 flash for f900 let me know please
thanx
Posted Oct 15, 2009 · 18:43 UTC#1368
No, because I don't understand what TMC/MSN has to do with my two questions, about having speed limit sign changed to the European style (white circle, red border), and why my unit boots in 2D mode - how can I make it to go to 3D by default.
Posted Oct 15, 2009 · 18:56 UTC#1369
thanx
Try this first:
...Can be fixed, when setting ALL regional settings in the SYS.TXT to Europe (default location, units, multitimezone...). You could do that first and try. In general, the "1" represents US-settings and the "0" stands for Europe. the letters "tmc" mus not be followed by a "2" looking "tmc2".
If this do's not work:
1. Do you have maps, hacked ezrider, licencefiles?
2. Do you know where to put all the stuff?
If "yes" for both questiones, I could send the rest to you, My licencefiles won't work on your unit and the maps are a bunch of load.
Posted Oct 15, 2009 · 19:08 UTC#1370
Try this first:
...Can be....
Yes, i have carefully studied...send it to me!
Posted Oct 15, 2009 · 20:29 UTC#1371
Try this first:
...Can be....
sent
Posted Oct 15, 2009 · 20:35 UTC#1372
here's the easiest way, go to your navigatemp_800_480.ui and look for this code
;UK
;US
as you can see the UK one is commented out, so all you have to do is to uncomment the UK one and comment out the US one,
one question though, have you tried using the TMC version? the zip has all files needed for EU users (sys.txt, the house number is also altered)
Posted Oct 15, 2009 · 20:51 UTC#1373
Hey IDT, I asked this a few posts back and nobody answered. Here is what I mean. I would like to cahnge the color of the car arrow to red instead of blue as the schemes that I use have major highways is the same color and the car arrow just gets washed out. How can I change the color to red? The daycar.bmp file is aready red, so I am kinda lost.
Posted Oct 15, 2009 · 20:53 UTC#1374
sorry i think i might have missed it, so this is for the 3D right? if so it would be the scheme that's responsible for its color,
Posted Oct 15, 2009 · 21:09 UTC#1375
I believe that you are right, but what is the color code for red? Here is what is in the color.ini. :
; System colors
hazecolor = 0, 0,0,0
zoomcolor1 = 0, 20,90,90
zoomcolor2 = 0, 30,130,130
zoomcolorfont = 0,190,190,190
carcolorint = 0,0,160,136
carcolorext = 0,0,200,170
carcolorghostint = 0, 150, 150, 150
carcolorghostext = 0, 50, 50, 50
Page 55 of 65
