IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 54 of 65
Posted Oct 11, 2009 · 14:36 UTC#1326
warning radar in Spanish?
are very large
buscar
i don't know what you mean?
I mean the voice that speaks, if I could speak Spanish
Posted Oct 11, 2009 · 15:51 UTC#1327
do you like me, you are properly registered voice in your language and you change the language files from the UK want.
Posted Oct 11, 2009 · 15:55 UTC#1328
as I do that???
Posted Oct 11, 2009 · 17:10 UTC#1329
thanks for the donation bro
Posted Oct 11, 2009 · 19:25 UTC#1330
No sabes :)
Posted Oct 11, 2009 · 20:57 UTC#1331
Hi IDT.
I just installed your latest mod, it's very good, one thing i have notuced though, i can't switch my unit off via the menu>source>off, i have to actually switch off the ignition.
One more question, if i try to find an address via a post code and that post code happens to be an unmarked road, the unit freezes up and i get a little grey widow pop up saying something about not having enough memory, and something about the cache too, i can use the hard menu button and select the source>radio or whatever and get to that, but i can't get back to the map. Any thoughts ?
Thanks, Paul.
Posted Oct 11, 2009 · 23:14 UTC#1332
Hi IDT.
Thanks, Paul.
i will try to find out regarding the running out of memory,
regarding the turning off, AFAIK the mod has nothing to do with it as that would be handled by av.exe and not igo, though i will try on mine and see if it acts the same way
Posted Oct 12, 2009 · 08:28 UTC#1333
bug report on version TMC.
i'm EU user
-In demo mode, the buttons do not appear unless the button "Stop"
-When I appear the second window info (long click on the hour)
. If I click on the button "return", a "day / night" mode is in "auto"
. If I click on the button "Map", a "day / night" becomes "day" forced (checked in options)
-When there is a radar warning (visual mode "Full" and audible "activated") and I am a "longclick" on the high alert window and I released, the small window appears altert visual and sound of alerts is not muted. By cons when looking at the radar via the option menu, it is clear that audibly alerts are disabled. Yet radar audible alarms continue to function. Then it is impossible to return to the great visual alert window by clicking on the small alert window, why we must cut the contact.
I can not find the alert mode reduces visual interesting. I find it better to have the possibility to mute the radar alerts by simply clicking on the alert window.
For the rest of this mode is really great, thank's IDT.
Posted Oct 12, 2009 · 11:12 UTC#1334
Hi IDT.
The switching off issue has gone away, it only happened after the first boot up after the new mod was installed, so i can now switch off via the menu.
The pop up window saying out of memory and the cache thing still comes up when i try and find or navigate to a postcode on an un-named road, this happens on both of my F910's, one has the final tmc mod, the other has the previous mod.
If someone out there (UK based) has an unmodded unit then perhaps they could try this postcode, GL19 3BE, please could you post what happens.
Thanks.
Paul.
Posted Oct 12, 2009 · 11:54 UTC#1335
Excellent work IDT. Thanks for everything. I have been wondering to myself how long you would keep at this...you kept it up longer than I would have. Salud!
Posted Oct 12, 2009 · 14:50 UTC#1336
EXCELLENT MOD!! The only thing that I changed to make it perfect for me, was to incorporate a few of DPHursts schemes, and I made the icons on top a little smaller as I have always found that they were a bit too big, that is just my opinion as I am sure that everyone else likes it the way it is. I really dont think that this MOD can be improved other than that. NICE WORK!!
Posted Oct 12, 2009 · 15:11 UTC#1337
could someone tell me how to make the voices of radars in Spanish????
thanks
Posted Oct 12, 2009 · 16:20 UTC#1338
thanks
The audio files are pre-recorded .ogg files. Someone would have to record their own and replace them or try searching for IGO sound bytes in Spanish.
Bud
Posted Oct 12, 2009 · 16:31 UTC#1339
Ok, when i first installed the final mod, tmc version, i had a female speed camera voice, and when i adjusted the volume slider for the female voice i'd get a sample of the volume, however, now i have the male voice again hen i go past a speed camera and when i adjust the volume slider for the speed camera i don't get any sample.
I'll end up selling my head unit at this rate.
Paul.
Posted Oct 12, 2009 · 17:22 UTC#1341
Hi IDT,
thanks a lot for your final version. You seem to be a perfectionist. 700 Km with no problems, everything workes fine.
Sent you some money.
so long
Jojool
Posted Oct 12, 2009 · 17:47 UTC#1343
The sound files are the same. Just replace the ones you have with the new ones. Make sure you rename them exactly as the old ones and it will work just fine. :)
Posted Oct 12, 2009 · 17:49 UTC#1344
mean the numbers 0,1,2 ...
if that changes now supuese
Posted Oct 12, 2009 · 20:46 UTC#1345
Hi IDT,
so long
Jojool
Posted Oct 12, 2009 · 22:01 UTC#1346
sweet update IDT thanks again.
Posted Oct 12, 2009 · 22:23 UTC#1347
no prob
Posted Oct 12, 2009 · 22:40 UTC#1348
Paul.
could you try adding this on the [debug] part of the sys.txt and see if it helps on the out of memory problem
cache=2048
Posted Oct 13, 2009 · 01:15 UTC#1349
One more question in regards to this mod. What is the purpose of being able to set the day and time from the red-negative button on the map screen? Has every day of the week, and the wrench for setting specific times. Is that to turn speedcams on/off based on the time or day or.....?
Sorry I just noticed this one today.
Posted Oct 13, 2009 · 02:02 UTC#1350
i think you're referring to the road blocking feature and not speedcam, that is to block a road depending on your preferences (construction, maybe no left turn on a specific time etc) so that when you have a route it would not use that road as a part of the route,
Page 54 of 65
