IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 53 of 65
Posted Oct 10, 2009 · 03:48 UTC#1301
Posted Oct 10, 2009 · 09:15 UTC#1302
Hi Julius,
Any time scale on release of FINAL update?Are you planning to add anything new?Any clues on what your new adventure will be.Whatever it is,best of luck and thanks for all your support with your amazing mod.
-navigation progress bar,
-for MSN and TMC users i was able to fit the favourites button on the shortcuts
-beep warning slider
-some other stuffs i can't remember
release date woiuld be tomorrow,
Thank you for that.Looking forward to tomorrow! :)
Posted Oct 10, 2009 · 13:31 UTC#1303
I've been reading the posts here with a lot of interest and looking at adding this mod to my unit, the only thing holding me back right now is that I don't have an overall feeling for everything that this mod does.
The downloads contain no extra info such as a readme or even a rudimentary overview that describes the changes that will take place after the mod is applied. And with over 80 pages of forum info, trying to extract that from individual posts is highly problematic.
Is there a summary or explanation of all the things in the mod that I missed somewhere?
Posted Oct 10, 2009 · 15:16 UTC#1304
i'll try to make one based on whatever i noted on the previous posts
Posted Oct 10, 2009 · 16:44 UTC#1305
Hey IDT,
Just wanted to report that I experienced the reboot problem again with your latest 4.9 version. I did have the speedcam option enabled with all the speedcam coordinates loaded. It was working fine in 3d mode, but when I switched to 2d and clicked on the area with the speedcam, the constant reboot problem appeared. I don't know if it's worth mentioning, but I also switched the speedcam alert from full to simple, then back to full prior to the reboots.
i just checked and i'm not having any problems with it, could you try reloading the mod,
anyone else having this problem?
Posted Oct 10, 2009 · 17:41 UTC#1306
Hey IDT,
I've reloaded it and it is working again. I'll try to find the exact steps to replicate the problem and report back to you. Hopefully, it is not just me that's having this problem.
Posted Oct 10, 2009 · 17:46 UTC#1307
Hey IDT,
please do,
Posted Oct 10, 2009 · 18:03 UTC#1308
IDT thank you for your great job :wink:
Posted Oct 10, 2009 · 18:06 UTC#1309
no prob, update will be up later,
Posted Oct 10, 2009 · 20:20 UTC#1310
FINAL UPDATE
-on/off setting for navigation progress bar
this would be the last version, i think that all i need is already here and i'm pretty happy where it's sitting right now,
as far as bugs, i will still update it if someone finds any, i have devoted so much time on this skin and i'm seriously happy with what i achieved, thanks to BORISM, N-S-E-W, andr2000, keeper22, all users that volunteered to test it,
i'm going to be working on another skin so expect a release soon,
there are 6 versions of this final mod, 2 for the regular users, 2 for MSN users and 2 for TMC users,
the reason i created two for each is because of the unit setting varying from different locations (setting a speed camera), so if the first one doesn't work for you then use the one with the alternate at the end of the filename
1) first off this is not an auto installer,
2)extract files and transfer all files to a freshly formatted SD card (for F500 users, you have to edit the device type part first to reflect the device type of the F500 before transfering it to the SD)
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
***if this is your first time,PLEASE BACK UP YOUR FILES
6) copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
7) to add a different scheme, add the contents of scheme folder to MYFLASHDISK\APL2\IGO\CONTENT\SCHEME
**IT'S MANDATORY TO DELETE THE SAVE FILES, it's in My Flash Disk\USER\UserData\iGo\save, everything should be deleted except for favourites.dat if you have it
8) once done copying turn off the unit, remove sd card and then turn unit on,
any comments, suggestions, requests are welcome, anyone who wants to be a tester for upcoming mods please send me a PM,i need more than one set of eyes to get this thing going
any donations thru paypal are very much appreciated [email protected]
DOWNLOAD LINK http://www.4shared.com/dir/21077539/1fe9d17d/sharing.html
Posted Oct 10, 2009 · 20:21 UTC#1311
CHANGE LOG
Aug 4/09 v1
-screen off
-quick day/night scheme button
-Address shortcut button
-poi shortcut button
-gps signal button
-navi setting button
-return home button
-route info button when with a route
-itenerary button when with a route
-navigation guidance mute button
-delete route button
-simulation controls
-speedcam
-speedcam voice
-speedcam mute/hide
-road sign setting (for turn restriction and speed limit sign)
-8.3 style direction icon
-changed route function lay out
-MSN button for MSN users
Aug 8/09 v2
-multi-route
-trip computer
-road blocking
-manage screen
-snap to road option
-building setting
-fading shortcuts
-plan mode screen
Aug 21/09 v3
-tripcomputer onscreen by pressing the current speed)
-multidraw on long click of multiplan button
-cosmetic fixes
-fixed return home bug
-fixed calling from poi screen
-removed gps button and replaced with favourites button
-fixed a whole other stuff that i can't remember
Aug 23/09 v3.1
-poi onmap onrelease will go to search by name and onlongclick will bring you to poi search screen
-included in the download is a bunch of schemes, i edited the scheme to have different colors for the multidraw screen including the edited stock pioneer schemes
-if you want different sky on your nav just replace sky.bmp on GFX/DAY and GFX/NIGHT on the data.zip
Aug 28/09 v3.5
----version made specially for EU users
-UK style speedlimit sign
-housenumbers were reversed for EU users
-TMC shortcut
-sys.txt already fixed to reflect the device type and TMC icons
----signpost on/off setting
----fixed scheme button
----history shortcut onlongclick of the address button
----added a ROAD SIGN settings page for speedlimit sign, sign post, turn restriction
----i don't know if you guys noticed that the software bypass was already included since v2 and i just kept forgetting to mention it,
----there's a couple other stuff that i can't remember
Sep 1/09 v4 BETA
-----return button on plan mode screen onlongclick will return to map screen
-----added elevation sign on map screen
-----on/off setting for elevation sign
-----added lane guidance option
-----on/off setting for lane guidance
-----reduced the size of the signpost
-----when signpost and speed camera are valid, speed camera warning box hides and a simple speed camera warning sign shows
-----more visible route information
Sep 10/09 v4.3
-added a custom audible alert (this is now where you select the spoken alert setting)
-added speedcam spoken alert volume slider
-added beep warning distance
-when adding a speedcamera instead of having the kph on top of the mph speed i just had it to display appropriate units depending on your regional unit
-fixed time and date color
-map color shortcut onlongclick of day/night scheme button
-moved lane guidance to the right
-added zoom control button on planmode screen
-fixed problem with the speedcamera warning box not showing up (from v4 BETA)
-schemes that are attached to the download were all edited to include clip_plane part
-added housenumber background for better visibility
-fixed roundabout number not being centered
-navigation cruise page when time/compass area is pressed (onrelease=simple and onlongclick=advanced) extracted from gj skin
October 1/09 v4.9
-fixed speedcamera reboot problem
-added an option on how you want the speed camera warning to display (Full or Simple)
-when the speedcamera warning box is pressed it reverts to the simple camera mode, onlongclick mutes all the speedcamera warnings and goes to simple mode
-spoken alert changed to female voice (the male alert files were the ones causing reboot)
-removed a couple speed camera settings that i found not usefull
-fixed audible warning not saving upon reboot
-added a custom setting button on the navi setting screen
-added an option for the fading buttons
-added a navigation text color setting (for the streetnames, next streetname, distance etc, also controls the time and date color)
-there's a couple more stuff that i did that i can't remember
-currently i haven't found a way for the elevation to display feet on all unit settings,
-still working on the signpost covering the speedcamera warning box
to change the 3D arrow to a car model download the 3DCars.rar file on the download link provided and extract it
and you have to edit the sys.txt
change the current values of this
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
to this
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
and add this part to the [3D] section
car_day=hot_rod_red.mdl
car_night=hot_rod_red.mdl
ghost_day=hot_rod_red.mdl
ghost_night=hot_rod_red.mdl
you now have to transfer the desired carmodel and tex file to the gfx folder in the data.zip and change the names of the above code to your selected car model name, i haven't tested every car model out as i already like the hot_rod car, but it's just a trial and error thing
October 10/09 FINAL
Posted Oct 10, 2009 · 20:38 UTC#1312
Many thanks Julius.you are right,what else could you add to improve this?nothing!Good luck in your new projects,as always i will look forward to seeing them on here when you're ready.Thanks again for some brilliant work.
Posted Oct 10, 2009 · 22:41 UTC#1313
what is the TMC mod?
Posted Oct 10, 2009 · 22:53 UTC#1314
Or should i say what does TMC stand for, thanks.
Posted Oct 10, 2009 · 22:57 UTC#1315
that's for EU users
Posted Oct 10, 2009 · 23:31 UTC#1316
Posted Oct 11, 2009 · 02:12 UTC#1317
Stupid question I guess....where do you see the navigation progress bar, and turn it on/off ?
Posted Oct 11, 2009 · 07:38 UTC#1318
just above the next street bar, setting is in map settings
Posted Oct 11, 2009 · 07:52 UTC#1319
hello IDT, which version is for the Euro user ?
thank's
Posted Oct 11, 2009 · 08:02 UTC#1320
thank's
the TMC one
Posted Oct 11, 2009 · 10:48 UTC#1321
In this version you can not disable the audible speed camera by simply clicking on the alert window visual ?
Posted Oct 11, 2009 · 13:18 UTC#1322
it should be a longclick
Posted Oct 11, 2009 · 13:53 UTC#1323
ok, but it only appears more icon to indicate that the audible speed camera is off, on which you click to activate this function?
Posted Oct 11, 2009 · 14:16 UTC#1324
warning radar in Spanish?
are very large
buscar
Posted Oct 11, 2009 · 14:20 UTC#1325
are very large
buscar
i don't know what you mean?
Page 53 of 65
