IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 63 of 65
Posted Dec 21, 2009 · 14:49 UTC#1551
it's OK i found the parameters in navgatemap.ui (
Posted Dec 24, 2009 · 22:52 UTC#1552
Thankyou for all your your work IDT. This is by far the best MOD for my tastes, I have been running it since its release and have no intentions of going with a different MOD. ( I prefer it over skin2, sorry)
If someone could let me know how to change the background behind the time and date to a solid background?????
Posted Dec 25, 2009 · 03:00 UTC#1553
look for this bitmap in your 800_480 folder
IDT_time_bg
and change the alpha layer to be a solid white nd that would do the trick
Posted Dec 30, 2009 · 15:56 UTC#1554
Hi Julius,
first of all great job!
I have a F900BT european (italian), I have been using GTI Matts mods, for months, then, since I wanted to have new maps, I bought and installed CNSD-100FM and the official pioneer upgrade from pioneer site (version 3.0200200). WIth this setup may I install your mods? Am I missing something?
I tried to install all 4 of your mods for eu skin 1 and 2 and alternate, but each time my units keep saying start up loading.... and it keeps going on a loop and then shuts down and keeps loading!!! I obviously restored original data.zip, sys.txt and save folder and everything works, but I 'd love to use your mods, if I can get it to work!!!
I will definitely make a donation if I can get it to work as I did with Matts and his mods (I really think everyone should do it!).
Just to make sure I did things right: I copied DATA.ZIP (this one was taken from your updated datazip for final version folder), SYS.TXT, and DS-DIGI in MYFLASHDISK\APL2\IGO and then I deleted in My Flash Disk\USER\UserData\iGo\save, everything but favourites.dat. restarted the unit, but it's not working!
thanks in advance to whoever can help!
Posted Dec 30, 2009 · 22:55 UTC#1555
Hi Julius,
what i would suggest is to download a new set of files and then try installing it one by one to determine what is causing problem (data.zip and the digi file should be installed at the same time) let me know how it goes
Posted Dec 30, 2009 · 23:22 UTC#1556
Hi Julius,
OK, I'll try! thanx
Posted Jan 06, 2010 · 18:15 UTC#1557
IDT - A "quirk" I noticed is that the Arrow, (car icon) sits almost completely through an intersection when I am at the stop line. During Nav. my Arrow is about 3/4 to 7/8 of the way past my turn by the time I am at the actual turn. This is frustrating in unfamiliar terrortory with a tight cluster of streets. I also noticed during Nav. that I am about 40 meters off in distance.
Is there a "Calibration" somewhere? I am currently running only the IDT 3.0vFinal mod if that has anything to do with it.
I realize I am being fussy, :)
Posted Jan 06, 2010 · 19:10 UTC#1558
glad to hear you got a new unit, this forum would be lost without you. thanks for all your great work. i am glad to have donated to your cause.
Posted Feb 12, 2010 · 20:37 UTC#1559
just wanted to keep the thread alive, i'm currently working on an update for this skin
Posted Feb 13, 2010 · 02:02 UTC#1560
Hi IDT thanks for working to update this mod .And when you think that will be available.
Posted Feb 13, 2010 · 03:30 UTC#1561
i don't wanna give dates as i might not meet it, hopefully soon as i'm done working with skin#2 for now,
Posted Feb 13, 2010 · 21:15 UTC#1562
Awesome, I have been running this mod solely since the last update. Great mod with very little issues involved. Thanks!!!
Posted Feb 16, 2010 · 00:11 UTC#1563
just wanna know what issues your having with the mod, i'm half way through the updating process and have the fuel calc, map changer running and some other setting running, if you could let me know ASAP the issues your having then i might be able to include it on the next update,
Posted Feb 16, 2010 · 18:05 UTC#1564
Will it have a gas mileage tracker?
Posted Feb 16, 2010 · 19:15 UTC#1565
if you're referring to fuel calculator, yes it will be included on the next update, 75% done on the update, hopefully it'll be out by the end of the week
Posted Feb 26, 2010 · 17:49 UTC#1566
Huge fan of your work, been rockin 3.0v, n lovin it! :D
Posted Feb 26, 2010 · 17:55 UTC#1567
thanks
Posted Mar 01, 2010 · 17:50 UTC#1568
Cant wait for your update :D , you rock bro!
Posted Mar 01, 2010 · 18:18 UTC#1569
already have it done, just need the time to upload it
Posted Mar 01, 2010 · 18:30 UTC#1570
And just the gas mileage tracker?
Posted Mar 01, 2010 · 18:46 UTC#1571
Posted Mar 01, 2010 · 20:05 UTC#1572
i meant it to be seperate if we wanted only to add that?
Posted Mar 01, 2010 · 20:31 UTC#1573
seriously haven't had time to do it, maybe later on, i'm trying trying to work all the hours i could as i just found out that we're going to be laid off within two weeks, :(
Posted Mar 01, 2010 · 20:49 UTC#1574
Good luck man, sorry to hear that!!
Posted Mar 03, 2010 · 01:49 UTC#1575
March 02/10
-added infoscreen
-added fuel calculator
-added map changer
-fixed signpost switching when speed camera is available
-fixed planmode bug,
-some other stuff
download link on first page
Page 63 of 65
