awsome were do i put the fuel calculator and how do u acess it on the deck?
IDT skin#1 v5.5 03/02/10 9download link to be updated)
when navigating a shortcut for it will pop up, regarding on where to put the fuel calc you have to read the instructions
I want to place it on another mod not yours?
like i previously said, i don't have the time right now to do it, i'm actually taking a break from modding and just wanted to release this mod before i do
Thank you for updating this for us. I have been using this since the first release and will never change. Hope all is well up there.
Great mod thanks . are you planing to add left/right announce of destination to your mod .Thanks in advance.
AFAIK the sys.txt already has the code neede for the announcement, you just have to find a compatible tts file ,
seriously haven't had time to do it, maybe later on, i'm trying trying to work all the hours i could as i just found out that we're going to be laid off within two weeks,
Damn, sorry to hear that, IDT. You've definitely have had your share of bad luck. Keep plugging away. It's bound to get better.
i just really hope it gets better, i think i've already suffered enough,
I've loaded v5.5 onto my unit, but when I press the FuelCalc or MapChanger it states Utility is not installed or Utility is not installed. I thought I loaded the Extension folder in the proper place, MYFLASHDISK\APL2\IGO\CONTENT \, but I must be missing a step somewhere. Any help would be appreciated.
it should be in MYFLASHDISK\APL2\IGO\, not in MYFLASHDISK\APL2\IGO\CONTENT \
Ok I will do that but this Note is what threw me off.
NOTE to users, some users use gallons so here's instructions for it, this is assuming that your in testmode
1) go to MYFLASHDISK\APL2\IGO\CONTENT \Extension\Fuelcalc and delete the contents,
thats an error on my part, ill updat the instructions, thanks for pointing out
IDT, thanks again for this. But I knew I should have left well enough be. Anyways, i sent my AVIC into a slow reboot now. I think it was mainly because I didn't use 7-zip, but regardless I put the old files back and it still does it.
I'll figure that part out, but had a question on the #7 of the directions. Is there another thread that explains the maps part, or could you help me there.
Do I delete the old maps folder?
the only thing you have to do is to create a new folder and name it as map_nt, this is where you would put other maps that you prefer (NAVTEQ, or even a newer or older version of TA), do not delete your map folder, also, copy the basemap.fbl file from your map folder and paste it to the map_nt folder
Thank IDT. I have the same maps in both MAPS and map_nt folders, I assume that is ok. I am still not able to access the nav system now though it doesn't reboot, it just reverts back to whatever music screen I was on. This is no matter if I try to access the map button or navi setting. The other interesting thing is that when I restart the AVIC, I hear a Windows start up sound.
I have modded the sys text and will see if that will work. If in US, I am use the Data and sys from the 5.5 standard download, from the standard only folder (not eu or MSN as I don't use MSN)
If you don't have any ideas on this, i am just gonna reformat the whole nav and let it be. No biggie.
Sir,
there is one way to find out about your problem. let me explain;
when you start you vehicle and your HU is starting up, wait until you see the Main screen with the little warning sign and click setting on the bottom right corner and then click navigation. If there is a problem, you would see a little error windows. (i.e, can't find maps, or something like that)
For the maps, if you want to use navteq, put your navteq maps and basemap file on your map_nt folder.
the windows start up sound actually is kinda like a confirmation that the navi part botoed properly, have you tried just using the sys.txt included in the download?
Eyah, just tried. No go. It actually caused a hard reboot, not sure if it is the sys or the data. Not getting the windows sound now though, but am getting a little screen quickly that says application (or something like that) not found. It is too quick for me to read.
So these have to be Navteq maps? I may have teleatlas, I don't remember and cant check cause ican't access that part of the navi.
to figue:
it won't let me that far, once i click settings, it reboots.
to figue:
try deleting the contents of the save folder,
OK, I deleted that last night, but went back in there was stuff there again, so i deleted it.
I loaded the data and sys from the new standard folder. On reboot, it loaded the maps when the map button was pressed and set the time and date automatically (got the windows sound back too). But when I went to the setting button on menu, it rebooted again (did not shut everything down (XM still played) ). Now it won't access the maps either. It did this this morning too. So I know I must be close.
Just to check again, I have MAP and map_nt with the same maps and basemap in them, is this ok?
extension folder, I use gallons, so changes the fuelcalc files and also has map changer and restart in there, right. I haven't changed anything else but those and the data and sys, and even reverting back tot he backed up files does this.
everytime you go into testmode it's advisable to clear up the contents of the save folder
this is strange,
try just having basemap.fbl in the map_nt folder
what unit are you using?
90bt
90bt
try the instructions above, what i suspect is some files are getting corrupted. Also try downloading a new set of files and this time use 7-zip.
Still a no go.
Questions:
Is there any files or folders I could have modded that the Data or Sys communicate with?
IS there a log collector or file that gets placed in the unit that I can pull that igves errors in a text format?
