Anyway to get rid of the caution screen "ok" on bootup?
By moiz87 · Aug 09, 2009in Hacks/Mods💬 83 posts👁️ 75,081 views
Page 4 of 4
Posted May 04, 2014 · 01:11 UTC#76
Ron S.
Newbie here, can you explain or throw me a link on how to apply a patch offset. I have upgraded to 5.0.
Posted May 04, 2014 · 15:55 UTC#77
Ron S.
Are you asking how to patch the file, or how to install it in the HU (using testmode)?
Either way, I can't give you keypress by kepress instructions from memory.
You need a hex editor on your PC - I use free HxD. It is pretty easy.
You can use the file NAVI.exe from the SD you used to do the install. I recommend copying it to the PC, modifying it, then copy the modified file to a different SD along with testmode.key - don't loose the original just in case.
Insert the SD in the HU, it should boot into TestMode
Go to File Maintenance
Navigate to /USER
If PRG.FLG exists, go to PRG1 folder, otherwise go to PRG0
Delete NAVI.exe
Navigate to your SD and select NAVI.exe them select COPY
Go back to where you deleted (/USER/PRG0 or PRG1) and paste the file.
Remove the SD and reboot.
Posted May 06, 2014 · 19:20 UTC#78
I have the 110BT upgraded to the 5.0 FW.  Can someone with the same unit and FW post the modified NAVI.exe file.
Posted May 26, 2014 · 19:43 UTC#79
Can someone post the modified Navi.exe for a 110 modified with the 5.1 Application version?
Posted May 26, 2014 · 20:07 UTC#80
I cannot see BE9A4, but only BE9A0. I have a Z110bt upgraded to 5.1. Should I upgrade this line instead?
Posted May 27, 2014 · 13:58 UTC#81
Sounds like you don't understand how a dump works. The line you highlighted starts at 0xBE9A0 and shows 16 (0x10) bytes. The next line starts at 0xBE9B0. So the patched bytes would start in the 5th column :
BE9A0, BE9A1, BE9A2, BE9A3, BE9A4......
Edited May 27, 2014 by RonS
Posted May 30, 2014 · 19:31 UTC#82
Thanks that makes more sense. I edited the file and it worked.
Edited May 30, 2014 by mds2004
Posted Jan 11, 2016 · 00:32 UTC#83
Has anyone explored how to disable this with the NEX units (8100, 7100, etc)?
Page 4 of 4
