avic f900_700 ver_3.000300 **EU** download **EU**
By Tomola · Aug 18, 2009in Hacks/Mods💬 75 posts👁️ 41,692 views
Page 3 of 3
Posted Sep 24, 2009 · 20:28 UTC#51
Thanks, works great on f900BT EU
Posted Oct 01, 2009 · 20:46 UTC#52
Has anyone else noticed any blue squares on the map, like sections of the map (in squares) are a different colour. Everything works great, just this seemed a bit strange. Never noticed this before.
Posted Oct 02, 2009 · 13:16 UTC#53
I have Tomolas APL2 folder running in Firmware 3.01, I would like to add the speed cam mod v3
do I just copy the data zip and sys txt files over the ones on my unit, or do I need to edit Tomolas Data zip file with the speed cam mod files then put on SD card and copy over the Data zip on my unit?
Posted Oct 03, 2009 · 08:15 UTC#54
how can i install this version over my 2.09 ?
Posted Oct 03, 2009 · 08:19 UTC#55
Yes I had the same problem.It is something within the map itself and I couldn't get rid of it.I solved it by installing updated maps(2009.Q6)and haven't had a problem since.The link to these maps are well documented elseware on this forum :)
Posted Oct 03, 2009 · 08:47 UTC#56
This is how i done it.
First I updated my Wince files (from 910bt Eu firmware upgrade 3.01 on official site) you need to enter service menu
Then I copied the rest of the files from this firmware over my original files in testmode
I then copied over Tomolas APL2 folder over the updated APL2 folder
Then I got the most up tp date maps 2009-6 and copied them into my map folder in APL2/Igo/Content/Maps
And now got firmware 3.01 and latest maps running on my F900bt
all links are in this forum for what you need
8)
Posted Oct 03, 2009 · 15:35 UTC#57
Ok, thanks. I've got updated maps so going to try them.
Posted Oct 04, 2009 · 12:55 UTC#58
Please help:
I have a AVIC F900 BT type of device, it Version 2.5.
I would like to update the map but can not see the machine in the corresponding fresh map.
What can be done to work?
Posted Oct 10, 2009 · 22:38 UTC#59
the perfect update.
only one problem, the red arrow is going ahead on my car, why?
there any way to correct it?
Posted Oct 11, 2009 · 06:30 UTC#60
Help me!
I am in Hungary, I have a Pioneer AVIC F900 BT. type of navigation device.
Come 2:05 version. The maps I would like to replace it, but I do not know, because I always rebootol.
The maps are the same (8.0) device.
What can be done to change the maps to know?
Posted Oct 18, 2009 · 15:49 UTC#61
the perfect update.
any solution?
Posted Oct 19, 2009 · 11:23 UTC#62
hi all,
i've installed v3 firmware new map license and speedcam. Now i can see the cam on my unit my i couldn't activate the alert
on settings->navi settings -> alert there isn't nothing about speedcam alert.
why???
Posted Oct 23, 2009 · 16:41 UTC#63
But the maps in this link are for IGO 8.0 ................this new firmware doesn´t work with IGO 8.3????
See this forum for the hacked ezrider 3.0 and the latest maps en buildings. You will also need the worldlicense code. Its all on this forum.
For maps and latest buildings see: http://www.volny.cz/sstopar/mio_mapy_igo8.html
Succes
Posted Oct 23, 2009 · 16:43 UTC#64
Can I update my firmware to the new 3.000. version and continuing using original maps from Pioneer??????
Posted Oct 23, 2009 · 19:40 UTC#65
That link has 8.0 maps and 8.3 maps.
Posted Nov 16, 2009 · 22:07 UTC#66
this worked perfect for my UK model, i used this EU v3 as the backup to save my blank screen problem. so now its fixed and well up to date, a point to note if you are useing this to fix your f900, follow these instructions to the letter http://www.avic411.com/forum/viewtopic.php?f=33&t=27155 "BUT USE THE WINCEIMG.BIN AND WINCEIMG.CKS FILES IN THE FIRST STEPS FROM THIS V3 DOWNLOAD (not from a diferent version)"
had to mention that as this thread and the one mentioned above were my combined saviour!
cheers
Posted Nov 19, 2009 · 10:06 UTC#67
Can someone help me with my update???? I´m driving crazy, there are too much different instructions and don´t know how to update my fu******* f900bt to the new 3.0 firmware version..........
Posted Dec 03, 2009 · 18:08 UTC#68
Thanks, just upgraded my F900BT to 3.000300.
I just would like to know if anyone has successfully upgraded an F900BT EU from this 3.000300 to 3.020200.
Posted Dec 03, 2009 · 18:20 UTC#69
This is how I've done it after reading dragon24's tutorial:
1 - Download the files on the first post, testmode 2.3
2 - In an 2GB SD card put WINCEIMG.BIN & WINCEIMG.CKS that are on the MyFlash folder on the root, create an testmode dir (with test mode in it).
3 - Start your car
4 - Press and hold the menu, map, eject buttons at the same time and hit the reset button.
5 - Once you hit the reset button, you will hear a pop sound from your speakers.
6 - Then the DVD/CD drive will load. When you hear this let go of the eject button but continue to hold menu and map buttons.
7 - This will bring you to a blue screen where you will have to enter the service combination - Up, Up, Down, Menu, Left, Right.
8 - Put the SD card and press Update CE
9 - Select Update SD Format
10 - Wait till it says restart in the bottom center. This will take about 2-3 minutes to install.
11 - Hit the reset button with the SD on the slot.
12 - Once WinCE boots up, double Click on My Device at the top left of the screen.
13 - Copy the content on MyFlash folder on the SD to the MyFlash drive on the device.
14 - Once done (it will take 20 to 30 mins)
15 - Press and hold restart and eject for 5 seconds.
Posted Dec 04, 2009 · 09:49 UTC#70
Well, answering to myself, I just tried to install the 3.020200 update from the Pioneer site and all went well.
Posted Dec 07, 2009 · 15:43 UTC#71
Thank youuuu
Posted Feb 15, 2010 · 17:43 UTC#72
Hi,
Thanks for posting this, i really enjoy the new features on my F700BT.. Upgrade went very smooth without error.
BTW, are these the newest EU maps ?
Posted Sep 12, 2010 · 14:08 UTC#73
Thanks for providing the download. Very helpful to get my confused F910 back to work.
Posted May 20, 2013 · 08:17 UTC#74
Edited Jun 03, 2013 by pawelli
Posted Jan 24, 2016 · 21:05 UTC#75
after several requests i uploaded the avic f900_700_500 ver_3.000300_ 20090511
I'm not really familiar with updating systems but for some explanation on how to you might
wanna look into this post http://avic411.com/forum/viewtopic.php?f=34&t=26418
here is the download, The par files i posted are only need when the rar files are damaged and won't unpack.
have fun with it :)
1 http://www.megaupload.com/?d=3YBUDX0P
2 http://www.megaupload.com/?d=CAK7C9HA
3 http://www.megaupload.com/?d=RAGYEFBX
PAR FILES
1 http://www.megaupload.com/?d=A2X6W7JI
2 http://www.megaupload.com/?d=M1E4O9HV
3 http://www.megaupload.com/?d=3T1BVGFX
4 http://www.megaupload.com/?d=LK0DWFJK
5 http://www.megaupload.com/?d=XLUG7PRG
6 http://www.megaupload.com/?d=I7KHIZXV
7 http://www.megaupload.com/?d=TEB46JKV
8 http://www.megaupload.com/?d=NWIEZ8M0
9 http://www.megaupload.com/?d=1J1CZ8C6
Not working any link...pls can you post the new ones?
Page 3 of 3
