3.x and emulation
By sstrange · Aug 20, 2009in Hacks/Mods💬 67 posts👁️ 14,427 views
Page 2 of 3
Posted Aug 21, 2009 · 20:22 UTC#26
what about other modded data zip? I put one in and got errors?
Posted Aug 21, 2009 · 22:58 UTC#27
Yeah I was just messing around with this too. I know mine is good and I get the FUIU errors with a /layer expected. Same thing when using the trip computer one.
Posted Aug 21, 2009 · 23:17 UTC#28
i thought the point of this was to add new stuff and u could view it before putting it on ur unit?
Posted Aug 21, 2009 · 23:23 UTC#29
Yes you can, and to make it in english you just need to copy the english language file from the "lang" folder of your backed up files into the "lang" folder of the new files you just downloaded.
As was mentioned in the very first post in this thread :)
Of course some people just never read and really sholdn't be messing with these things... :lol:
Why read? That's not really necessary, just start a new thread, then bump it when you don't get an answer, get ticked and leave. :P
Posted Aug 21, 2009 · 23:26 UTC#30
That guy doesn't leave either...
Posted Aug 21, 2009 · 23:37 UTC#31
come on can we get a proper answer?
Posted Aug 24, 2009 · 19:32 UTC#32
I got mine to work :D
Just one question : is it possible to simulate the route or anything?
I would like to change few things in direction/distance color but cant see those due to not having gps signal :(
Posted Aug 24, 2009 · 19:58 UTC#33
Sure. Pick a point, set it as start (I think default skin would ask something about turning off GPS tracking). Pick another point, set it as destination. Then go into Route menu and hit Simulate.
Posted Aug 24, 2009 · 20:05 UTC#34
You are legend Boris!!!! Works perfect, now I can mess around without going to the car everytime :D
Awesome!!! :cool:
Posted Aug 24, 2009 · 20:32 UTC#35
For those still having problems or getting errors try using the World License, Hacked 3.01 ezrider, and new map that is found here viewtopic.php?f=34&t=26742&p=184021&hilit= place them in the correct place and it should work (it did for me).
Posted Aug 24, 2009 · 20:45 UTC#36
Awesome!!! :cool:
You're quite welcome!
Posted Aug 24, 2009 · 22:03 UTC#37
/\that's right. I used hacked ezrider with the license that works on my unit with new map and I also switched the language file to English. Otherwise you will have menu in Ukrainian language :)
Posted Aug 24, 2009 · 23:08 UTC#38
The same files for (ezrider, license and map data) did not work in my emulator. When I put them into my NAV they worked fine. I cannot seem to change the data.zip or maps in the emulator. I can get the original data.zip to work flawlessly but nothing other than that. If I put my mods in the emulator the screen starts and immediately crashes. I wish this would work as it would save me a CRAP load of trips out to the car to test. ;) I need to do more digging I just have not had the time to mess with it in the short term.
Posted Aug 25, 2009 · 06:12 UTC#39
diaftia-
Mine didn't work (was crashing etc) because I forgot that I added another font which I forgot to copy over together with my data.zip. Make sure all the additional files that you had used in your custom data.zip are also copied over. As Boris mentioned earlier use only one map with the emulator (the one you know worked fine in your unit for example together with ezrider, and license file)
Posted Aug 26, 2009 · 05:12 UTC#40
did you delete the license that was already in content/license? if you did that is where you went wrong.
Did you use the base map to run emulation? if you did this is where you went wrong. it does not like basemap.
Pass that how far are you getting before crash?
Posted Aug 27, 2009 · 06:56 UTC#42
This did it! I think I removed the original license as well as possibly copying over the basemap file. This is going to make testing SOOOO much easier. ;)
Posted Aug 27, 2009 · 08:25 UTC#43
Here is the complete 3.x emulator I am using (with instructions). It has a texas map and english lang. Download and Mod away :)
http://rapidshare.com/files/271970819/Avic_Emulator.zip.html
Thanks for the upload I will try it out.
Posted Aug 27, 2009 · 16:23 UTC#44
Do you guys know how to get it to default to the Map when it loads? Mine is defaulting to the destination menu and its hard to get over to the map.
Posted Sep 04, 2009 · 12:57 UTC#45
Thanks guys, got it running.
Posted Sep 04, 2009 · 16:57 UTC#46
just create a shorcut on that screen, maybe add a onlongclick='run sc_ReturnToMap' to the address button,
Posted Sep 07, 2009 · 20:55 UTC#47
How can we use the emulator to test mods to the main menu as well as audio/phone etc. All I can do is create and edit route information along with the way the map looks...
Posted Sep 14, 2009 · 16:29 UTC#48
where in the start_800_480 ui file where i add that script?
Posted Sep 14, 2009 · 23:51 UTC#49
I'd like an answer too...
Posted Sep 15, 2009 · 00:40 UTC#50
yes
Page 2 of 3
