well i talked to pioneer about the freezing with my unit and they think its a processor issue. i sent mine in and hopefully they'll get it fixed this week. i'll let you guys know how it turns out.
Demetrius
Since several people are having this problem, I thought it is something to do with Firmware, not hardware. Did you send whole unit, or just the NAV unit(Screen) ?
Sending whole unit would be PITA.
It seems the whole unit is rushed to market, and several people has several issues with this unit. I got my unit today, hooked on bench and started testing it. Some of the controls did not feel intuitive, but that's ok. The problem sofar I observed on bench are, it did not read couple of USB drives, even after format and kept giving me Error 23 on the screen.
So, I connected my iPhone, which is recognized and played fine. But funny thing is, when I turned off acc( Key turn off) while playing music from iPhone, and turned it on again, music start playing again which is good, but played like old worn out vinyl record, repeating the words. When I changed the source and went back again, it worked fine.
Unlike my Prius inbuilt Blue-tooth which paired very quickly with same phone, this one took too long to pair for the first time. Later it connected quickly. Vioce quality was not good, but I did not fiddle with settings yet.
Making all audio adjustment using the single joystick control kinda tricky, not easy like typical car audio systems, but I guess I will get used to it.
Also another thing, I thought I would be able to play music without the Screen, but I could not turn on the unit without the screen at all(unlike Eclipse unit).
Anyways, please let us know how it worked out for you after Pioneer fix.
