Yes, even the 1.003 firmware the nav will occasionally go into "airplane mode" and have you fly over fields and lakes a mile or two from where you really are. Eventually it usually corrects itself, but the logic it's using kind of escapes me. What's odd is that the compass shows north correctly, and the direction and speed of travel is matched perfectly, just the location is off. It seems the GPS has some signal but there is a bug in locking into a specific location perhaps a little too quickly, and once it does, is reluctant to second guess and correct itself. I've not seen a GPS with a weak signal react in this manor so I think its more software related. Maybe it's trying to prevent a weak signal from causing it to stray off target, but in fact is protecting a poor location lock in the first place?
I watched it on a recent drive home about 20 minutes out. At first I was skimming over a nice lake, but once I started tracking thru streets it would try to do it's best to lock me onto one of them (if I got low enough to the ground I guess
). But gradually as it jumped me street to street it would tend to lock onto a street that was a bit closer to where I really was, finally gear down for landing after about 15 minutes.
I'm trying to figure out if it's related to where I park. Most often I've seen the problem after parked facing north against 2 story high concrete wall. I've been backing in for a clear southerly view lately to see if that makes a difference.
