i just finished copying this, now to test it out and see if there's something that could be added to it
Ported Gurjon Display (Navigation Cruise) - Instructions V2
What did you do to get this to work? I copied all of the images it referenced to other names, copied them to my 800_480 directory but I get a black background. The text seems to work though. The only image that shows is the speedcam one. Problem is I have no way to view what the images are since I cannot seem to find an image viewer that can read these BMP's. On top of that I cannot seem to search for anything in his original data.zip file. I am guessing its because his stuff is in russian? Not to mention that the Gurjon code is a little beyond my skill level. ![]()
I must be the stupidest person here, but I want to get this working so much that I don't care if everyone knows how stupid I am! ![]()
So, I have a couple things I'm hoping someone might clarify for me, please.....
the instructions say:
"Just like the trip computer screen, this screen requires people to move over two ui files. One inside the 800_480/ui directory and the other in the common/ui directory"
What 2 files do I move, and where do I move them?
"Obviously the destinationdial.ui goes in the common/ui path and the destinationdial_800_480.ui goes in the 800_480/ui directory"
Where is destinationdial.ui coming from and how do I get it?
"These new ui files need to be included in the main.ui file in the 800_480/ui/ directory as well. Just follow the convention/grouping you notice"
Convention/grouping? I don't even know where I'm supposed to be looking!
I've got the Gurjon skin working, do I have to stop using it? If not, won't overwriting the data.zip make it stop working? This data.zip is 3 mb smaller than my gurjon data.zip.
Thank you in advance to anyone who is brave enough to try straightening this out for me!
icps - is there any way someone could post the needed files for this mod?
@infochia
If you have the gurjon skin, then you have this already. Push and hold the speed digit and it'll appear. A soft push will take you to the trip computer, hold it longer and you'll have what Ben ported over from the gurjon skin. I posted a picture of it in the gurjon thread.
Thank you, great MOD. Keep it up!!
Hmmmm looking at yours something is off on mine. I see a lot more of my background. Does anyone know what the name of the image is that is the black layer over the background?
There was a post I put on here that didn't show up oddly enough. It's good because I figured out my problem. So if it ever does... ignore it. ![]()
Like NSEW said. This is for people who don't have the Gurjon skin and want that screen. You don't need t do any of this with the Gurjon Skin. While I really like that skin, i decided to revert back and really liked this screen from it.
you can get the destinationdial ui files from my data.zip that I posted. What you do is unzip it and look at where they need to go in yours and it's already done in the posted version. For example the destinationdial_800_480.ui is located in the posted data.zip/ui_pioneer/800_480/ui directory.
if you open the main.ui file. You see a set of imports. You will notice that the 800_480 imports are in one main group and the common or the other. This just means type in the line "import ..." to essentially include the different ui files in the running system.
All the files needed if you don't have the gurjon skin are posted in the data.zip file. Again - if you are using the Gurjon skin, you don't need any of this. That's where most of the work came from (I just pulled it out and put it in it's own state transition...
Thanks,
Ben
N-S-E-W & Ben,
Thank you very much for your patient and helpful replies. I don't know how I missd the fact that this mod was included in the gurjon skin~!
But, when I press the speed digit, I don't get anything even close to the picture in the first post of this thread. I did get a huge digital number showing in the center of my screen.
What do I need to do to make the following show on my unit and work?
I'm sorry for just not getting this, and I really appreciate your help and patience.
gratefuly,
ic
No problem at all - I should have done a better job highlighting the point that this is a part of Gurjon that was pulled out.
EDIT: To confusing - see post below that describes how...
Ben
NSEW or others may be able to tell more how to activate it. I can't recall exactly how it came up . I know the other extension (digital speedometer) is the one you are referring to.
I think it had to do w/ something w/ NavigateionCruiseSettings or something like that...
Ben
Press the same spot but press and hold for a second or two.
Ben
So as not to confuse others that don't read through all this, the way to access this on the GURJON zip is as described by diaftia.
For all others YOU will decide how to access it by what ever bmp you attach this code to: onrelease='nextstate ST_DESTINATIONDIAL'
It's working!!!!
Thank you for your help (& patience) Ben, N-S-E-W & Diaftia. I really appreciate it.... ![]()
i checked your picture again and found my answer, i see that you're going 900+ mph so that's why, whatevers controlling it is just to go to i think 220 kmh or 150+ mph
Yeah I am to reproduce in simulation but the first time that I saw it I was navigating. The odd thing is that the gridded dial portion is a solid piece. In simulation it will work, and then go away when a turn or exit changes. I will see if I can get a screen shot if it working and see if there is any obvious indicators.
Nobody else is seeing this huh? I have narrowed it down to when the posted speed limit is 65. I even just changed everything over from the BDS trip computer to IDT's trip computer and its still doing it. New .ini files and all. It only does it on freeways when the posted speed is over 65 (although I have no freeways to test over 55) and will do it in simulation mode and real life driving.
