I guess its safe for me to delete this version off my comp and hope for someone to create an ISO file instead. I gave up tryin to burn this last night since I was havin a headache of a ime tryin to do so. On top of missin files, try searchin each of the files in the CNDV-90MT folder and there are some folders in that folder that are empty. I would advise everybody to hold off until a legit version is released.
CNDV-90MT are NOW POSTED
I tested this morning on my drive to work and it worked flawlessly. I don't know what to tell you guys. It's working 100% for me. Use the programs I specified and it will work for you too. Also, I used WinRAR to extract the files. I suggest you all do the same. Check warez-bb.org for the program and serials.
Can you seed? Need some seeders out there?
7.55 GB (8,114,246,275 bytes) This is the original east coast disk property's
7738.3 MB(8,114,246,275 bytes) This is the east ISO Direct from disk
7.55 GB (8,114,246,275 bytes) This is the rar file that i made then uncompressed to folder to check property'
So it seem that all data is there and unchanged and all property's match...
I will leave it to you guys i have the ISO'S made directly from the disks the i can put up as torrents .... ![]()
SWDW can you check the original disk and tell me what is the volume name and total size ?. Thanks this will eliminate some of the confusion.
7.55 GB (8,114,246,275 bytes) This is the orginal east coast disk propertys
7738.3 MB(8,114,246,275 bytes) This is the ISO Direct from disk
7.55 GB (8,114,246,275 bytes) This is the rar file that i made then unconpressed
my opinion is if you post the iso i would take toooooo long to download also the way it is now you can change the xm icons.it took me 10 hours to download it and its 12 seeders not including me..i will seed for atleast 2 weeks because i know i would want it so if everyone the gets it seeds things will be great.
Much appreciated. Are you seeding?
Can you set your folder options to show hidden files AND turn off hide protected system files, then re-do a byte count? Also, sometimes the manufacturers include zero byte files to stymie copying - they will not copy over, but will do so if the disc is extracted to an ISO - found this to be true with the older CNDV-50MT way back when.
THIS IS THE SIZE ON DISK WITH HIDDEN FILES TURNED OFF AND PROTECTED SYSTEM FILES TURNED OFF
BOTH THE SAME
BOTH THE SAME
OK thanks SWDW. We'll that's exactly what I have with the un-RARed files from the original East. I still say the ISO extraction is a better tool, since it captures a true image of the original, and since it was what was used in the past. Anyway the files from yesterday are unusable for most of us - it's worth to do an ISO version and see.
BOTH THE SAME
that's only if SWDW does not mind for doing us a favor to help us out =)
i'm gonna try this later and post back results
i got it to work too. i used winrar to extract the files and power iso to create the image then burned it.
Disc i used : Verbatim DVDR+ DL
Mines is working also i forgot to add the Poi's Overlay thats why i thought my poi's wasnt workin but it works perfect ![]()
im using TDK DL disc that I brought from Office Depot to the person who said TDK disc does not work.
Can you seed and update the tracker? Seems like it is out... I am on a T1 3.0MPS up and down will seed after for a while.
I'm going to post the ISO's direct rip from the disks with md5 and udf turned on.
Will give you the links when there done.
just remember there Huge when not compressed !!!!!!
i am so glad your office depot tdk disc worked for you.
I'm going to post the ISO's direct rip from the disks with md5 and udf turned on.Will give you the links when there done.
Thanks SWDW...
how much longer you think you'll post the link?
i'm leave work in 2 and half hours, i want to leave it download and seed from my work connection.
HERE ARE THE LINKS TO THE EAST AND WEST ISO ....DIRECT 1 TO 1 FILE COPYS WITH MD5 AND UDF TURN ON EVERYTHING CHECK AND MATCHES TO THE BYTE.. THIS IS ALL I CAN DO!!!
http://www.mininova.org/tor/3006030
THANK YOU!!!!! SWDW. ![]()
PEOPLE! LET'S START THE SEEDING!!!
Thank You.. Anyway you could another Tracker? Piratebay seems to overloaded
Many many thanks!!!
Many many thanks!!!
trackers
http://open.tracker.thepiratebay.org/announce
http://tracker.openbittorrent.com:80/announce
http://tracker.publicbt.com:80/announce
