What is the best program to burn the 90 mt disk?and where can i find it on the internet?
Imgburn http://www.imgburn.com/
thanks and can u tell me the whole process of how to burn it using imageburn please.
Once you have imgburn installed, just right-click on the .iso file and select Open with imgburn. Once in img burn, under the settings area select write speed to 1x, under the destination area click on verify, and then click on the Disc image and it will burn.
Here is a link also
http://www.avic411.com/forum/viewtopic.php?f=6&t=22452&hilit=burning+disc
ok cool , when i open imgburn i see two selections to burn and they are as follows,
WRITE IMAGE FILES TO DISK, WRITE FILES AND FOLDERS TO DISK
witch one do i chose??
hey thanks a whole lot ![]()
ok cool , when i open imgburn i see two selections to burn and they are as follows,WRITE IMAGE FILES TO DISK, WRITE FILES AND FOLDERS TO DISK
I have never seen this option before, but I would say "Write image files to disk" are you sure that you up clicked on just 1 iso file
POSITIVE, MY EAST DOWLOAD IS 90 PERCENT DONE
Hi,I have downloaded these 2 files from mininova and can not make them work.
Does anyone know the file name of the dvds? Or do i need too do something else to make them work i downloaded
a RAR file not an ISO. Pleses help ![]()
the file u downloaded from mininova are good copys..i downloaded the same ones...you have to make a folder on the desktop, then use winzip and extract the files to the folder u just made. U imageburn to create an iso file, what i had to do after. i used ultraiso and copied all the folder onto the iso and resaved it, the used untra iso to burn the dual layer dvd.. Make sure to copy the folder into the iso or the nav dvd will not work. also when u goto burn make sure to click the dvd button. hope this helps i have made many copies of these disk this way and they work perfect
damn i am sooo glad i downloaded the ISO file. thats a "cluster"
looks like you have opened the file. what you are seeing are the folders. you want to burn the entire ISO file.
Yes, I know I need to burn the ISO but it won't let me. It will only open the file as seen on the pic I posted, it will not let me burn the ISO file itself. Any idea why?
from the picture you posted, can you go BACK one screen? when i burned using powerISO, the name of the file i burned was 200909302220. i have never used the program you are trying to use.
No, I can't go back. Here is what I did, maybe it will clearify it better. After I downloaded the ISO, I then extracted the RAR file to a new folder on my desktop. When I try to burn the ISO file with Alcohol 120% it simply shows the folders on my drive, like if you open your Windows Explorer and see what's on C drive. I try to chose the ISO file to burn but all it does is display the files in the ISO file like shown in the pic.
Did that make any sense?
if you would like to give powerISO a shot, here is a link to a free download. http://www.poweriso.com/ I have been using the trail version for last years and this years version. download and install it. it show two panes, files on the left and folders on the right. as long as you have the file highlighted in the left hand pane and you have the DL DVD inserted, click burn on lowest speed and check verify disc. i wish i could be more for you.
or try this link: http://download.cnet.com/PowerISO/3000- ... 39118.html
I'll thry that, thanks.
Currently I just right clicked on the ISO file in Windows and hit "send to DVD RW Drive", considering that is all I can do with. I have no control over the burn speed and I have no idea if this will even work. If it doesn't I will download PowerISO like you suggested.
If you need instructions on how to get the cd working, download the torrent I posted on the last page and just download the 6mb avi file its a short video on how to make the cd
Good Luck
If you like download my torrent, I've got an instructional video included on how to get it working (short and simple I might add) if you only need the east disk just unchecked the west disk in your torrent client
http://www.mininova.org/tor/3019050
Al thanks to SWDW
I download this 3 times and the text and the tutorial do not have nothing and stupidly I click in the other file the image.exe and did something strange I hope I don't brick the PC.
I don't understand why is so complicated just to make a ISO file compress and upload
Good Luck
upload the iso file to download and open with ultra iso and click burn thats it........
how many gigs should the east iso be?
ok i dowloaded the east 90 mt, and saved it as a compressed iso file now alcohol 120 and image burn says there not supported formarts??? wtf
now how do i get this iso file to burn on a dvd??
and what file type does the 90 mt have to be for the programs alcohol 120 and imgburn have to be b 4 they can burn it to dvd???
hello to allwell it is confirm the cndv-90mt is not for the older units=avic-80,90,9 and so on
here is cut and paste of pioneer reply=
Thank you for contacting Pioneer Electronics, Inc.
No, it does not work with the add-on navigational units.
Thank You,
Pioneer Support Group
--Original Message--
Date: 10/04/09
Subject: Parts Inquiry|B00002|2137466337[#1270958
Now the million dollar question is whether the older units are no longer going to be supported going forward, or whether they just decided to skip an update for these this year.
when i downloaded the east 90 mt its in rar file format, now what do i do to burn it?
Al thanks to SWDW
Your an idiot if you could not get that to work. The .exe file is straight from imgburn's website. If you don't have anything better to do then cut down people's work because you are a pathetic scumbag, stay out of it. So please don't slander other people when your stupidity gets in the way.
Why is it that when i downloaded the east 90 mt, the file on uturrent says its 5 gigs or so and then when i got done downloading it it`s only like 2.88 gigs???
