Has anyone had issues where one day, they could no longer get any maps to display on their D3?
I have the West Region 90MT disc via SWDW / Mike. Everything was fine for a month - and this morning, the map display died. Radio, iPod, Steering Wheel control work - just cannot get any map to ever come up.
I did a reset of the entire nav unit (ball point pen next to the eject button), removed and re-inserted the disc - but I can never get the nav system to ever display a map.
When I do the ball point pen reset of the unit (90MT disc is in the unit) - it tells me it is checking the disc and then I get a quick Pioneer splashscreen. It then tells me that it's trying to switch to memory mode and that it may take 30 seconds - and I wait several minutes and no luck.
I still have my original 80MT Pioneer disc. Should I try to revert back to that disc to determine if I have a disc issue or a DVD-ROM / laser issue?
What's the process to go from SWDW's 90MT back to Pioneer's 80MT?
Thanks guys.
Brent
MORRPHUS WROTE THIS BELOW
Fix for an upgrade gone wrong:
If you find yourself with a non working unit or corrupted map data after the upgrade do not despair, there is still hope to "downgrade" your unit. First go to system settings and change the language (doesn't matter if it's to French or Spanish) Let the unit "upgrade" your unit again and make sure it goes well and finishes. then change the language back to English, but hit the eject button before the unit has a chance to start the upgrade. You will see "insert the appropriate disc" message. Take your old working disc (CNDV-80MT) for example and place it in the unit. IT will then "Upgrade" to the older version. You should now have your old version in English.
Sounds like a bad disk happens from time to time.. I sent you a replacment ![]()
