Any way you would just post what you change in DATA.zip? I'd like to do the work myself, if possible. I've already put the igo8 folder in my DATA.zip...is there anything else I need to do?
New Mod with sky for 3.0 (UPDATED with 3Dcar)page 3
Nevermind...figured it out. All I had to do was put the igo8 folder from 9007's DATA.zip into the root directory of IDT's DATA.zip. Then, inside the APL2/Igo directory, put the GFX folder, and add 9007's schemes to APL2/Igo/CONTENT/SCHEMES. Worked like a charm.
Yes, that will do the trick.
Nice work. Now make theme's for yourself and share them if you like.
Now i'm looking to get a car instead of the arrow.
Haha, I've got a bit of free time coming up here soon...perhaps I will.
I have been having trouble with this mod and I was wondering if someone could help. I have copied over all of the files and the unit starts up like normal but when I click to go to the navigation, it just reboots the unit. I am thinking it is something to do with the data zip file because I was able to add the igo8 files to the data zip file of another mod I was previously using and it works like it should. I just like the setup on the navi screen of this one better. Does someone have the unmodded version of the data file? Or any suggestions. Thanks.
El TENIENDO estado Problemas con este mod y me preguntaba si alguien podria ayudar. El copiado todos los archivos y la unidad se inicia como normal, pero Cuando hago clic para ir a la navegación, sólo se Reinicia la unidad. Pienso que es algo que ver con los datos del archivo zip Porque era yo Capaz de agregar el igo8 archivos los datos de un archivo ZIP de otro Estaba Utilizando mod y que funciona como Debería. Simplemente me gusta la configuración de la pantalla de navegación de esta mejor. ¿Alguien tiene la versión unmodded del archivo de datos? O alguna sugerencia. Gracias. [/ Quote]
Me ocurre exactamente lo mismo.Intentado varias veces con el mismo resultado.
Brex05, you also have to copy the GFX folder to IGO/APL2 and the schemes to IGO/APL2/Content/Schemes. (don't unzip the schemes) Al the folders are working together and are related to eachother.
So, only take the ui-igo folder from data.zip and putting it to another data.zip wont work.
Hope this will help.
I forgot to mention that I did add the gfx folder to IGO/APL2 and the schemes to IGO/APL2/Content/SCHEME also. When I added those and the ui-igo folder to the other data.zip the entire thing worked. I had all of the different skies available. I just want to get it to work with this mod. I like the look of this nav screen better. When going from one mod to another is there something I need to erase or can you just freely swap the sys and data files?
I don't know certain, but when in your new data.zip there is no folder such as ui8 and you put it in there, it must work.
Don't merge 2 folders, it wont work.
Someone els ideas??
Maybe upload the data.zip file wich you want to mod, so i can test it???
Someone els ideas??
I like the data.zip file you posted on page 2 but it makes the unit restart when I hit the navigation button. I'm just not sure why it is doing it. I added everything in your dataandgfx folder into the correct spots. I was just mentioning using the other data.zip file to show that the new skies will work on my navi, just for some reason your data.zip is giving me problems. I appreciate your help.
Hola,me sucedio lo mismo ,lo que tienes que hacer es reinstalar el igo folder y despues instalar el data zip ,los schemes y el gfx folder y te funcionara.
suerte
I don't understand Spanish, but I've updated my mod with 3d car. Doenload this link http://drop.io/9007rob unzip it and read the readme.txt.
Greatings. ![]()
Rob EU NL F900BT
No comments??
Rob,
thank you very much, the Schemes looks great. But where do you find the hills in Holland
I have download your last update, but there is no car... could it be, that i have mixed ist with the igo8 skin, hmmm?
Best Regards from Good Old Germany
