here is the new maps .usa canada and mexico
2009.06..very very good maps
here is the link ( i dont know if i can post a link..but)
Are the maps that are in the 3.0 update not the latest ones? This link is using RapidShare and unless you are not a premium member, it will take aproximately 1 year to download 1.6 GB of map info. Lol, new maps will be available then
actually u can dl off rapidshare every 1~2 hours...so once download is completed...wait for an hour or two, come back and download the next file
its not that bad
One thing that is confusing to is that all parts have the exact same files in it so when you are extracting them into one location, they just overwrite the previous part. I tried this with the 2009.2 maps and the parts would not combine, they would just overwrite each other
u wait about 20 min..it s no so bad
or u dont download them at all and u stay with what u have!!!!!!!
its free ......i mean... OR
WWW.TELEATLAS.COM.....you order the new maps..u pay some$$$$$
and in a few days the dvd is at your door....
ok, but how do you add all parts together if you are downloading 14-20 parts and they are all the same files????????
unzip the first part ...and it will do all the work for you..
WTF?????????
I got a premium account to download this and after I got all the files, I need a password to open them!!! What a bunch of crooks!
WTF?????????I got a premium account to download this and after I got all the files, I need a password to open them!!! What a bunch of crooks!
Hello
it is written on the page at Gps Underground.
Pass: 'P P C W A R E Z . O R G' without spaces
Labgate
OOOOOPS!!!! I'm a dummy ![]()
I dont know if these maps are going to work. They have totally different file names eg:
Canada map in AVIC -- Canada.fbl
Canada map in 2009.6 file -- Canada83TA_2009.06_090723.fbl
I dont know if these maps are going to work. They have totally different file names eg:Canada map in AVIC -- Canada.fbl
it doesn't matter, igo will use whichever one is more updated,
Yeah, but the file name has to correspond to the script. So I take it that I will have to change all 56 file names, is that right? Or will it see the file name even though it has the dates etc. in the name?
Yeah, but the file name has to correspond to the script. So I take it that I will have to change all 56 file names is that right? Or will it see the file name even though it has the dates etc. in the name?
no, the way i see it is it has a file name written inside the file that igo looks at so it really doesn't matter, same thing with schemes, even though you change the .zip name it will use the name of the theme in the color.ini
OK, thanks for the quick reply. I will try installing the new maps tomorrow. Its going to take a while though because if the file names are different, then they will not overwrite the present ones and there is not enough room on the flash to have both map files. so I will have to cut and paste the original maps on to my flash drive and then install the 2009.6 maps on to my flash disk
i'm using all of those new maps and i find them better than the one included in the download, although the turn restrictions are still wrong
Ok, but obviously byou had to delete your old maps first, right? I am just thinking about space on the flash disk
yes, actually i'm only using canada maps and deleted everything else i don't need cause i have no plans to go to the states anytime soon,
thats what i thought, it would be quicker to change the file names and just overwrite them as I need all maps ![]()
it would be quicker to delete them and load the new ones,
Lol, how do you delete them? there is no delete button, at least not that I could find
go to contents/maps clicke the edit button, then select all, then there's an X button that you could use to delete it
how are the maps better?
it has the right speed limit, here in winnipeg all the old roads were removed,
1/ back up the map folder from your avic
2/delete the map folder from your avic
3/write the new map folder to your avic
and you are good to go....
or i think u can run the new maps from a sd card....
