Lucky you. Doesn't work for me. Any other ideas?
F500BT 3.0 PLT and APL dump..
Did you try both steps in my last post?
I can only suggest you try finding the Pioneer SW-330 update, although I had no luck googling it. Fk knows why Pioneer EU aint got it there any more, just shows how much they value us as customers........
Also try a search on the Troubleshooting forum, you may get a result.
Good luck ![]()
Yes, I tried both steps. I have a US unit and tried to update to 330 but during the update, the device stops the update and generates an error message.
I solved my problem, but I don't know, if it's worth it. I changed my SYS.txt to UC again. Before, I changed to EW in order to use the US unit with a european cradle, to be able to receive TMC data.
Gonna play around with it a little bit now.
Looks like similar behavior to here: viewtopic.php?t=25231
Here's 330 bluetooth update if it helps.
Thanks, but the update is not the problem. It won't work, when device is set to EW, no matter what....at least for now.
It's like in the thread you posted. Either TMC or BT.
Thank's for help. Problem fixed by changing "EW" to "UC" in sys.txt
Good to hear, but remeber: TMC does not work, if you set it to UC!
It's doesn't matter. There is no TMC in Ukraine...
the download links doesnt work anymore ! can someone re upload them please ?
are if someboy have other links i will be verry happy 3.0 update f500bt
Hello,
i come from Europe and also interested to the Links. I have an F500BT and try a lot out of this Forum, but 3.0 didn´t work. Yesterday my 500 damaged. No Boot anyway, also Testmode. I have boot the wince from SD in the Service Menü, after that i could reinstall the Original-Pioneer Update 200700.., after that i could boot in Testmode and reinstall the Original APL´s and so on, also my Skin, based on 2.0.
Has anybody Run 3.0 on 500er EU-Version? Is it possible, that anybody can say exactly what is to do? It is confused with all the different Thread´s....
Is it possible that the Update not work because i have loaded a Skin? Must I update from Original-Pioneer?
What I want to do is for Example load the Gurjon Skin or Navteq Maps, 3D Cars and so on.....
Sorry for my English, i come from Europe ![]()
Best Regards T
Hi Gents,
I am a happy owner of a F500BT, well could be even more happier if I could upgrade its fw and sw. I tried to get the files from the link posted here but it does not seem to be there anymore. May I ask someone to upload it again and share its location with me?
Thanks in advance!
Can anybody upload this. Can't seem to find a retailer here in canada that sells this update. Would like to try it out.
I'd like to get hold of PLT(winceimg) and APL dump for F500BT as well. Could someone upload a copy?
anybody got this file link?
Hope they are the right ones:
http://netload.in/dateiwTKXqwDeRe/411_5 ... t1.rar.htm
http://netload.in/dateiZGIDFcQHu6/411_5 ... t2.rar.htm
Enjoy!
No that is not it. I have that installed. We need the actual sd backup with the new wince on it.
I think I found it from Russian website (I love google!!) ![]()
http://translate.google.com/translate?h ... ic%3D11171
http://www.rapidshare.ru/1206567
I haven't had chance to try it out yet. My daugther isn't sleeping yet.... can't wait to try it out on F500BT.
That zip file can't be wince. It is only 18mb. You would think it would be larger unless this only updates wince. Who is going to try this out first.
Well I upgraded th wince 6.5.0.6 and all went ok but did not notice any difference. Anyone know a way to check what version installed. Maybe something in testmode. Where does wince reside on the f500bt.
When and if you use this, will you loose everything on the "My Flash Disk" or somthing?
And how does the wince image get applied?
Testmode = WinCE I thought.
Just read everything in this thread. Yes you lose everything on gps. You need to make a backup first. Not hard to do at all. Can't really mess it up. Easy fix if you do. I have been playing with it for a week now. I think I got it just the way I want it now. I do find now that I have only 7.5 mb left on gps. I did not check to see just how much I had before. Hope someone can check on theirs to see how much room they have.
But after update with the files download from russian site, i still have firmware 2.007000. There must be some mistake. Help me please
You need to upgrade APL folder. Once you replace APL folder from x910bt dump, you will have updated firmware information. Also, you could upgrade APL folder to one from EU's firmware version 3.020200.
