F500BT 3.0 PLT and APL dump..
By miotoo · Sep 28, 2009in Hacks/Mods💬 85 posts👁️ 25,283 views
Page 3 of 4
Posted Jan 25, 2010 · 14:28 UTC#51
Warning to anyone wanting to upgrade to wince 6.5.0.6 posted above. Leetlauncher will not work after the update. I don't know why but it will not boot. That is ok though.
Posted Jan 25, 2010 · 16:25 UTC#52
The original download links are dead. Anyone has the latest download links?
Is there any significant advantage upgrading the WinCE and APL to firmware 3.0 level?
Posted Jan 25, 2010 · 20:51 UTC#53
I updated to get latest APL (av and bt apps). It looks quite good and works quite well for me. I guess it's really up to you if you want it. There isn't any significant changes that I can tell from v3 (wince & apl) compare to v2.
New BT doesn't display across screen. It's on right side of the screen and doesn't cover up the tracking arrow.
Posted Jan 26, 2010 · 19:17 UTC#54
You mean there is no difference between version 2 and 3? Does it really not worth upgrading the F500?
Posted Jan 26, 2010 · 19:52 UTC#55
I guess it's really up to you..
If you want to run the latest os (wince), I would... I like to run the latest and greatest s/w.... always. :D
Posted Jan 26, 2010 · 20:01 UTC#56
If I have not tested, I can hardly choose. :mrgreen:
You've tried both, without mentioning that you like last FW, are there advantages really about 2?
You do not know if it's worth the risk to update my unit, if no real advantages.
Posted Jan 26, 2010 · 20:50 UTC#57
Indeed, those who have upgraded from the Russian website, has just updated the file that is being posted here, or have done all the instructions that say the Russians, download the 5 parts of a file, etc?
Posted Jan 26, 2010 · 21:00 UTC#58
Only download the wince update from the Russian site. The rest you can figure out how to download from here.
Posted Jan 26, 2010 · 22:28 UTC#59
A help, please? I am exhausted from so much searching on here for my F500 ... :(
Posted Jan 26, 2010 · 23:51 UTC#60
Parruso what are you trying to do. Update wince or get new maps. You don't realy need the new wince. Download the new maps. This is the wrong thread for that. Go to complete 3.0 install guide and rwad on. Lots to read. I had to do it. Read all of it and you will figure it out. You will not mess up your gps if you understand how it works. Take your time and read. I can't give you all the steps. Ask a question in that thread if you don't understand afterwards.
Posted Jan 27, 2010 · 22:03 UTC#61
I have current maps. I have the Avic customized, skin and others, but what I want, is upgrade to 3.0, as if I had bought the CNSD 150.
The problem is that in Spain, the update costs 195 €, about $ 273, far from the $ 60 it cost in the U.S., and I think that is theft. If those costing $ 60-80, would you buy, no doubt.
I read a lot, took a year in this forum and read a lot before you ask, but right now I'm exhausted from so much reading, and understand that I am translating with Google continually posts, and it becomes a bit complicated.
If you have some clear steps, I appreciate that post, because I do not know where to shoot.
Anyway, I keep reading ...
Thank you!
Posted Jan 27, 2010 · 23:03 UTC#62
Download the file listed in this post and then get to the service menu hold Power and Reset for 5 sec.
Passcode is MAP,MAP,MENU,Enter (center of joystick),MENU,Enter. Once in Service Menu the reset button is the only way of navigating. Short push move through options. Push and hold for 1/2 sec selects option.
You will figure out what to do from there.
Posted Jan 28, 2010 · 00:00 UTC#63
Okay, thank you very much for your help.
Right now I'm upgrading. I updated the file with WinCE Russian, and now I am copying the maps and others.
One question I have is that in System, before upgrading, the version was version 5.0 and now continues to 5.0, but the system seems different. There are more icons on the desktop and testmode not work, I had to put Tesmode 2.3 (go scare me because I hit there was no way to boot ...)
Those things make me think that Windows was updated but the version says otherwise ...
Is it normal? Am I missing something?
Thank you.
Posted Jan 28, 2010 · 10:30 UTC#64
Yes that is normal. I you want it to show up as updated, copy over the apl directory from the x910bt dump and it will show new firmware.
Posted Jan 28, 2010 · 14:39 UTC#65
Are you talking Pioneer software or Windows? Because Pioneer version if it is 3.02, but Windows 5.0, though I see the system differently.
Pioneer software I used for the 3.02 update there on the web of Pioneer. I imagine that will be the same as that of the 910 which you mention, not where it is.
Posted Jan 28, 2010 · 15:19 UTC#66
Are you saying that the version of wince in not showing up on the gps after update. If so all you need to do is copy the apl folder from where ever you got your new igo from. I'm guessing you just copied over the apl2 folder to your gps right. It will then show up. No big deal thought. It is still updated even thought you don't copy the apl.
P.S. I hope you don't plan on using leetlauncher now. It will not work with the new wince.
Posted Jan 28, 2010 · 22:50 UTC#67
Ha ha, thanks for telling me about Leetlauncher. I will not use it. I bought a Pioneer for using a Pioneer, not a Tom Tom or Garmin ... Thank you.
Regarding the WinCE version shown, I see on Windows-Settings-Control Panel-System, and there is Version 5.0.
Anyway, now I can only boot Windows with testmode 2.3, (before could only do so with testmode 1) so I suppose you enough to know that Windows is updated, they?
I completely erased the folder My Flash Disk, and I copied everything that appears on the website of Pioneer Update 3.02, add maps, voices, etc.. Then all the folders APL, APL2, etc, are new.
I guess this way is correct.
By the way, all this would be valid for a F900? O WinCE files are different ...
Thank you, I'm helping too many people, so in my name and in theirs, thanks! :mrgreen:
Posted Jan 29, 2010 · 01:25 UTC#68
No problem. That is what I'm here for. If you ever have any other questions of problems, don't hesitate to ask.
Posted Jan 29, 2010 · 15:13 UTC#69
Thank you very much for your offer, has been a great help. :wink:
The last question I have is whether the same Russian archives and the procedure is the same for an F900. I have a friend who has it and wants to upgrade it.
Posted Jan 29, 2010 · 18:05 UTC#70
I would not try to update wince on those. You can update the maps thought. I'm almost sure that wince version is just for the f500. You may find one on here somewhere thought. Have to look arround.
P.S. just did a search on this site and found an update for those gps's. Good luck. I don't have any experience with those so I can't help too much. Just read all the post first and then only if you feel confortable that you know what you are doing you can move forward.
Posted Jan 29, 2010 · 19:51 UTC#71
Ok, I'll see if I find.
Thank you! :wink:
Posted Jan 30, 2010 · 19:02 UTC#72
Hi all. I just bought my F500BT and upgraded it to 2.006 from the Pioneer website. I would like to update the maps to 3.0. I have downloaded a pile of different versions and everytime I copy the APL2 folder I can't get past the system startup screen. Tried different liciense, changed to the 749, tried different easyrider.exe. Do I need to upgrade ce? I'm not a programmer or hacker but know the basics. I read almost the whole forum and am just confused. Just looking for a simple upgrade to 3.0 before I order mine. $120 I want to see if its worth buying. Thanks for any help.
Posted Jan 30, 2010 · 19:53 UTC#73
First of all you don't need to install the wince upgrade. More complicated for nothing. Did not see a difference. You need to download the files in the f500bt 3.0 upgrade thread. Just read all of it and you will figure it out. You can start at page 4 and on. http://avic411.com/forum/viewtopic.php?f=34&t=25838&start=45. It come with the 2008 maps. You probably downloaded the 2009 maps and all you have to do is before you copy over apl2 folder to gps, replace the map, poi and building folders from the new maps. Oh ya don't forget to download the world licence and copy it over to the licence folder and your licence as well. That may be the reason your gps is not booting.
Posted Jan 30, 2010 · 19:58 UTC#74
Google these two files. 411_500_3.0.part1.rar 411_500_3.0.part2.rar. Download and copy over the new maps. It has the new ezrider and all you need. Just copy over your licence and maps. Hope this helps.
Posted Feb 01, 2010 · 16:38 UTC#75
Thank you for the replies and help. I downloaded the two parts and like another download it has an APL2 folder in each part. Which one do I copy to my Avic? Thanks
Page 3 of 4
