Abb's 'Insane Red' Theme *UPDATED- 12/08/09* PICS ON PG. 4
By abb1 · Oct 22, 2009in Hacks/Mods💬 72 posts👁️ 14,200 views
Page 2 of 3
Posted Nov 11, 2009 · 15:00 UTC#26
Abb.Yes looks good.Installed it and agree it is a bit less in yer face .Did you look at doing a purple theme in the same design?Thanks for your great work.
Posted Nov 11, 2009 · 16:30 UTC#27
Yes, I have done a purple theme but there are a few problems with it, mainly missing textures, that I have to figure out
Posted Nov 17, 2009 · 03:15 UTC#28
Hi abb,
First of all, I LOVE this theme. this was the first one ive used.
Second, i know this is probably a noob question and i might get flamed, but what do you do to use the different background you included in the newest revision and is there something special to change in order to use the big moon on the nighttime map?
Thanks in advance.
Jordie
Posted Nov 17, 2009 · 13:28 UTC#29
Hi abb,
Thanks in advance.
Jordie
The background and the NAV scheme with the full moon are in the IDT 2.0 Nav download on the first pagem Make sure that you install all the files, including the schemes folder which goes into your APL2/iGo/CONTENT folder. The full moon theme is a scheme called night_sky2. I have put all my NAV themes on IDT's Nav mod as I have used most of the Nav mods out there and I find his is the most feature rich mod out there. I have included his mod to accept DPHursts schemes which are the best schemes, so you have the best of both worlds
Posted Nov 17, 2009 · 15:54 UTC#30
thanks abb,
i played around with it before class and figured that it was a stupid question. I figured out how to change it, the only problem i ran into was changing the day background to autumn day background cause igo to shut down. anyone else have this problem or know why it may have done it?
Jordie
Posted Nov 17, 2009 · 16:13 UTC#31
Wow, I just purchased & updated to 3.0, then to IDT's skin, then the new Red theme from here. WOW, insane!!! Best upgrade/mod todate by far!!!
FYI, if you deviate from Pioneer Blue Day/Night themes, the IDT layout messes up a bit. But regardless the red theme stays, and is awesome!!!
Thanks!!!!
Posted Nov 17, 2009 · 18:32 UTC#32
Thanks!!!!
Glad you like it! Did you put in my modded IDT scheme to take advantage fo the RED THEME? It is the second download on the first page. The IDT layout should not mess up, and it is setup to accept some new schemes by DPHurst
Posted Nov 17, 2009 · 18:53 UTC#33
Yes, I did. I love the red theme!!!
If I set it on anything except the Pioneer Blue Day/Night theme for Map Colors...then new buttons on main map screen have some missing.
I have it set as Pioneer Blue, and it works great.
Posted Nov 17, 2009 · 20:15 UTC#34
Ok, .that should not be happening. Can you post pitures of both scenarios? with the blue theme and with another theme.
Posted Nov 17, 2009 · 22:11 UTC#35
hey abb,
have ever encountered the problem that selecting certain backgrounds for the nav causes igo to shut down?
I have had this problem with the night_2 with the moon back and also with autumn day dark and a few others.
Posted Nov 18, 2009 · 12:56 UTC#36
hey abb,
no, those are the same ones that i am using and they are fine. are you sure that you have MY DATA.zip file installed? I altered IDT's 2 DATA.zip file, not only to change color, but also to accept new schemes. Make sure that the DATA.ZIP file has the ui_igo8 folder in it. It is the skynight_2 that has the moon, i am pretty sure that night 2 has the cloudy sky
Posted Nov 18, 2009 · 19:37 UTC#37
ok i will reload the data zip tonight and see if i had forgotten anything. will let you know.
Posted Nov 19, 2009 · 19:40 UTC#38
Great theme. Not using IDT MOD where do I put the image.res file. Would also like to have it in blue.
Posted Nov 21, 2009 · 14:15 UTC#39
The image.res file gets put in the 'My Flash Disk/APL' folder. I have a blue theme and a green theme desiged as well. just do a search
Posted Dec 04, 2009 · 14:32 UTC#40
i just installed this theme, everything is red aside from the map screen it's the normal IDT one, i'm running the idt skin 2 3.0, i did not get your data.zip file as the link does not work, is this why?
Posted Dec 04, 2009 · 16:46 UTC#41
Link will be reposted for IDT's mod later this evening
Posted Dec 04, 2009 · 23:18 UTC#42
Ok, the link is back up!
Posted Dec 05, 2009 · 16:18 UTC#43
hey abb, i must be retarded, i installed your data.zip and my navigation map screen the bar on top is still not red.
Posted Dec 05, 2009 · 20:08 UTC#44
Hmmm, can you post a pic?
Posted Dec 05, 2009 · 20:40 UTC#45
abb1, can you please tell me what image this is? I cant find it anywhere! Its the red one behind the "rear view" text.
Posted Dec 05, 2009 · 20:56 UTC#46
Im looking to get this red theme going but I have a question. Am I supposed to replace the file Image.res under MyFlashDisk/APL/ ? If so do I delete the Image.res because the one I am adding is a Image.rar ?
Help and feedback is greatly appreciated guys I am a nooooob :wink:
Posted Dec 05, 2009 · 21:00 UTC#47
You have to unzip the file first.
Posted Dec 05, 2009 · 21:11 UTC#48
Ok... unzip it and then what? Do i delete the Image.res?
Posted Dec 05, 2009 · 22:40 UTC#49
Replace the old image file with the new one. Read the FAQ's to threads on how to mod your unit.
Remember to backup your unit first.
Posted Dec 05, 2009 · 23:07 UTC#50
I have backed it up and I have read faq's. I just want to get things straight before I mess things up. I download that image.rar file and saved it as a .res because that was the type of file I was replacing. It made sense to me but I after doing so it stays the splash page and does not load up. I thoguht with the mods you didnt have to unzip anything it was just download and tranfser? Im new and eager to learn.
Page 2 of 3
