Hi,
1. If the next move in the upper bar is preceeded by a 4-digit number (1000 m), the compass covers the "1"
i'll have it fixed on the next update
2. In the area showing distance after next turn, the arrow covers the first numer, if it has three digits (12,3 km) the "1" is covered by the yellow arrow
3. Pressing the TMC button or the route button and then returning to the navigation screen, the - don't know the correct expression, sorry - red dot with the red circle does not show. For it to show again I had to press Menu-button and the the Map-button.
i will take a look at it
4. First time after installing the 3.02-update it took long this morning to find the gps-signal - I improved the performance by setting the default location in SYS.TXT to a place in Germany, for Europeans it even helps a lot setting Northing AND Easting to "0.0". But the day befor I had to park in minus 6th floor, where there is no reception of anything. I have to admit, I can only guess why this is so... I don't know Windows very well... To be honest, I try to avoid it as much as I can.
it might be because you 6 floors down and there's no reception (maybe reception is very weak) in there
Thanks IDT for this wonderful mod.
no prob
