For those who've been on here a while you'd have known that it's been a battle to figure out how to get the AVIC's to announce which side of the street the destination is on. When I was running the gurjon skin to my surprise it did announce left/right. I looked at my tts file and it had the codes for left/right so I attributed it to the upgrade which included a new tts file or so I thought.
After I stopped using the gurjon and moved to stanislovoich/andr2000 zip the destination announce was no longer there. Off and on for the last few months I've been reviewing this in hopes of figuring out how to get it to work.
I've finally figured it out. To get left/right via point/destination to work you'll need two things:
1) a compatible tts voice file that includes the left/right commands. You'll know if your file is compatible if in the commands.csv file towards the bottom it shows left/right commands.
2) In sys.txt add the following in the sounds section. If you don't have a sounds section add it in. Here it is as it appears in my sys.txt
[sound]
announce_viadest_side=1
Here's the tts file I'm running for samantha. Install the zipped file in "My Flash Disk\APL2\iGo\content\voice" folder. The samantha tts is also posted in gurjon mod thread on page 9.
http://avic411.com/forum/download/file.php?id=7994
Let me know how it works. As a side note. If it announces the wrong side it's because of the map data.
Edit 11/22 to add the file location to install the tts zip.
