Hey Abb,
Can you tell me what program you use to open the image.res?
Thanks.
You need 7z to open it. Do a search, somewheres (I forget the name of the thread) there is an exact read me on how to open, alter it and save it using 7z
Hey Abb,
Thanks.
Awesome. Thanks very much for your help kind Sir!
Well, I m about to put an update to the green theme using Guga's buttons, a few graphic changes and Diaftias Nav mod. Before I upload, let me know what you think and if it is an improvement over the previous one. Here are some pics:
Looks good. I will try it if you post it. Thanks.
Well, the links are up on the first page! I hope you like them and PLEASE leave feedback or suggestions. I still have the original download with IDT's 2.0 mod, so if you like that NAV mod, just download the new image file and replace it.
*IMPORTANT* If you are downloading Diaftias NAV mod, you also have to add the bnt.ttf, Digital.ttf, and the new sys.txt files as well as the Data.zip file. YOU ALSO HAVE TO GO TO 'USER/USERDATA' AND DELETE THE IGO FOLDER
The current schemes as well as DPHursts schemes will work with this mod.
Abb.
I installed the image file only. Looks better than the original. Only 1 thing to mention is the green could be a little darker at the bottom where sirius is playing. The song title blends in some and it is hard to read what is playing. Other than that...well done. Thanks.
Abb.I installed the image file only. Looks better than the original. Only 1 thing to mention is the green could be a little darker at the bottom where sirius is playing. The song title blends in some and it is hard to read what is playing. Other than that...well done. Thanks.
I too only installed image file and love the green theme - Thank you!!!
QQ though, what is the "Nav" folder for?
It will make your navigation area green also.
DO NOT DOWNLOAD DAFTIAS NAV MOD! There have been a few issues with combining my mod with his. I will pull it when I get home. IDT's 2.0 mod for my red theme is safe to use
Hello,
Abb, thank you für your Mod, looks great. Tomorrow i will try to install it on my F500BT (EU).
I have some Questions:
1. Is there a Button to Mute the speakers while Navigation?
2. Do i need the image.res? Where (Folder?) must i copy the image.res?
3. What is about TMC and Speedcam´s in Europe? Works that?
4. Is the Car included? What do i have to do exactly if i want to have my Dodge Nitro on the Screen? Or another Car?
Best Regards, Thomas
Hello,
1 - Yes, I have modded IDT's 2 NAV mod that has the mute button while navigating
2- Yes, the image.res is the file that changes the overall appearance of the program. It goes into the APL folder
3- I dont know, I live in Ontario, Canada and we dont have speedcams here so I dont do anything with them
4- No, go to IDT #2 mod and he has am entire folder of vehicles there and instructions for installation are in the first post
ok, thanks. I have your Mod now on my F500 (3.0) and everything works fine.
Also Bluetooth, TMC and a car.
When i try the Scheme "winter cloudy" the F500 bricked. I have deleted this Scheme.
Next week i try speedcams and if i find a 3d-Picture of my Dodge Nitro i will change this.
BR
BR
Hmmmm, that's weird, I just tried 'Winter Cloudy' and it works fine in my system. Can anyone else confirm this? I might have done some changes since posting
ok, i have tested another Scheme. The same Problem. Allways when i change a Scheme come´s a windows:
For Example:
"Failed to open file:
gfx/sky0.bmp
exiting application"
I must go into the Testmode and delete the Scheme.
Any Idea?
Did you install the Data.zip or are you using your own Data.zip.? You should have IDT $2 scheme that is modified to my green theme.
i have installed your complete download from Page 1 of this Thread
The reason that you are getting that error message is that the schemes that are not working are linked to a ui_igo file that is located in the Data.zip file which is included in the Data.zip that I had posted. I checked the contents of that file and it is intact and it works fine on my system (F700BT). Seeing that you are the only one with this problem, it has to be your installation. I would reccomend reinstalling everything and overwriting the previous files. The installation goes as follows:
Data.zip, SYS.txt, DS-DIGI.TTF files all go in the APL2/IGO folder
the shemes go into the APL2/IGO/CONTENT folder and just click yes to merge the folders.
The IMAGE.RES file goes into the APL folder
Abb, i have tested it again in the morning. Now, everything works fine. I take a few other scheme´s from this forum und test it....
Well, now i have found a 3D-Animation from a Dodge Nitro. But, how can i change this to Format .mdl? Can anybody help? Look here: http://www.edmunds.com/flipper/do/Media ... av=Gallery
BR Thomas
BR Thomas
The person to ask for that would be IDT. He has an entire assortment of 3D cars. PM him and ask him to see if he can add your Nitro to the list
Has anyone seen a mod/hack that will allow the SiriusXM screen show more than one line of song info? I really want Artist and title to show at the same time.
This has been covered here before somewhere, but I don't think that side of the avic has hacked yet. So for the time being, no.
ok, i have tested another Scheme. The same Problem. Allways when i change a Scheme come´s a windows:For Example:
gfx/sky0.bmp
Any Idea?
Same thing is happening to me. It does not give me the message on all of the schemes, but the one that has the moon, does it everytime. Even tried it with the Insane Red just to see if it was something in the scheme file and still does it.
The reason that this is, is because you downloaded my schemes without installing my Data.zip. IGT's mod cannot utilize these schemes. I have a special folder in my Data.zip that allows me to use these schemes. You do not have this installed!!!!
Thanks Abb
I downloaded your data.zip, but I'll try it again.
Right now my car is torn apart, I'm installing some Polk component speakers, so I'll post up once my head unit is back up and running.
Hello Abb,
the Problem with the Scheme´s is still there, i have also tested other scheme´s.....
I have your Data.zip from Page 1. After my first Post with the Problem i had downloaded the data.zip again.
Well, the Skin looks nice, i have deleted all other Scheme´s and it ist ok...
BR Thomas
