Hello Abb,
the Problem with the Scheme´s is still there, i have also tested other scheme´s.....
I have your Data.zip from Page 1. After my first Post with the Problem i had downloaded the data.zip again.
Well, the Skin looks nice, i have deleted all other Scheme´s and it ist ok...
BR Thomas
Ok, I have tested this again and it works great.The reason that you are getting that error is that my DATA.zip has an extra folder in it that SEES these new schemes. If you have the wrong Data.zip installed or if it was not extracted right, then you will have this error as NO OTHER Data.zip (except for DPhursts NAV) has this folder. Make sure that:
the 'image.res' file goes in the APL folder.
Make sure that MY 'DATA.zip', 'SYS.txt', and the 'DS-DIGI.TTF' file goes in to the APL2 folder
Make sure that the scheme folder gets put in the 'APL2/CONTENT' , let it merge and overwrite anything if it asks
Try this, It has to work as I have tried this out several times without problem. This error will come up if you have the schemes loaded and NOT my 'DATA.zip'
