How To: Complete TA 2009.6 Map Upgrade Guide - Please Sticky
By LTdan · Nov 25, 2009in Hacks/Mods💬 88 posts👁️ 108,166 views
Page 2 of 4
Posted Jan 05, 2010 · 14:58 UTC#26
when you look at the map version after installing them what does it say? I just want to know before I install them because I believe I already have them. Thanks
Posted Jan 05, 2010 · 21:03 UTC#27
I've dowloaded all the files, used password to unzip them. Once I unzip them I can see two folders - "buildings" and "dem". I have no problem copying or opening folder buildings, however, when I try to copy folder "dem" which contains file "NorthAmerica_low_2008_03_25.dem*" it starts copying (in reality as I understand it fully unzips it now) and than it stops and keeps asking me for the password over and over again. What is wrong with it? I thought I only need to enter password once.
Posted Jan 06, 2010 · 04:29 UTC#28
Thanks worked great with the updated Igo from copying the ACT2 folder x910bt.zip and patching
on my Pioneer AVIC F500BT means i don't really need to get leetlauncher.
Posted Jan 06, 2010 · 05:34 UTC#29
I am not a fan of passwording rars so I downloaded all these and rared them up without the password for anyone who has usenet
nzb file is in the attached rar
Thanks! Got em in 5 minutes! I love usenet....
Posted Jan 06, 2010 · 17:45 UTC#30
I downloaded this file, but what do I do with it? When I unzip it, it shows one file total "83_Cont_USA_2009.06_TA.nzb" and this file is only 307,188. The total size files that I download from the "passworded" link is 228,995,205.
What am I missing? I really want to upgrade my maps, but keep missing something out in the file download process.
Please help. Thank you.
Posted Jan 07, 2010 · 15:33 UTC#31
The nzb file points to the locations of the files on usenet that can be used by some newsreaders (http://en.wikipedia.org/wiki/Comparison ... ewsreaders) to quickly find and download news group files. So once you DL the .nzb, you still need to connect and DL the actual files from usenet using a supported reader. GrabIt is a free file grabber that can use .nzb files on Windows (I personally use NewsLeecher, but it does cost 20 USD). Note that even using the .nzb you will need access to a news server (your ISP may or may not provide one - they seem to be phasing out news support).
Your other option is to manually search and find the files:
83_Cont_USA_2009.06_TA.rar
83_Cont_USA_2009.06_TA.r00
83_Cont_USA_2009.06_TA.r01
83_Cont_USA_2009.06_TA.r02 all the way to 83_Cont_USA_2009.06_TA.r15
on Rapidshare or other file sharing service.
Good luck
Posted Jan 07, 2010 · 18:09 UTC#32
It worked great! :)
Really good instructions. thank you :)
Posted Jan 07, 2010 · 19:24 UTC#33
I think i already have the right maps.
The extension should be country.fbl for the maps?
Posted Jan 12, 2010 · 10:29 UTC#34
Hi
Will this generic license work with the EU 2009.09 maps? and if so where i can get the complete (Dem, Buidings...etc) maps we need a guide for the TA EU ones pleasssseee
Posted Jan 14, 2010 · 14:18 UTC#35
Please how to copy a files from my PC or SD card to AVIC-F500BT internal memory ?
Regards;
Posted Jan 15, 2010 · 20:28 UTC#36
Good luck
I finally figured out how to use grabit service, but now all of these files are not hosted :-(. My grabit keep telling me that it is unable to connect to these 83_... files.
Posted Jan 15, 2010 · 21:16 UTC#37
Regards;
Use the testmode.
Posted Jan 19, 2010 · 14:12 UTC#38
Maps working but my POI is showing in another state. Whats the problem
Posted Jan 25, 2010 · 12:53 UTC#39
how can i found MAP and IGO for the EUROPA ?
thanks
Posted Jan 27, 2010 · 15:13 UTC#40
yes for me olso where can i get the eu map of 8.3 use the same ezrider?.
Posted Jan 28, 2010 · 00:09 UTC#41
Do i need to put the testmode and winCE files on the SD as well? Also i downloaded all 16 files but they're in a ".rar" format. Is this correct or do i need to unzip these somehow?
Posted Feb 01, 2010 · 02:10 UTC#42
updated my maps per directions.
Question, does this generic license enable 3d buildings? Right now all i see are landmarks. I'm running Daftia's latest mods.
Posted Feb 01, 2010 · 03:40 UTC#43
Try here.
viewtopic.php?f=34&t=20836&hilit=3d+buildings
I don't think it makes any difference who's mod you are using to get this to work.
There are other license files posted on here somewhere. They are small, so having more than 1 will not hurt anything.
Posted Feb 01, 2010 · 04:03 UTC#44
I originally posted in that thread. the license file in that thread is the same as the one in this thread. Ok maybe im missing something here, how many buildings should i be seeing? Im in atlanta right now and there may be about 10 buildings that show up, but i think those are the landmark buildings.
based on the these two threads it seems that it could be my sys.txt file or the color scheme.
Posted Feb 01, 2010 · 22:56 UTC#45
Simulate a route through the center of los angeles. There should be buildings everywhere.
Posted Feb 04, 2010 · 06:08 UTC#46
Is there any other sources for the updated maps? I downloaded all 16 files and got a CRC error message. After double checking the password I figure I must have a corrupted file. I am not waiting 45 seconds and typing a code for each downloaded file again. Comcast also has no news server, so I can't use the nzb file. (edit -- I did try downloading the part 1 file again (and from another source), but get the same error, so either the password is wrong or maybe a corrupt file has replicated through the file sharing sites??)
This forum is great and I really appreciate the effort put forth by those who contribute (thanks LTDan), but these download sites are retarded. I don't do that kind of stuff often enough to justify a membership, and since one such site I signed up for years ago kept charging my credit card for over a year with me calling them month after month to cancel, I just don't bother with them anymore.
Enough whinning, though, is there another source of the maps, or perhaps a torrent?
Alternatively, can I buy upgraded maps from IGO8 or Pioneer? I saw that Pioneer has updates, but since I did the 3.0 upgrade on my F900BT, would I have to order the maps for an X910BT?
Posted Feb 04, 2010 · 13:35 UTC#47
Dude i think this is the only way, I did see another post about navteq maps but i think you lose the highway signs functionality. Did you make sure the password was CAPS?
Posted Feb 04, 2010 · 15:39 UTC#48
You are a hero; it was the caps issue; it seemed like a password thing, can't believe I missed the "in all caps."
Posted Feb 10, 2010 · 23:03 UTC#49
Hi, i have the X910bt, i have made a backup of my maps and am ready to copy the new ones. Do the names of the files have to be the same? Because the ones that are on the x910bt right now are called, for example: USA_Indiana.fbl and the ones from the download are called, for example: USA_Indiana83TA_2009.06_090710.fbl
I just dont want to mess anything up
Oh yeah, before i forget, does anyone have the modified samantha tts files that dont make samantha sound so robotic?
Thanks,
Zach
Posted Feb 17, 2010 · 05:25 UTC#50
Thanks,
Zach
^^^ what he said
Page 2 of 4
