A blind guess.. But also make sure that you have at least one movie sync'ed via ITunes..... Otherwise, I don't believe that the Avic will even look at the video sides of things...<---could be very wrong...like I said, blind guess...
Jailbroken iPhone + TVOut
Yea you do have to have at least one vid on the ipod before the VIDEO button will let you touch it.
Has anyone tried this with the Sirius iphone app?
Any audio app will work for this. Jailbroken or not.
thx VB
have you tried this specific app on yours?
just curious as to how the sound quality will be...
No.
Startet up tvout.
Adjustet screen to landscape, startet up Rev for iphone Sweet
and soo easy to se the data running on the 7" screen
Haven't been around in a while but I just wanted to post that I've since switched to using Resupported which I believe allows output to both the iPhone screen and the Z (mirrored of course). Also TVOutTuner is great for adjusting the screen size/position.
Ive been playing around with this and I found that you do NOT have to sync a movie to your iDevice to have visuals on the Z. Simply connect iDevice, go into iPod settings on the Z and change control from navi to ipod. Getting ready to try Resupported so I dont have to use the touch marker (annoys da hell out of me).
Also Ive been using an app for iPhone\Windows called ORB which will basically turn your home PC into a Slingbox.
ah yes. I remember orb from way back about 5 or 6 years ago on my media pc. Another cool app to have on hand is Air Video which allows you to stream and convert video files live from your PC. I have over 500 movies and 12 TV show series on my media center. If I can successfully get this TV out thing to work I will pretty much have my entire TV/Movie collection right on my iphone which can be connected to the Z!!! OMG. I love new technology!
To make this work you must have the TVout on and connected with the pioneer ipod cable. On the AVIC screen put it on ipod them touch the little gear on the screen and change the setting on the lower left hand box from NAV control to Ipod control and go back to the ipod screen and you will be in TV out mode and your phone screen will display. To go back to the ipod control screen click the little gear again and change the lower left hand box back to NAV controls and got back to the previous screen and it will be ipod control not TV out
you're a few months late bro
Thanks though. I've since purchased a G37 which has the composite inputs in the center console so I'm good to go now! apps work perfectly with TVOUT coupled with TVOUT Tuner
This step is not necessary to get this to work. Just make sure your TVOUT extension is on and select VIDEO on the iPod source and open whatever video app you want. Everything will still need to be controlled from the phone however.
Hi guys,
forgive me i'm new at this.
so i followed the guides and i'm on an iphne4 with cydia. i got the tv out app and ran it on the z110bt (running 1001) it seemed to work well but since i did it my ipod function has gone down. it shows the ipod and all but no sounds comes out of it till i switch to the av1 which is where i set up the app. can anyone kindly tell me if there is a solution? otherwise i will delete the tvout app and see how that goes.
many thanks
Hi guys,
many thanks
Just a guess....pg 143 of z110 manual, "Change Control Mode" needs to be set to Navi for normal iPod functionality. If you are playing iPod apps, set it to iPod.
And, AV Source should be iPod.
