IDT skin#3 v1 12/30/2010 (download link updated)
By ill.die.trying · Mar 03, 2010in Completed Mods/Themes💬 35 posts👁️ 13,164 views
Page 1 of 2
Posted Mar 03, 2010 · 01:28 UTC#1
here's my skin#3
for more pictures you could also look here http://avic411.com/forum/viewtopic.php?f=34&t=28376&start=0#p195485
what's in it;
-av button hide/unhide (VR only works when av button is not hidden)
- phone shortcut on the main screen
-map changer option (extracted from GURJON half patch)
-fuel calculation (only when navigating) (extracted from GURJON half patch)
-created infoscreen, based on DIAFTA's split screen (only when navigating)
-includes shortcuts for POI, DELETE ROUTE, VOICE GUIDANCE MUTE, TRIPCOMPUTER and MAP
-onscreen trip computer can be accessed by pressing the time (with or without route)
-welcome greeting (credits to N-S-E-W)
-to change the welcome greeting go to the audio folder in your DATA.zip and change the !welcome.ogg to your selected tone, be sure to have rename it as !welcome
-screen off
-address shortcut button (onlongclick will go to history)
-poi shortcut button (onlongclick will go to poi search by location)
-navi setting button
-return home button
-route info button when with a route
-navigation guidance mute button
-delete route button
-simulation controls
-speedcam
-speedcam warning display option (FULL or SIMPLE)
-speedcam spoken alert
-speedcam spoken alert volume slider
-beep warning distance
-speedcam mute/hide
-changed route function lay out
-MSN button for MSN users, TMC button for TMC users
-multi-route
-trip computer
-tripcomputer onscreen by pressing the current speed (with or without route)
-road blocking
-manage screen
-snap to road option
-building setting
-plan mode screen
-multidraw on long click of multiplan button
-included in the download is a bunch of schemes, i edited the scheme to have different colors for the multidraw screen including the edited stock pioneer schemes
-if you want different sky on your nav just replace sky.bmp on GFX/DAY and GFX/NIGHT on the data.zip
-UK style speedlimit sign (using the EU file)
-signpost on/off setting
-added a ROAD SIGN settings page for speedlimit sign, sign post, turn restriction etc
-software bypass
-return button on plan mode screen onlongclick will return to map screen
-current speed on map screen
-on/off setting for current speed
-elevation sign on map screen
-on/off setting for elevation sign
-added lane guidance option
-on/off setting for lane guidance
-reduced the size of the signpost
-more visible route information
-added 2 more boxes for the displayed info instead of pressing it to toggle (all infos controlled in the displayed info setting)
-navigation cruise page when compass area is pressed (onrelease=simple and onlongclick=advanced) extracted from gj skin
-added a custom setting button on the navi setting screen
-added a navigation text color setting (for the streetnames, next streetname, distance etc, also controls the time)
-navigation progress bar,
-on/off setting for navigation progress bar
-currently this has the subaru impreza rally car as the default 3D car
to change the 3D arrow to a car model
download the 3DCars.rar file on the download link provided and extract it
and you have to edit the sys.txt
change the current values of this
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
to this
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
and add this part to the [3D] section
car_day=hot_rod_red.mdl
car_night=hot_rod_red.mdl
ghost_day=hot_rod_red.mdl
ghost_night=hot_rod_red.mdl
you now have to transfer the desired carmodel and tex file to the gfx folder in the data.zip and change the names of the above code to your selected car model name, i haven't tested every car model out as i already like the hot_rod car, but it's just a trial and error thing
for speed camera
you have to search for speed camera text file for your area,
there are 2 versions of this mod, 1 for standard (regular, MSN and TMC) and 1 for alternate (regular, MSN and TMC)
the reason i created two for each is because of the unit setting varying from different locations (setting a speed camera), so if the first one doesn't work for you then use the one with the alternate at the end of the filename
INSTALLATION: Please read carefully
1) first off this is not an auto installer, download your desired zip (regular or alternate)
2) extract files and transfer all files to a freshly formatted SD card (for F500 users, you have to edit the device type part first to reflect the device type of the F500 before transfering it to the SD)
3) this already has testmode file so no need to add anything else
4) insert SD to unit,
5) boot up unit
***if this is your first time,PLEASE BACK UP YOUR FILES
6) copy DATA.ZIP and SYS.TXT (from standard, MSN or EU folder),EXTENSION folder and DS-DIGI file to MYFLASHDISKAPL2IGO
7) go to MYFLASHDISKAPL2IGOCONTENT and create a new folder and name it as map_nt and copy basemap.fbl from map folder to map_nt folder, this is where you're going to place your navteq maps
:cool: to add a different scheme, add the contents of scheme folder to MYFLASHDISKAPL2IGOCONTENTSCHEME
**IT'S MANDATORY TO DELETE THE SAVE FILES, it's in My Flash DiskUSERUserDataiGosave, everything should be deleted
9) once done copying turn off the unit, remove sd card and then turn unit on,
NOTE to users, some users use gallons so here's instructions for it,
this is assuming that your in testmode
1) go to MYFLASHDISKAPL2IGOExtensionFuelcalc and delete the contents,
2) copy the contents of the zip to that folder,
3) DELETE THE SAVE FILES, it's in My Flash DiskUSERUserDataiGosave, everything should be deleted
for people who want to use custom branding.zip to delete kml.icon from data.zip (DATA.zipui_pioneericonspoikml.icon). (thanks to jezikk for pointing it out)
if you find any bugs please post em up so i could get it fixed
any comments, suggestions, requests are welcome, i will try my best to please everyone
any donations thru paypal are very much appreciated <!-- e --><a href="mailto:[email protected]">[email protected]</a><!-- e -->
DOWNLOAD LINK http://www.4shared.com/account/dir/8gU2eL5q/sharing.html?sId=SFq6GIOF8vMtDtea
Edited Dec 31, 2010 by ill.die.trying
Posted Mar 03, 2010 · 01:55 UTC#2
Looks great! Going to try this out tomorrow for sure!
Posted Mar 03, 2010 · 05:44 UTC#3
Awesome, will try it out if I can get my F90BT out of reboot loop. :(
Posted Mar 03, 2010 · 07:38 UTC#4
Got it working. Everything looks good, but is there a way to keep the navi settings button when there is a destination? It changes to mute/unmute button and I'd rather be able to go to navi settings to change voice volume if needed. Maybe on long hold, it could open up settings? Thanks.
Posted Mar 03, 2010 · 12:27 UTC#5
here's my skin#3
Hmmm, one thing that has me confused, why is there an info button in reg mode if it is only supposed to work in Nav mode. Does the split screen work in reg mode now? or is this just a button that is useless until you hit Nav mode
Posted Mar 03, 2010 · 15:00 UTC#6
what version igo are we using or what navtec maps do we use R1 orR3...thx
Posted Mar 03, 2010 · 16:43 UTC#7
it's just a dummy button when not navigating, split screen will only will only work when navigating
Posted Mar 03, 2010 · 16:44 UTC#8
8.3
Posted Mar 03, 2010 · 18:20 UTC#9
thx .... anyone know what path in the sys.txt to read maps off of SD card.
is it: 2=",map_nt,\Storage Card\iGo,,"
2=",map_nt,\Storage Card\iGO8,\ResidentFlash\iGO8,"
or if you can give me the steps to do it
I just have the maps , do I need DEM file or whole other apl2 folder??
Thanks going on a road trip today ....show off my NAV thanks to you guys.
Posted Mar 03, 2010 · 22:01 UTC#10
IDT, I have quick question how to add house numbers to the main view, while you are not in the navi mode.
I'd like to have it on the view like Your firs screen in this treat.
When I go to info screen (split screen) i see numbers but not on the other view.
Can you help me with it ???
Posted Mar 03, 2010 · 22:09 UTC#11
you could press the current street name area for the house numbers to show up
Posted Mar 03, 2010 · 22:22 UTC#12
Ok so maybe the sd card setup isn't ready....So how do I set my folders as far as Map ,Buildings , POI and DEM for Map changer . I remember making the map_nt folder... does all of it go in there ??? please let me know I am hitting the road in a couple hours and would to see it working...thanks
Posted Mar 03, 2010 · 22:32 UTC#13
you're asking a bit too much and for that i'll be charging you $$$$ :lol: , here's what you'll need,
hacked ezrider <---for the unit to accept different maps
newer maps <------search the thread for download links
building files <-----ussually bundled with map downloads
licenses <-----------search the forum for licenses
the unit has already poi and DEM files,
hacked exrider goes to myflashdisk\apl2\igo
maps goes to myflashdisk\apl2\iGO\content\map
buildings goes to myflashdisk\apl2\igo\content\buildings
license goes to myflashdisk\apl2\igo\content\license,
BE SURE YOU BAKC UP ALL YOUR FILES,
Posted Mar 03, 2010 · 23:00 UTC#14
Thanks for your time and check your email PP..., I am setting up the Map changer ....I got all the files (navtec)... so they go in the same folders as the stock maps dem etc....??? I was originally wanting to run it all off the sd card but I couldn't find any info for the right paths in sys.txt to do that ..not sure if I had to make folders and blah blah.... If I have the paths for the changer whether its SD card or avic flash ... I can prob figure it out. would rather have the right info then loading 2.0 back in it tonight.....lol
Posted Mar 03, 2010 · 23:04 UTC#15
thanks for the donation, i really appreciate it,
Posted Mar 04, 2010 · 06:49 UTC#16
Can you tell me how to make house number always on if i'm not in the navigation mode (&!has.route) ?
E.g. Now i have to press current street to show up house numbers and small house icon to hide.
After the modification I'd like to have house numbers switched on while not in navigation by default. And if I press small house it would be hiding.
Posted Mar 04, 2010 · 15:07 UTC#17
try this, copy this code and paste it in you navigatemap_800_480.ui under ui_NavigateMapButtons
;US
Posted Mar 05, 2010 · 00:35 UTC#18
Hey IDT
Great job.
I have one bug to report and I'm wondering if it's happening to others. While on the nav screen, voice prompt will not work. I press the big silver button and it mutes if music is playing for about a second, but then the music comes back on without letting me giving the unit a command.
Posted Mar 05, 2010 · 02:10 UTC#19
Hey IDT
Great job.
this is not a bug, if you'll check the features in page 1 it states there that for VR to work you have to press the av button first, ones the AV source button appears VR will work when the knob is pressed,
Posted Mar 05, 2010 · 06:54 UTC#20
;US
I put the code above + added to visiblemodel &!has.route and it's working quit well. However, in some places house numbers are not showing but when I click on the map (left and right side of the road) I see the correct numbers. Thx IDT.
Posted Mar 05, 2010 · 09:12 UTC#21
Bump, any tips on this guys?
Posted Mar 05, 2010 · 12:05 UTC#22
Hey IDT
Great job.
Ok, thanks IDT. I guess I overlooked that in the first post.
Posted Mar 06, 2010 · 22:45 UTC#23
IDT please help me undo an error that I made.
I setup the MAP_NT folder and put the basemap in just like the instructions stated. Everything was working great and I liked it.
Then I thought I would just take a look at these navtec maps, it said to let it restart and that is all it does now. It boots up to the big three Icons with the system starting up screen laid out across it and stays there for a few minutes, the it shut down and does the same stuck start up again & repeats.
Please help I do not really care about the navtec maps but I would like to have the regular parts working again.
Is there a start up file somewhere that needs to be edited to tell it to use the teleatlas maps?
I now know there are missing file but I just want to repair the startup
Posted Mar 06, 2010 · 23:59 UTC#24
i think the problem is you transferred the basemap.fbl fo the map_nt folder, the thing is you have to make a copy of the basemap file and put the copy to the navteq folder and nnot transfer it, i would suggest is to do that and delte the contents of the save folder, let me know how it goes
Posted Mar 07, 2010 · 16:54 UTC#25
Julius
Can you tell me how to get into the route plan mode please.Is this the screen which you can search,change route method(fast,short etc)in which the icons are down the LH side of the planning screen.thanks.
Page 1 of 2
