X920BT IS NOT COMPATIBLE WITH TESTMODE/MODS!!!
By VBLUE42 · Mar 04, 2010in Hacks/Mods💬 43 posts👁️ 34,044 views
Page 1 of 2
Posted Mar 04, 2010 · 21:14 UTC#1
Just to nip this in the bud before it gets started. The Z110/120BT runs completely different software then the previous X series. It will not run testmode and will not work with any software mods that are on this forum. There will be no hacks for this unit in the foreseeable future. If that ever changes it will be posted and stickied on this forum but likely will never happen.
MOD NOTE 11-24-2010: Recently a testmode file has materialized that does work on the 920/120BT units that will allow access to the file system of the unit. Unfortunately that is all this file does at this time. It does not offer a way to hack or mod any of the software in these units what so ever and there are no changes expected in the foreseeable future. If there are this thread will be updated. What that means is no UI hacks or mods, no software bypass, and no additional map or map upgrades are currently possible. Please do not apply the mentality that this will give you the same capabilities of the previous X and F series units.
MOD NOTE 04-19-2012: Per the request of another forum member I am updating the status of this thread. As reported on 11-24-2010 there is now acsess to testmode on all X920/930/940 and Z110/130/130/140 units. Unfortunately the mods that are available on all US F series units (F90BT/900/700) and X910/710 units is still not posible. What has changed is that with this testmode you can do a system backup and can now change the maps to a different country or update to newer maps. Its important to understand however that this is not 100% reliable and issues have been noted involving certain features that do not work properly after doing map change. There is still no indication that a UI have hack similar to what is happening with the previous F series/1st gen X series will ever progress beyond this point. When and if it does this thread will be updated.
Edited Apr 20, 2012 by VBLUE42
Posted Mar 05, 2010 · 18:24 UTC#2
yes, before - admin make big mistake, and no anybody help him.
need move X910BT, AVIC-X710BT model to F-series, or create new folder for x920 model :mrgreen:
anybody has link to X920 service manual or software update ? thanks.
Posted Mar 05, 2010 · 19:06 UTC#3
No X920BT software update. That model is still yet to be released.
Posted Mar 07, 2010 · 14:32 UTC#5
Until someone does something with this and hacks the unit this means nothing.
Posted Mar 26, 2010 · 12:01 UTC#6
Yes, thank you! I just mentioned this in the troubleshooting section not seeing someoen arleady posted it here. Why Pioneer thought they should keep the series name the same when it has nothing to do with it is very strange. Only thing that is the same is the chassis shape/size and the name pioneer.
Posted Mar 27, 2010 · 18:17 UTC#7
Yes, I have already mentioned this in a few posts earlier this year, as I had this confirmed from a Pioneer Engineer before the unit was released. The X920BT has the same OS as the Z110BT and will never be hackable. This is really unfortunate on Pioneers behalf because sales would boost dramatically if these units were capable of being modded. I go through hardware once a year because I get bored. I just purchased a new X910BT, only because it can be modded. I would have purchased a Z110, X920BT or even an Alpine 7" Nav if it could be modded, but they can't, so I traded my F700BT in for a X910BT. Am I happy, YOU BET!! because my modded X910BT looks better than anything on the market today, and trust me, I have looked!
Posted Mar 27, 2010 · 23:17 UTC#8
Thats exactly why I switched from the Z to the X910BT.
Posted Sep 02, 2010 · 00:25 UTC#9
I know this thread is kinda old, but I just purchased the X920BT and performed the "mute ground wire" hack and it unlocked perfectly.
Also, when doing this hack you have to remove one of the pins from the connector and move it over one slot. The pin was difficult to remove but I figured out a new approach to this. Instead of inserting a pin or staple into the end of the connector, I noticed that the connector has tabs on the outside which can be opened a little. So open them as far as possible without breaking anything, then insert the pin or staple into the SIDE of the connector where the mute pin/wire is and jiggle it while pulling the wire and it will pop out.
Other than that, it went well and I can ride in my van (in the passenger side of course) while watching movies and playing with navigation and all other features. Truly an awesome unit.
Posted Sep 02, 2010 · 02:11 UTC#10
Congratulations on your first post. You managed to tell us all something we all have known for well over a year now and that has been posted many times. You also managed to get off topic with this first post. :roll:
Edited Nov 12, 2010 by VBLUE42
Posted Nov 12, 2010 · 01:16 UTC#12
No on both questions.
Posted Nov 17, 2010 · 03:10 UTC#13
Why not, since it's the exact same software? even the upgrade files (2.003) is named Z110, could you please explain?
Posted Nov 17, 2010 · 04:25 UTC#14
Same software as what? Testmode is not compatible with any of the currently available units.
Posted Nov 18, 2010 · 15:09 UTC#15
To enter X920BT testmode:
Turn Power On
While holding home button press: rew, fast, rew, fast, rew, fast (or fast, rew, fast, rew, fast, rew, can't remember right now which one is first).
Screen will go black, so release the home button and wait.
Testmode will be on, with full file copy capabilities.
Tested on mine, works.
Now we just need to know which files to change.
Am I wrong VBLUE42?
Cheers!
Edited Nov 18, 2010 by cassioac
Posted Nov 19, 2010 · 23:46 UTC#16
hello! this is the test mode that worked in my X920BT!
http://avic411.com/i...attach_id=13877
Now I have to figure out where are the files and folders of maps!
Tanks
Posted Nov 20, 2010 · 00:06 UTC#17
your link doesnt work...
Tanks
Posted Nov 20, 2010 · 02:14 UTC#18
Ok it does appear this is totally legit and I have tested the file myself on the 120 and it does give file access. Unfortunately we have had this access to the file system of these units before and it still has not yielded a way to mod the software of the units. This member has claimed however that someone from Brazil was able to use this file to install Brazilian maps to his unit which up until this point at least was not possible. Stay tuned. :smile:
Posted Dec 09, 2010 · 17:54 UTC#19
Guys, I have the X920BT in my Amazon cart... Just looking for a feedback to place the order! What do you guys think? Once it could enter the Test Mode, do you think it will be possible to install foreing (Brazil) maps on this unit? SHould I buy the x910BT instead and play safe???
Looking forward feedback...
Posted Dec 09, 2010 · 18:47 UTC#20
I bought this unit, and also live in Brasil (São Paulo). Now I'm stuck without any maps, so don't buy the X920BT or you will end up like me. Get the X910BT.
Abraço!
Cassio
Posted Dec 09, 2010 · 18:53 UTC#21
Abraço!
Cassio
Oh, my... I was afraid of hearing that... :-( That SUX! :-( ... Entering the Test Mode didn't help? Do you think that it might be possible in a near future? And what does the X910BT misses? Which features we have on 920BT that we don't have on 910BT? I'm reading and found a bunch already:
  • No MusicSphere
  • No Pandora Link
  • No video playback on SD card, only on CD/DVD
  • 5.8" against 6.1" - This is not a deal breaker, tough
Could you guys list some more missing features? As it was hacked already, it might be possible to get some of those features on a hacked X910BT, wouldn't be?
thx... (I'm SAID! :-( )
Posted Dec 09, 2010 · 22:20 UTC#22
Hi all!
I've copied all the X920BT(probably the same of Z110) system files through testmode, and made it available in this link:
http://www.4shared.com/file/A9KS6rpy/X920BT.html
If would be great if somebody could try to mod it to load other country maps.
Cheers!
Posted Dec 10, 2010 · 01:57 UTC#23
Hi all!
Cheers!
I'm downloading it already... :-) What did you try already?
Posted Dec 10, 2010 · 02:51 UTC#24
Downloading that file will do nothing for you. These units are still not hackable so you are wasting your time.
Posted Dec 10, 2010 · 03:19 UTC#25
Well, just to take a look... So I might buy the X910BT. Is it much slower than the X920BT? Or just the boot time is slower?
Page 1 of 2
