Cracking the Z110/20BT: F10/F20BT included? Region changing?
By ShortFuse · Sep 04, 2010in Hacks/Mods💬 290 posts👁️ 108,600 views
Page 1 of 12
Posted Sep 04, 2010 · 23:22 UTC#1
MOD COMMENT: I just wanted to offer a huge congrats to valued forum member ShortFuse. Over the last several months there have been numerous members claim they could do what he has done only to never be seen again. This kind of carrot dangling does no one any good at all and I honestly had no faith in this effort. I am glad to say I was wrong for my lack of faith in this instance. Now, for the first time in over a year, it now appears we may actually be able to offer UI hacks for the current crop of Pioneer navis do to his contributions. We are making no promises, but this is a big step in the right direction. I look forward to where this goes from here.
Donate if you like:
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7ELH2CPLUZLQY
Phase 1 - Crack upgrade file - COMPLETE
Download the v1.001 update from Pioneer.
Replace AVICZ110EU090APL.VER and AVICZ110APLRenewalIFLib.dll with the files attached.
Copy the AVICZ110 folder with the patched files to the root of an SD card.
Insert the SD to your Z110BT and it should start updating automatically.
You are now running the patched version. When you try to run a map upgrade insert anything for the password. If it's not taking it, try filling the input box with characters (no numbers).
It's PERFECTLY SAFE to upgrade the 2.003. Looking at that, I'm 99% sure that the next update (2011 map if it exists) will be cracked with the same method. Don't ask me about 2012.
There are reports of this working for the EU versions. I wouldn't be surprised. The APL folder (NAND1) for the US and EU version are COMPLETELY IDENTICAL. F10BT's 2.003 update is identical to Z120's 2.003 update. What makes them work different are the contents on NAND2 (the 4GB). This also means that any APL patches for the US versions will be cross compatible with other regions. I wouldn't be surprised if the F10BT is just a Z110BT upgraded to 1.001 (can any F10BT users check this?)
This might also mean, you can convert from any 1.x region to any other 2.x region (ie: 1.x US to 2.x EU). I believe that Pioneer runs a region check in the application. I incorrectly called this a "version check" because the subroutine is called GetVersion(void). I did bypass this function, which means I probably bypassed the region check as an added bonus to this crack.
PLEASE PLEASE PLEASE note: There is no downgrade ability at the moment. Don't just try to convert your 1.x to a different region for the fun of it.
Reference Posts:
<!-- l --><a class="postlink-local" href="http://avic411.com/forum/viewtopic.php?f=57&t=34478&p=229354#p229354">viewtopic.php?f=57&t=34478&p=229354#p229354</a><!-- l -->
Phase 2 - Mods
Step 1: Make recovery bootloader
Before we start modding things we need a recovery options. It's far too easy to brick the device right now. I almost bricked it when I did the upgrade crack. We need to have an option to force recovery. This will likely be a button press sequence while the device boots (like holding Home and Mode while booting).
The target files are the PRG files in BOOT and PLATFORM. Once we decode that, we can start playing around with it.
The file makes reference to the WINCE kernel and WinCE dll files, so I wouldn't be surprised if this like a PPC ROM file.
After some more research, it seems we can flash via recovery by access Option #3 from the Test Mode menu.
Misc
NAND2 Image from 2010 Firmware update:
PARTCODE.TXT
RELEASE.TXT
NDATA�0ALLDATA.LFT
NDATA�0DTR_H.DB
NDATA�0ILUSTMAP.LFT
NDATA�0INDEXDAT.DB
NDATA�0LANDMARK.LFT
NDATA�0NDB_ALLDATA.VER
NDATA�0ShortCutGenre.txt
NDATA�0ZonelistOnFlash.txt
NDATA�0IDXGENRE_H.DB
NDATA�0IDXPOI.LDB
NDATA�0MAP2DCITY.LFT
NDATA�0MAPLINKCOND.LFT
NDATA�0MAPPARCEL.LFT
NDATA�0MAPPARCEL00.LFT
NDATA�0MAPRDSTMC.LFT
NDATA�0MAPREGION.LFT
NDATA�2HN02.LFT
NDATA�2SHLDDC02.LFT
NDATA�2STPTDC02.LFT
NDATA�2STRTDC02.LFT
NDATA�2IDXINDEX02.LDB
NDATA�2IDXPOISR02.LDB
NDATA�2IDXSCSR02.LFT
NDATA�2MAPPARCEL02.LFT
NDATA�3HN03.LFT
NDATA�3SHLDDC03.LFT
NDATA�3STPTDC03.LFT
NDATA�3STRTDC03.LFT
NDATA�3IDXINDEX03.LDB
NDATA�3IDXPOISR03.LDB
NDATA�3IDXSCSR03.LFT
NDATA�3MAPPARCEL03.LFT
NDATA�4HN04.LFT
NDATA�4SHLDDC04.LFT
NDATA�4STPTDC04.LFT
NDATA�4STRTDC04.LFT
NDATA�4IDXINDEX04.LDB
NDATA�4IDXPOISR04.LDB
NDATA�4IDXSCSR04.LFT
NDATA�4MAP2DCITY04.LFT
NDATA�4MAPPARCEL04.LFT
NDATA�5HN05.LFT
NDATA�5SHLDDC05.LFT
NDATA�5STPTDC05.LFT
NDATA�5STRTDC05.LFT
NDATA�5IDXINDEX05.LDB
NDATA�5IDXPOISR05.LDB
NDATA�5IDXSCSR05.LFT
NDATA�5MAPPARCEL05.LFT
NDATA�6HN06.LFT
NDATA�6SHLDDC06.LFT
NDATA�6STPTDC06.LFT
NDATA�6STRTDC06.LFT
NDATA�6IDXINDEX06.LDB
NDATA�6IDXPOISR06.LDB
NDATA�6IDXSCSR06.LFT
NDATA�6MAP2DCITY06.LFT
NDATA�6MAPPARCEL06.LFT
NDATA�7HN07.LFT
NDATA�7IDX
NDATA�7MAP
NDATA�7SHLDDC07.LFT
NDATA�7STPTDC07.LFT
NDATA�7STRTDC07.LFT
NDATA�7IDXINDEX07.LDB
NDATA�7IDXPOISR07.LDB
NDATA�7IDXSCSR07.LFT
NDATA�7MAP2DCITY07.LFT
NDATA�7MAPPARCEL07.LFT
NDATA�8HN08.LFT
NDATA�8SHLDDC08.LFT
NDATA�8STPTDC08.LFT
NDATA�8STRTDC08.LFT
NDATA�8IDXINDEX08.LDB
NDATA�8IDXPOISR08.LDB
NDATA�8IDXSCSR08.LFT
NDATA�8MAPPARCEL08.LFT
NDATA�9HN09.LFT
NDATA�9SHLDDC09.LFT
NDATA�9STPTDC09.LFT
NDATA�9STRTDC09.LFT
NDATA�9IDXINDEX09.LDB
NDATA�9IDXPOISR09.LDB
NDATA�9IDXSCSR09.LFT
NDATA�9MAPPARCEL09.LFT
NDATA�AHN0A.LFT
NDATA�ASHLDDC0A.LFT
NDATA�ASTPTDC0A.LFT
NDATA�ASTRTDC0A.LFT
NDATA�AIDXINDEX0A.LDB
NDATA�AIDXPOISR0A.LDB
NDATA�AIDXSCSR0A.LFT
NDATA�AMAP2DCITY0A.LFT
NDATA�AMAPPARCEL0A.LFT
NDATA�BHN0B.LFT
NDATA�BSHLDDC0B.LFT
NDATA�BSTPTDC0B.LFT
NDATA�BSTRTDC0B.LFT
NDATA�BIDXINDEX0B.LDB
NDATA�BIDXPOISR0B.LDB
NDATA�BIDXSCSR0B.LFT
NDATA�BMAP2DCITY0B.LFT
NDATA�BMAPPARCEL0B.LFT
NDATA�CHN0C.LFT
NDATA�CSHLDDC0C.LFT
NDATA�CSTPTDC0C.LFT
NDATA�CSTRTDC0C.LFT
NDATA�CIDXINDEX0C.LDB
NDATA�CIDXPOISR0C.LDB
NDATA�CIDXSCSR0C.LFT
NDATA�CMAP2DCITY0C.LFT
NDATA�CMAPPARCEL0C.LFT
NDATA�DHN0D.LFT
NDATA�DSHLDDC0D.LFT
NDATA�DSTPTDC0D.LFT
NDATA�DSTRTDC0D.LFT
NDATA�DIDXINDEX0D.LDB
NDATA�DIDXPOISR0D.LDB
NDATA�DIDXSCSR0D.LFT
NDATA�DMAP2DCITY0D.LFT
NDATA�DMAPPARCEL0D.LFT
NDATA�EHN0E.LFT
NDATA�ESHLDDC0E.LFT
NDATA�ESTPTDC0E.LFT
NDATA�ESTRTDC0E.LFT
NDATA�EIDXINDEX0E.LDB
NDATA�EIDXPOISR0E.LDB
NDATA�EIDXSCSR0E.LFT
NDATA�EMAPPARCEL0E.LFT
NDATA�FHN0F.LFT
NDATA�FSHLDDC0F.LFT
NDATA�FSTPTDC0F.LFT
NDATA�FSTRTDC0F.LFT
NDATA�FIDXINDEX0F.LDB
NDATA�FIDXPOISR0F.LDB
NDATA�FIDXSCSR0F.LFT
NDATA�FMAP2DCITY0F.LFT
NDATA�FMAPPARCEL0F.LFT
NDATA10HN10.LFT
NDATA10SHLDDC10.LFT
NDATA10STPTDC10.LFT
NDATA10STRTDC10.LFT
NDATA10IDXINDEX10.LDB
NDATA10IDXPOISR10.LDB
NDATA10IDXSCSR10.LFT
NDATA10MAP2DCITY10.LFT
NDATA10MAPPARCEL10.LFT
NDATA11HN11.LFT
NDATA11SHLDDC11.LFT
NDATA11STPTDC11.LFT
NDATA11STRTDC11.LFT
NDATA11IDXINDEX11.LDB
NDATA11IDXPOISR11.LDB
NDATA11IDXSCSR11.LFT
NDATA11MAP2DCITY11.LFT
NDATA11MAPPARCEL11.LFT
NDATA12HN12.LFT
NDATA12SHLDDC12.LFT
NDATA12STPTDC12.LFT
NDATA12STRTDC12.LFT
NDATA12IDXINDEX12.LDB
NDATA12IDXPOISR12.LDB
NDATA12IDXSCSR12.LFT
NDATA12MAP2DCITY12.LFT
NDATA12MAPPARCEL12.LFT
NDATA13HN13.LFT
NDATA13SHLDDC13.LFT
NDATA13STPTDC13.LFT
NDATA13STRTDC13.LFT
NDATA13IDXINDEX13.LDB
NDATA13IDXPOISR13.LDB
NDATA13IDXSCSR13.LFT
NDATA13MAP2DCITY13.LFT
NDATA13MAPPARCEL13.LFT
NDATA14HN14.LFT
NDATA14SHLDDC14.LFT
NDATA14STPTDC14.LFT
NDATA14STRTDC14.LFT
NDATA14IDXINDEX14.LDB
NDATA14IDXPOISR14.LDB
NDATA14IDXSCSR14.LFT
NDATA14MAP2DCITY14.LFT
NDATA14MAPPARCEL14.LFT
NDATA15HN15.LFT
NDATA15SHLDDC15.LFT
NDATA15STPTDC15.LFT
NDATA15STRTDC15.LFT
NDATA15IDXINDEX15.LDB
NDATA15IDXPOISR15.LDB
NDATA15IDXSCSR15.LFT
NDATA15MAPPARCEL15.LFT
NDATA16HN16.LFT
NDATA16SHLDDC16.LFT
NDATA16STPTDC16.LFT
NDATA16STRTDC16.LFT
NDATA16IDXINDEX16.LDB
NDATA16IDXPOISR16.LDB
NDATA16IDXSCSR16.LFT
NDATA16MAP2DCITY16.LFT
NDATA16MAPPARCEL16.LFT
NDATA17HN17.LFT
NDATA17SHLDDC17.LFT
NDATA17STPTDC17.LFT
NDATA17STRTDC17.LFT
NDATA17IDXINDEX17.LDB
NDATA17IDXPOISR17.LDB
NDATA17IDXSCSR17.LFT
NDATA17MAP2DCITY17.LFT
NDATA17MAPPARCEL17.LFT
NDATA18HN18.LFT
NDATA18SHLDDC18.LFT
NDATA18STPTDC18.LFT
NDATA18STRTDC18.LFT
NDATA18IDXINDEX18.LDB
NDATA18IDXPOISR18.LDB
NDATA18IDXSCSR18.LFT
NDATA18MAP2DCITY18.LFT
NDATA18MAPPARCEL18.LFT
NDATA19HN19.LFT
NDATA19SHLDDC19.LFT
NDATA19STPTDC19.LFT
NDATA19STRTDC19.LFT
NDATA19IDXINDEX19.LDB
NDATA19IDXPOISR19.LDB
NDATA19IDXSCSR19.LFT
NDATA19MAP2DCITY19.LFT
NDATA19MAPPARCEL19.LFT
NDATA1AHN1A.LFT
NDATA1ASHLDDC1A.LFT
NDATA1ASTPTDC1A.LFT
NDATA1ASTRTDC1A.LFT
NDATA1AIDXINDEX1A.LDB
NDATA1AIDXPOISR1A.LDB
NDATA1AIDXSCSR1A.LFT
NDATA1AMAPPARCEL1A.LFT
NDATA1BHN1B.LFT
NDATA1BSHLDDC1B.LFT
NDATA1BSTPTDC1B.LFT
NDATA1BSTRTDC1B.LFT
NDATA1BIDXINDEX1B.LDB
NDATA1BIDXPOISR1B.LDB
NDATA1BIDXSCSR1B.LFT
NDATA1BMAP2DCITY1B.LFT
NDATA1BMAPPARCEL1B.LFT
NDATA1CHN1C.LFT
NDATA1CSHLDDC1C.LFT
NDATA1CSTPTDC1C.LFT
NDATA1CSTRTDC1C.LFT
NDATA1CIDXINDEX1C.LDB
NDATA1CIDXPOISR1C.LDB
NDATA1CIDXSCSR1C.LFT
NDATA1CMAPPARCEL1C.LFT
NDATA1DHN1D.LFT
NDATA1DSHLDDC1D.LFT
NDATA1DSTPTDC1D.LFT
NDATA1DSTRTDC1D.LFT
NDATA1DIDXINDEX1D.LDB
NDATA1DIDXPOISR1D.LDB
NDATA1DIDXSCSR1D.LFT
NDATA1DMAP2DCITY1D.LFT
NDATA1DMAPPARCEL1D.LFT
NDATA1EHN1E.LFT
NDATA1ESHLDDC1E.LFT
NDATA1ESTPTDC1E.LFT
NDATA1ESTRTDC1E.LFT
NDATA1EIDXINDEX1E.LDB
NDATA1EIDXPOISR1E.LDB
NDATA1EIDXSCSR1E.LFT
NDATA1EMAP2DCITY1E.LFT
NDATA1EMAPPARCEL1E.LFT
NDATA1FHN1F.LFT
NDATA1FSHLDDC1F.LFT
NDATA1FSTPTDC1F.LFT
NDATA1FSTRTDC1F.LFT
NDATA1FIDXINDEX1F.LDB
NDATA1FIDXPOISR1F.LDB
NDATA1FIDXSCSR1F.LFT
NDATA1FMAPPARCEL1F.LFT
NDATA20HN20.LFT
NDATA20SHLDDC20.LFT
NDATA20STPTDC20.LFT
NDATA20STRTDC20.LFT
NDATA20IDXINDEX20.LDB
NDATA20IDXPOISR20.LDB
NDATA20IDXSCSR20.LFT
NDATA20MAP2DCITY20.LFT
NDATA20MAPPARCEL20.LFT
NDATA21HN21.LFT
NDATA21SHLDDC21.LFT
NDATA21STPTDC21.LFT
NDATA21STRTDC21.LFT
NDATA21IDXINDEX21.LDB
NDATA21IDXPOISR21.LDB
NDATA21IDXSCSR21.LFT
NDATA21MAP2DCITY21.LFT
NDATA21MAPPARCEL21.LFT
NDATA22HN22.LFT
NDATA22SHLDDC22.LFT
NDATA22STPTDC22.LFT
NDATA22STRTDC22.LFT
NDATA22IDXINDEX22.LDB
NDATA22IDXPOISR22.LDB
NDATA22IDXSCSR22.LFT
NDATA22MAP2DCITY22.LFT
NDATA22MAPPARCEL22.LFT
NDATA23HN23.LFT
NDATA23SHLDDC23.LFT
NDATA23STPTDC23.LFT
NDATA23STRTDC23.LFT
NDATA23IDXINDEX23.LDB
NDATA23IDXPOISR23.LDB
NDATA23IDXSCSR23.LFT
NDATA23MAP2DCITY23.LFT
NDATA23MAPPARCEL23.LFT
NDATA24HN24.LFT
NDATA24SHLDDC24.LFT
NDATA24STPTDC24.LFT
NDATA24STRTDC24.LFT
NDATA24IDXINDEX24.LDB
NDATA24IDXPOISR24.LDB
NDATA24IDXSCSR24.LFT
NDATA24MAPPARCEL24.LFT
NDATA25HN25.LFT
NDATA25SHLDDC25.LFT
NDATA25STPTDC25.LFT
NDATA25STRTDC25.LFT
NDATA25IDXINDEX25.LDB
NDATA25IDXPOISR25.LDB
NDATA25IDXSCSR25.LFT
NDATA25MAP2DCITY25.LFT
NDATA25MAPPARCEL25.LFT
NDATA26HN26.LFT
NDATA26SHLDDC26.LFT
NDATA26STPTDC26.LFT
NDATA26STRTDC26.LFT
NDATA26IDXINDEX26.LDB
NDATA26IDXPOISR26.LDB
NDATA26IDXSCSR26.LFT
NDATA26MAP2DCITY26.LFT
NDATA26MAPPARCEL26.LFT
NDATA27HN27.LFT
NDATA27SHLDDC27.LFT
NDATA27STPTDC27.LFT
NDATA27STRTDC27.LFT
NDATA27IDXINDEX27.LDB
NDATA27IDXPOISR27.LDB
NDATA27IDXSCSR27.LFT
NDATA27MAP2DCITY27.LFT
NDATA27MAPPARCEL27.LFT
NDATA28HN28.LFT
NDATA28SHLDDC28.LFT
NDATA28STPTDC28.LFT
NDATA28STRTDC28.LFT
NDATA28IDXINDEX28.LDB
NDATA28IDXPOISR28.LDB
NDATA28IDXSCSR28.LFT
NDATA28MAP2DCITY28.LFT
NDATA28MAPPARCEL28.LFT
NDATA29HN29.LFT
NDATA29SHLDDC29.LFT
NDATA29STPTDC29.LFT
NDATA29STRTDC29.LFT
NDATA29IDXINDEX29.LDB
NDATA29IDXPOISR29.LDB
NDATA29IDXSCSR29.LFT
NDATA29MAPPARCEL29.LFT
NDATA2AHN2A.LFT
NDATA2ASHLDDC2A.LFT
NDATA2ASTPTDC2A.LFT
NDATA2ASTRTDC2A.LFT
NDATA2AIDXINDEX2A.LDB
NDATA2AIDXPOISR2A.LDB
NDATA2AIDXSCSR2A.LFT
NDATA2AMAPPARCEL2A.LFT
NDATA2BHN2B.LFT
NDATA2BSHLDDC2B.LFT
NDATA2BSTPTDC2B.LFT
NDATA2BSTRTDC2B.LFT
NDATA2BIDXINDEX2B.LDB
NDATA2BIDXPOISR2B.LDB
NDATA2BIDXSCSR2B.LFT
NDATA2BMAP2DCITY2B.LFT
NDATA2BMAPPARCEL2B.LFT
NDATA2CHN2C.LFT
NDATA2CSHLDDC2C.LFT
NDATA2CSTPTDC2C.LFT
NDATA2CSTRTDC2C.LFT
NDATA2CIDXINDEX2C.LDB
NDATA2CIDXPOISR2C.LDB
NDATA2CIDXSCSR2C.LFT
NDATA2CMAPPARCEL2C.LFT
NDATA2DHN2D.LFT
NDATA2DSHLDDC2D.LFT
NDATA2DSTPTDC2D.LFT
NDATA2DSTRTDC2D.LFT
NDATA2DIDXINDEX2D.LDB
NDATA2DIDXPOISR2D.LDB
NDATA2DIDXSCSR2D.LFT
NDATA2DMAP2DCITY2D.LFT
NDATA2DMAPPARCEL2D.LFT
NDATA2EHN2E.LFT
NDATA2ESHLDDC2E.LFT
NDATA2ESTPTDC2E.LFT
NDATA2ESTRTDC2E.LFT
NDATA2EIDXINDEX2E.LDB
NDATA2EIDXPOISR2E.LDB
NDATA2EIDXSCSR2E.LFT
NDATA2EMAP2DCITY2E.LFT
NDATA2EMAPPARCEL2E.LFT
NDATA2FHN2F.LFT
NDATA2FSHLDDC2F.LFT
NDATA2FSTPTDC2F.LFT
NDATA2FSTRTDC2F.LFT
NDATA2FIDXINDEX2F.LDB
NDATA2FIDXPOISR2F.LDB
NDATA2FIDXSCSR2F.LFT
NDATA2FMAP2DCITY2F.LFT
NDATA2FMAPPARCEL2F.LFT
NDATA30HN30.LFT
NDATA30SHLDDC30.LFT
NDATA30STPTDC30.LFT
NDATA30STRTDC30.LFT
NDATA30IDXINDEX30.LDB
NDATA30IDXPOISR30.LDB
NDATA30IDXSCSR30.LFT
NDATA30MAPPARCEL30.LFT
NDATA31HN31.LFT
NDATA31SHLDDC31.LFT
NDATA31STPTDC31.LFT
NDATA31STRTDC31.LFT
NDATA31IDXINDEX31.LDB
NDATA31IDXPOISR31.LDB
NDATA31IDXSCSR31.LFT
NDATA31MAP2DCITY31.LFT
NDATA31MAPPARCEL31.LFT
NDATA33HN33.LFT
NDATA33SHLDDC33.LFT
NDATA33STPTDC33.LFT
NDATA33STRTDC33.LFT
NDATA33IDXINDEX33.LDB
NDATA33IDXPOISR33.LDB
NDATA33IDXSCSR33.LFT
NDATA33MAP2DCITY33.LFT
NDATA33MAPPARCEL33.LFT
NDATA34HN34.LFT
NDATA34SHLDDC34.LFT
NDATA34STPTDC34.LFT
NDATA34STRTDC34.LFT
NDATA34IDXINDEX34.LDB
NDATA34IDXPOISR34.LDB
NDATA34IDXSCSR34.LFT
NDATA34MAPPARCEL34.LFT
NDATA35HN35.LFT
NDATA35SHLDDC35.LFT
NDATA35STPTDC35.LFT
NDATA35STRTDC35.LFT
NDATA35IDXINDEX35.LDB
NDATA35IDXPOISR35.LDB
NDATA35IDXSCSR35.LFT
NDATA35MAP2DCITY35.LFT
NDATA35MAPPARCEL35.LFT
NDATA36HN36.LFT
NDATA36SHLDDC36.LFT
NDATA36STPTDC36.LFT
NDATA36STRTDC36.LFT
NDATA36IDXINDEX36.LDB
NDATA36IDXPOISR36.LDB
NDATA36IDXSCSR36.LFT
NDATA36MAPPARCEL36.LFT
NDATA42HN42.LFT
NDATA42SHLDDC42.LFT
NDATA42STPTDC42.LFT
NDATA42STRTDC42.LFT
NDATA42IDXINDEX42.LDB
NDATA42IDXPOISR42.LDB
NDATA42IDXSCSR42.LFT
NDATA42MAP2DCITY42.LFT
NDATA42MAPPARCEL42.LFT
NDATA43HN43.LFT
NDATA43SHLDDC43.LFT
NDATA43STPTDC43.LFT
NDATA43STRTDC43.LFT
NDATA43IDXINDEX43.LDB
NDATA43IDXPOISR43.LDB
NDATA43IDXSCSR43.LFT
NDATA43MAP2DCITY43.LFT
NDATA43MAPPARCEL43.LFT
NDATA44HN44.LFT
NDATA44SHLDDC44.LFT
NDATA44STPTDC44.LFT
NDATA44STRTDC44.LFT
NDATA44IDXINDEX44.LDB
NDATA44IDXPOISR44.LDB
NDATA44IDXSCSR44.LFT
NDATA44MAPPARCEL44.LFT
NDATA45HN45.LFT
NDATA45SHLDDC45.LFT
NDATA45STPTDC45.LFT
NDATA45STRTDC45.LFT
NDATA45IDXINDEX45.LDB
NDATA45IDXPOISR45.LDB
NDATA45IDXSCSR45.LFT
NDATA45MAPPARCEL45.LFT
NDATA46HN46.LFT
NDATA46SHLDDC46.LFT
NDATA46STPTDC46.LFT
NDATA46STRTDC46.LFT
NDATA46IDXINDEX46.LDB
NDATA46IDXPOISR46.LDB
NDATA46IDXSCSR46.LFT
NDATA46MAPPARCEL46.LFT
NDATA47HN47.LFT
NDATA47SHLDDC47.LFT
NDATA47STPTDC47.LFT
NDATA47STRTDC47.LFT
NDATA47IDXINDEX47.LDB
NDATA47IDXPOISR47.LDB
NDATA47IDXSCSR47.LFT
NDATA47MAPPARCEL47.LFT
NDATA48HN48.LFT
NDATA48SHLDDC48.LFT
NDATA48STPTDC48.LFT
NDATA48STRTDC48.LFT
NDATA48IDXINDEX48.LDB
NDATA48IDXPOISR48.LDB
NDATA48IDXSCSR48.LFT
NDATA48MAPPARCEL48.LFT
NDATA49HN49.LFT
NDATA49STRTDC49.LFT
NDATA49IDXINDEX49.LDB
NDATA49IDXPOISR49.LDB
NDATA49IDXSCSR49.LFT
NDATA49MAPPARCEL49.LFT
NDATA4AHN4A.LFT
NDATA4ASHLDDC4A.LFT
NDATA4ASTPTDC4A.LFT
NDATA4ASTRTDC4A.LFT
NDATA4AIDXINDEX4A.LDB
NDATA4AIDXPOISR4A.LDB
NDATA4AIDXSCSR4A.LFT
NDATA4AMAP2DCITY4A.LFT
NDATA4AMAPPARCEL4A.LFT
NDATA4BHN4B.LFT
NDATA4BSHLDDC4B.LFT
NDATA4BSTPTDC4B.LFT
NDATA4BSTRTDC4B.LFT
NDATA4BIDXINDEX4B.LDB
NDATA4BIDXPOISR4B.LDB
NDATA4BIDXSCSR4B.LFT
NDATA4BMAPPARCEL4B.LFT
NDATA4CHN4C.LFT
NDATA4CSHLDDC4C.LFT
NDATA4CSTPTDC4C.LFT
NDATA4CSTRTDC4C.LFT
NDATA4CIDXINDEX4C.LDB
NDATA4CIDXPOISR4C.LDB
NDATA4CIDXSCSR4C.LFT
NDATA4CMAP2DCITY4C.LFT
NDATA4CMAPPARCEL4C.LFT
NDATA4DHN4D.LFT
NDATA4DSHLDDC4D.LFT
NDATA4DSTPTDC4D.LFT
NDATA4DSTRTDC4D.LFT
NDATA4DIDXINDEX4D.LDB
NDATA4DIDXPOISR4D.LDB
NDATA4DIDXSCSR4D.LFT
NDATA4DMAPPARCEL4D.LFT
NDATA4EHN4E.LFT
NDATA4ESHLDDC4E.LFT
NDATA4ESTPTDC4E.LFT
NDATA4ESTRTDC4E.LFT
NDATA4EIDXINDEX4E.LDB
NDATA4EIDXPOISR4E.LDB
NDATA4EIDXSCSR4E.LFT
NDATA4EMAPPARCEL4E.LFT
NDATAAVXMDATIMAGETBL.DAT
NDATAAVXMDATVERSION.DAT
NDATABTBTDEFAULT.DAT
NDATAFEMAPPARCELFE.LFT
NDATAINITDATAUSERRWVBTVERSION.TXT
NDATAINITDATAUSERRWVBTENEN_USHFD_Dynamic.fsm
NDATAINITDATAUSERRWVBTENEN_USHFD_Dynamic.fsmb
NDATAINITDATAUSERRWVBTENEN_USMusicCatalog.db
NDATAINITDATAUSERRWVBTENEN_USMusic_Dynamic.fsm
NDATAINITDATAUSERRWVBTENEN_USMusic_Dynamic.fsmb
NDATAINITDATAUSERRWVBTENEN_USVBAgent.db
NDATAINITDATAUSERRWVBTENEN_USVBSystem.db
NDATAINITDATAUSERRWVBTENEN_USVBTLexDynamic.dsu
NDATAINITDATAUSERRWVBTENEN_USVBT_Grammar.fsm
NDATAINITDATAUSERRWVBTENEN_USVBT_Grammar.fsmb
NDATAL3DDAY.CTL
NDATAL3DDAY.L3D
NDATAL3DDAY.LST
NDATAL3DDRV.TBL
NDATAL3DDRV.TXT
NDATAL3DNIGHT.CTL
NDATAL3DNIGHT.L3D
NDATAL3DNIGHT.LST
NDATASDUSBFILTER.FLR
NDATASDUSBMMPCONF.DAT
NDATASOUNDLOPEDATA.DAT
NDATASOUNDUC090SND.ENU
NDATASOUNDUC090SND.FRE
NDATASOUNDUC090SND.SPA
NDATASOUNDUC090TTS.ENU
NDATASOUNDUC090TTS.FRE
NDATASOUNDUC090TTS.SPA
NDATAsymbolSL_GP_MAPOVER.symb
NDATAsymbolSL_GP_TEXBD.symb
NDATAsymbolSL_GP_TEXBN.symb
NDATAsymbolSL_GP_TEXRD.symb
NDATAsymbolSL_GP_TEXRN.symb
NDATATELGOOG411.DAT
NDATATTSDataPP.DAT
NDATATTSDataENUdepes_enu.dat
NDATATTSDataENUdepes_enu_samantha.dat
NDATATTSDataENUphonmap_enu_samantha.dat
NDATATTSDataENUsynth_samantha_dri40_155mrf22_270_06.dat
NDATATTSDataENUsysdct_enu_cfg2.dat
NDATATTSDataENUtokentn_enu.dat
NDATATTSDataENUuselect_samantha_dri40.dat
NDATATTSDataENUvauto_pipeline_enu_samantha_22_dri40_155mrf22.hdr
NDATATTSDataFRFdepes_frf.dat
NDATATTSDataFRFdepes_frf_virginie.dat
NDATATTSDataFRFphonmap_frf_virginie.dat
NDATATTSDataFRFsynth_virginie_dri40_155mrf22_270_06.dat
NDATATTSDataFRFsysdct_frf_cfg1.dat
NDATATTSDataFRFtokentn_frf.dat
NDATATTSDataFRFuselect_virginie_dri40.dat
NDATATTSDataFRFvauto_pipeline_frf_virginie_22_dri40_155mrf22.hdr
NDATATTSDataSPEdepes_spe.dat
NDATATTSDataSPEdepes_spe_monica.dat
NDATATTSDataSPEphonmap_spe_monica.dat
NDATATTSDataSPEsynth_monica_dri40_155mrf22_270_06.dat
NDATATTSDataSPEsysdct_spe_cfg1.dat
NDATATTSDataSPEtokentn_spe.dat
NDATATTSDataSPEuselect_monica_dri40.dat
NDATATTSDataSPEvauto_pipeline_spe_monica_22_dri40_155mrf22.hdr
NDATATTSDataTransDataENUapdb_tp_samantha_dri40_lrfix.apdb
NDATATTSDataTransDataENUTTS_DIC_ENU.bdc
NDATATTSDataTransDataENUTTS_PRON_ENU.bdc
NDATATTSDataTransDataENUTTS_TRANS_ENU.rul
NDATATTSDataTransDataFRFTTS_DIC_FRF.bdc
NDATATTSDataTransDataFRFTTS_PRON_FRF.bdc
NDATATTSDataTransDataFRFTTS_TRANS_FRF.rul
NDATATTSDataTransDataSPETTS_DIC_SPE.bdc
NDATATTSDataTransDataSPETTS_PRON_SPE.bdc
NDATATTSDataTransDataSPETTS_TRANS_SPE.rul
NDATAVBTPOILIST0.DB
NDATAVBTVERSION.TXT
NDATAVBTENEN_USAEGrammars.vba
NDATAVBTENEN_USState.fsm
NDATAVBTENEN_USVBTAsrModel.dat
NDATAVBTENEN_USVBTDDG2P.DAT
NDATAVBTENEN_USVBTLex.dsu
NDATAVBTENEN_USVBTMP3DDG2P.dat
NDATAINITDATAUSERSETUP is empty
Total image space:  3,802,103,808
Free image space:   668,868,808
Image cluster size: 8,192
Boot Sector OEM:    MSWIN4.1
Serial Number:      07F10006
Bytes/Sector:       512
Sectors/Cluster:    16
File System:        TFAT32
Disk Label:         DONT_DEL015
NDATASDUSBFILTER.FLR file contents:
SDMMCNDB
SDMMCPC
SDMMCVoice
SDMMCFirmware
SDMMCLT
SDMMCdebug
SDMMCUPDATE
SDMMCTypeManager
SDMMCVersion
NDATATELGOOG411.DAT file contents:
14252964544
  • [*:1hfjomq9]The firmware update themselves have no executable code.
    [*:1hfjomq9]NDATAINITDATAUSERRWVBTENEN_USMusicCatalog is in SQLite Format 3
    [*:1hfjomq9]NDATAVBTPOILIST0 is in SQLite Format 3
Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse.zip
Edited Nov 09, 2010 by ShortFuse
Posted Sep 04, 2010 · 23:56 UTC#2
Good luck.
Posted Sep 05, 2010 · 00:33 UTC#3
Okay, I think the hack you guys really care about is the password hack.
It's stupid easy if you've ever cracked something before. I'm working on making a keygen. The code itself will be in the RenewalIFLib.dll under USER\PRG\APL. I'll play with modifying other stuff later. :)
It seems RenewalIFLib decodes AUTHINFO.DAT and VERINFO.DAT
I would just patch the dll and make it skip this but it seems to write a file as well. It might break something else later and then maybe you'll be permanently stuck. It's probably just safer to make a keygen.
Posted Sep 05, 2010 · 00:37 UTC#4
What is your opinion on the possibility of UI hacks based on what you have seen so far?
Posted Sep 05, 2010 · 00:57 UTC#5
Crack it
Posted Sep 05, 2010 · 01:11 UTC#6
THE BMP files can be modified. A lot of graphic files are packed so I"ll have to see how to unpack them. I'm still running the stock Z110BT so I'll have to update first. The voices can seemingly be changed.
There are two NAND devices. They're called NAND and NAND2. NAND is where the application itself lives. I'm sure it's probably 64MB or 128MB. The second (NAND2) is a 4GB. That's where the NDATA writes to. We can modify that by changing the NDATA files and running the update. Flashing files to NAND1, I'm not sure yet. By the way, the Operating System being "Windows Automative 5.5" is not true. It's WinCE 5.0. I'm sure there's no check. You can probably replace navi.exe from APL with a WINCE app and it'll run. I'll look into play with all this but first, I'm going to try to decrypt the DAT files so I can actually use the new firmware.
Can somebody describe the firmware upgrade process to me? The steps?
Oh yeah, I'm sure you can also modify the voice. Pioneer uses Scansoft's Vocalizer for WinCE
You can grab a demo here: ftp://ftp.scansoft.com/pub/intel/
I'm pretty sure that's what the VBT files are
Posted Sep 05, 2010 · 01:48 UTC#7
Ok can you please keep this thread updated and stick with it. Or at least let everyone know if you get to a point where you no longer want to continue. There have been so many that have claimed they could and would do what you are claiming only to never be seen again. Please don't be one of those people. Once this gets to a promising point I will gladly sticky this and any other topics that are promising.
Posted Sep 05, 2010 · 02:17 UTC#8
K, I'll try to post as much as I can. I'm not that great of a cracker. Regardless, I'll contribute as much as possible. If I can't, hopefully somebody can continue work.
Posted Sep 05, 2010 · 02:18 UTC#9
Updated: Added Decrypt subroutine from RenewalIFLib.dll
Posted Sep 05, 2010 · 04:43 UTC#10
The key file here is RenewalIFLib.dll from the APL directory.
Decompiled with Desquirr:
AL_AUTH_Operation::PassAttestation(ushort const *)
10002648 _PassAttestation_AL_AUTH_Operation__QAA_AW4AL_AUTH_PasswordResult__PBG_Z:
10002648   R12 = SP;
1000264c   /* push LR */
1000264c   /* push R12 */
1000264c   /* push R11 */
1000264c   /* push R8 */
1000264c   /* push R7 */
1000264c   /* push R6 */
1000264c   /* push R5 */
1000264c   /* push R4 */
10002650   R11 = & 0x20;
10002658   R6 = R1;
1000265c   R7 = R0;
10002668   var_24 = * unk_10010CCC;
1000266c   R8 = 0x20000000;
10002680   /* Low-level instruction of type 31 */
10002684   R5 = 3;
10002688   Cond = R6;
1000268c   if (Cond != 0) goto loc_100026B4;
10002690   R3 = _Output_AL_Log__SAXKPBDZZ;
10002694   R1 = "ERROR: NULL Password";
100026a0   /* Low-level instruction of type 31 */
100026a4 loc_100026A4:
100026a8   sub_1000600C(var_24, R1, R2, R3);
100026ac   R5 = 3;
100026b0   goto loc_100028CC;
100026b4 loc_100026B4:
100026bc   Cond = wcslen(R6) - 0x10;
100026c0   if (Cond == 0) goto loc_100026DC;
100026c4   R3 = _Output_AL_Log__SAXKPBDZZ;
100026c8   R1 = "ERROR: SIZE Password";
100026d4   /* Low-level instruction of type 31 */
100026d8   goto loc_100026A4;
100026dc loc_100026DC:
100026e8   memset(R11 - var_4C, 0, 0x11);
1000270c   Cond = * _NCharToChar__YAHPBGHPADH_Z(R6, 0x10, R11 - var_4C, 0x10) - 0x10;
10002710   if (Cond != 0) goto loc_100026A4;
10002718   var_A4 = 0;
1000271c   R3 = 0;
10002724   var_A0 = R3;
10002728   var_9C = R3;
1000272c   var_98 = R3;
10002738   var_A8 = strlen(R11 - var_4C);
10002750   Cond = ?ConvertHexStrToBin@AL_AUTH_Operation@@QAAJPAEKPBEK@Z(R7, R11 - var_A4, 0x10, R11 - var_4C);
10002754   if (Cond == 0) goto loc_10002774;
10002758   R3 = _Output_AL_Log__SAXKPBDZZ;
1000275c   R1 = "ERROR: CONVERT ERROR: Password:%s";
10002760   R2 = R11 - var_4C;
1000276c   /* Low-level instruction of type 31 */
10002770   goto loc_100026A4;
10002774 loc_10002774:
10002784   var_8C = 0;
10002788   memset(R11 - var_8B, 0, 7);
10002790   R6 = 0;
100027ac   var_84 = R6;
100027b0   var_80 = R6;
100027b4   var_7C = R6;
100027b8   var_78 = R6;
100027bc   var_94 = R11 - var_8C;
100027c0   var_90 = 0x18;
100027c4   R0 = ?Decrypt@AL_AUTH_Operation@@QAAJPBGAAUAL_AUTH_CryptoDataBuff@@PBK@Z(R7, * off_1001057C, R11 - var_94, R11 - var_A4);
100027c8   R6 = R0;
100027d4   ??0AL_AUTH_File@@QAA@ABUAL_AUTH_FileInfo@@@Z(R11 - var_74, R11 - var_8C, R2, R3);
100027d8   R2 = 0x14;
100027dc   R1 = 0;
100027e0   R0 = R11 - var_38;
100027e4 loc_100027E4:
100027e4   memset(R0, R1, R2);
100027f4   memset(R11 - var_58, 0, 10);
100027f8   R3 = 0xf0000002;
100027fc   R7 = R3 | 0x660000;
10002800   Cond = R6;
10002804   if (Cond != 0) goto loc_10002864;
1000280c   R0 = ?Check@AL_AUTH_File@@QBA_NXZ(R11 - var_74, R1, R2, R3);
10002810   Cond = R0 - 1;
10002814   if (Cond != 0) goto loc_10002860;
10002818   R0 = ?Instance@AL_VersionManagerIFBase@@SAPAV1@XZ(R0, R1, R2, R3);
1000281c   Cond = R0;
10002820   if (Cond == 0) goto loc_10002888;
10002834   /* Low-level instruction of type 31 */
1000283c   R6 = R0;
10002858   * _NCharToChar__YAHPBGHPADH_Z(R11 - var_38, 10, R11 - var_58, 10);
1000285c   goto loc_10002864;
10002860 loc_10002860:
10002860   R6 = R7;
10002864 loc_10002864:
10002864   Cond = R6 - R7;
10002868   if (Cond == 0) goto loc_100028B8;
1000286c   if (Cond <= 0) goto loc_100028BC;
10002870   R3 = 0xf0660004;
10002878   Cond = R6 - R3;
1000287c   if (Cond <= 0) goto loc_100028B0;
10002880   Cond = R6;
10002884   if (Cond != 0) goto loc_100028BC;
10002888 loc_10002888:
10002890   R1 = ?GetVersion@AL_AUTH_File@@QBAPBDXZ(R11 - var_74, R1, R2, R3);
100028a0   Cond = strncmp(R11 - var_58, R1, 10);
100028a4   if (Cond != 0) goto loc_100028B8;
100028a8   R5 = 0;
100028ac   goto loc_100028BC;
100028b0 loc_100028B0:
100028b0   R5 = 2;
100028b4   goto loc_100028BC;
100028b8 loc_100028B8:
100028b8   R5 = 1;
100028bc loc_100028BC:
100028bc   R0 = R11 - var_74;
100028c0 loc_100028C0:
100028c0   ??1AL_AUTH_File@@UAA@XZ(R0, R1, R2, R3);
100028c8   sub_1000600C(var_24, R1, R2, R3);
100028cc loc_100028CC:
100028cc   R0 = R5;
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   /* pop  */
100028d4   return R0;
AL_AUTH_Operation::Decrypt(ushort const *,AL_AUTH_CryptoDataBuffer &,ulong const *)
var_28= -0x28
var_24= -0x24
var_20= -0x20
var_1C= -0x1C
10002244 _Decrypt_AL_AUTH_Operation__QAAJPBGAAUAL_AUTH_CryptoDataBuff__PBK_Z:
10002244   /* push LR */
10002244   /* push R8 */
10002244   /* push R7 */
10002244   /* push R6 */
10002244   /* push R5 */
10002244   /* push R4 */
1000224c   R7 = R3;
10002250   R4 = R2;
10002254   Cond = R1;
10002254   R5 = R1;
10002258   R8 = R0;
1000225c   if (Cond == 0) goto loc_100023BC;
10002264   Cond = * R4;
10002268   if (Cond == 0) goto loc_100023BC;
10002270   Cond = * (R4 + 4) & 7;
10002274   if (Cond != 0) goto loc_100023BC;
1000227c   R0 = ??2@YAPAXI@Z(0x400);
10002280   Cond = R0;
10002280   R6 = R0;
10002284   if (Cond != 0) goto loc_10002288;
10002284   R5 = 0xf06600ff;
10002288 loc_10002288:
10002288   if (Cond == 0) goto loc_100023E8;
10002298   memset(R6, 0, 0x400);
100022a0   R3 = * (R4 + 4) + 8;
100022a4   Cond = R3 - 0x400;
100022a8   if (Cond <= 0) goto loc_100022D8;
100022c8   * _Output_AL_Log__SAXKPBDZZ(0x20000000 | 0x80000, "DECRYPT ERROR: MemSize:%d, EncryptedSize:%d", 0x400, R3);
100022d0   R5 = 0xf0000000 | 0x660000;
100022d4   goto loc_10002330;
100022d8 loc_100022D8:
100022e4   var_28 = R6;
100022e8   var_24 = R3;
100022ec   R0 = ?ReadEncryptedFile@AL_AUTH_Operation@@AAAJPBGAAUAL_AUTH_CryptoDataBuff@@@Z(R8, R5, & var_28, R3);
100022f0   Cond = R0;
100022f0   R5 = R0;
100022f4   if (Cond == 0) goto loc_1000233C;
10002314   * _ErrorRec_AL_Error__SAXPBDKJK_Z("$Id: AL_AUTH_Operation.cpp 58126 2009-03-23 10:09:44Z yuliangde $", 0xc6, R5, -1);
1000232c   /* Low-level instruction of type 31 */
10002330 loc_10002330:
10002334   ??3@YAXPAX@Z(R6);
10002338   goto loc_100023E8;
1000233c loc_1000233C:
1000233c   R1 = var_28;
10002340   R5 = * (R4 + 4);
10002350   var_20 = * R1;
10002354   R3 = * (R1 + 4);
1000235c   var_1C = R3;
10002360   memcpy(* R4, R1 + 8, R5);
10002368   ??3@YAXPAX@Z(R6);
1000236c   Cond = R7;
10002370   R0 = & var_28;
10002374   if (Cond != 0) goto loc_10002398;
10002378   ?GetInternalAccessKey@AL_AUTH_KeyLib@@SAXPAK@Z(R0, R1, R2, R3);
1000238c   ?DecryptInternalAccessKey@AL_AUTH_CryptoLib@@SAXPAKPBK1K@Z(* R4, & var_28, & var_20, R5 >> 3);
10002390   R5 = 0;
10002394   goto loc_100023E8;
10002398 loc_10002398:
1000239c   ?GetExternalAccessKey@AL_AUTH_KeyLib@@SAXPAKPBK@Z(R0, R7, R2, R3);
100023b0   ?DecryptExternalAccessKey@AL_AUTH_CryptoLib@@SAXPAKPBK1K@Z(* R4, & var_28, & var_20, R5 >> 3);
100023b4   R5 = 0;
100023b8   goto loc_100023E8;
100023bc loc_100023BC:
100023dc   * _Output_AL_Log__SAXKPBDZZ(0x20080000, "DECRYPT ERROR: Buff:%08x, Size:%d", * R4, * (R4 + 4));
100023e4   R5 = 0xf0000000 | 0x660000;
100023e8 loc_100023E8:
100023e8   R0 = R5;
100023f0   /* pop  */
100023f0   /* pop  */
100023f0   /* pop  */
100023f0   /* pop  */
100023f0   /* pop  */
100023f0   return R0;
Okay, if you guys want a crack, it'll be done in AL_AUTH_Operation::PassAttestation(ushort const *) in the RenewalIFLib.dll
You can see a somewhat decompiling there in C but I'm also just looking at straight assembly code in IDA Pro. Basically, this function is the end-all checking function. It tests your password.
Here's how it works. The function returns R0, but before that, Ignoring the POPs, R0 is set to equal the value of R5. Here are all the function we care about:
loc_1000600C (UNKNOWN1):
(probably a message box or debugging log)
loc_100026A4 (FAILED):
GOTO UNKNOWN1
R5 = 3 (MOV R5, #3)
GOTO FINISH
loc_100028CC (FINISH):
R0 = R5
/POP/
Return R0
Here's how it works:
  1. [*:1p0x1fp4]Check if you put a password. If you didn't:
    Respond: "ERROR: NULL password"
    GOTO FAILED (which goes to FINISH)
    [*:1p0x1fp4]Check the length of your password. If it's not the right length:
    Respond: "ERROR: SIZE password"
    GOTO FAILED
    [*:1p0x1fp4]Run your password through a character conversion function. If it fails:
    GOTO FAILED
    (interesting there's no error message)
    [*:1p0x1fp4]Convert your pass from string to binary (hex).If this fails:
    Respond: "ERROR: CONVERT ERROR: Password: %s" (%s being your password)
    GOTO FAILED
    [*:1p0x1fp4]Decrypts your password via AL_AUTH_Operation::Decrypt
    [*:1p0x1fp4]Probably looks for AUTHINFO.DAT since it calls AL_AUTH_File::AL_AUTH_File(AL_AUTH_FileInfo const &)
    [*:1p0x1fp4]At loc_100027E4, it checks some values, but I'm not entirely sure what's going on, but I know if it fails:
    Skip to step 12
    [*:1p0x1fp4]AL_AUTH_File::Check, If True:
    SET R6 = R7
    Skip to step 12
    [*:1p0x1fp4]Initialize VersionManager, if good
    Skip to step 15
    [*:1p0x1fp4]Another character conversion ???
    [*:1p0x1fp4]If R6 = R7
    Skip to 17
    [*:1p0x1fp4]If R6 < R7
    Skip to 18
    [*:1p0x1fp4]If R6 <= 0xF0660004 (This will run if R6 > R7)
    R5 = 2
    Skip to 18
    [*:1p0x1fp4]If R6 = 0
    Skip to 18
    [*:1p0x1fp4]Get VersionFile. It calls AL_AUTH_File::GetVersion(void)
    [*:1p0x1fp4]Compare Version. If False
    R5 = 0
    Skip to 18
    [*:1p0x1fp4]R5 = 1
    [*:1p0x1fp4]Do something... not sure
    [*:1p0x1fp4]Close AuthInfo files. It calls AL_AUTH_File::~AL_AUTH_File(void)
    [*:1p0x1fp4](FINISH) Return R5
Here's what I figure.
R5 Values
  • [*:1p0x1fp4]0 = New version. Do Update.
    [*:1p0x1fp4]1 = Same version. Don't Update.
    [*:1p0x1fp4]2 = No authfile. I'm not sure what it'll do.
    [*:1p0x1fp4]3 = Failed. Don't update.
Here's my guess. I crack it by saying, if it goes to FAILED, set R5 = 0 instead of 3. So you can put a blank (or at least 1 character) for a password and it'll accept it as correct. :)
Now, you're asking. How do I crack it?
Easy.
TL;DR
Open RenewalIFLib.dll in a hex editor. Go to 0x1AAC. Change 03 to 00.
Let me know if that works for you guys. :)
Posted Sep 05, 2010 · 07:53 UTC#11
After reading this thread, I think I just grew a set of buck teeth, and now I just keep saying duhhhhhhhh. LOL
Posted Sep 05, 2010 · 12:26 UTC#12
Bad news. The SD upgrade doesn't run the cracked lib on the SD. It runs off the internal NAND. I have to make a fake update. If you haven't upgraded to 1001, there's a good chance it'll work for you. I'm going to see if I can find another way for us 1001s. If you still have 1000, post here.
Posted Sep 05, 2010 · 16:16 UTC#13
Good news! i found out how to falsify updates! File mods, here we come!
Posted Sep 05, 2010 · 20:13 UTC#14
Ok, what does this mean exactly.
Posted Sep 05, 2010 · 21:38 UTC#15
WOAH!!!!!!! It worked!!!! I'm updating it now.
Posted Sep 05, 2010 · 22:01 UTC#16
Stickied!
Posted Sep 05, 2010 · 22:07 UTC#17
HOLY CRAP! Froze at 98% and said
INCORRECT SD CARD. PLEASE INSERT THE CORRECT ONE.
My heart jumped. I found out the issue. I fixed it and it installed now. I'm going to test it and play with it now.
Bluetooth AVRCP isn't working but I just remembered I haven't done the bluetooth upgrade. I'm doing that now...
Yeah, that was it. It's working now. This definitely not worth the $200. I'm making a file now.
Posted Sep 05, 2010 · 22:38 UTC#18
Woah nice..
Posted Sep 05, 2010 · 22:49 UTC#19
Crack is up! Check the first post!!!
Posted Sep 05, 2010 · 22:59 UTC#20
So here's how I understand it..
U download the 1.001000 update from Pioneer, replace the 2 files and copy 1.001000 update (with the patched files) to an SD card. Insert that and update the radio.
Then after the AVIC is updated to 1.001000, you go ahead and insert the (1 of 2)120BT SD cards update? Inputting anything for a password?
How big do those cards have to be?
Posted Sep 05, 2010 · 23:08 UTC#21
Yes, this is a special 1.001000 update. It's actually marked as 1.002000 which is why it updates.
In reality, you can do it all with just one SD card. The updates can be found on torrents. SD1 is 4GB. SD2 is just 2 megabytes.
Posted Sep 06, 2010 · 01:21 UTC#22
I felt a little brave enough to try this out.. Tried it right now and I can confirm that it WORKS. Now just need to get used the interface :D
Posted Sep 06, 2010 · 02:20 UTC#23
I'm not going to do the mod, but just have to say thanks to shortfuse for doing what he did. It allows interesting things to be done with the hardware that many of the manufacturers themselves never thought about. Just goes to show that there are some really intelligent people out there. Congratulations!!!!!!
Posted Sep 06, 2010 · 04:12 UTC#24
Well done on the mod! :D
Wanted to try this but needed to ask if this method will work the same with the AU version (f10bt) because I can't find any f10bt 1.001 on the AU/EU website. There is an update though for time-zone fix which contains pretty much the same files just a different size, would it still work if I swapped the 2 files on that update?
Posted Sep 06, 2010 · 07:15 UTC#25
I'm not after the 2010 upgrade, but I am very interested in mods! I've got both an F90BT and Z110BT at the moment, and would love to see the map program hacked to do the speed trap cameras and other great stuff that's been unlocked on the F-series.
If I have to go with the Z120 interface to do so, I'll do it, (new maps a bonus).
Huge props to ShortFuse!
Perhaps we can get the master modders from the F series to take their efforts over here now, now that the master cracker has opened the door?
Page 1 of 12
