This is great news. My question though is how do we 1) Get into the main file bmp's to change them, and 2) How can I make my 'Data.zip" work with this so that the NAV portion can be modified?
Cracking the Z110/20BT: F10/F20BT included? Region changing?
Well done on the mod!Wanted to try this but needed to ask if this method will work the same with the AU version (f10bt) because I can't find any f10bt 1.001 on the AU/EU website. There is an update though for time-zone fix which contains pretty much the same files just a different size, would it still work if I swapped the 2 files on that update?
This is a US version and therefore contains the US maps, unles you can separate the interface and install that only, which I'm not sure you can ![]()
Do you think it may be possible to hack the music playing file decoders to allow playback of FLAC files?
I suggest everyone install the 2010 upgrade because there's no way for me to test v1.x and I'm not going to split development.
Excuse my ignorance, i'm new to this forum, but what is cracking this upgrade allow you to do with the Z110BT?
Hmmmm, lots of replies, but none to my question. Can the Z120's navigation section be hacked? The file structure should be similar even though it is a different OS, but if it is possible to get into the main Navigation section, I can try to convert my Nav mod over to the Z120. If this is possible and someone can send me the files, I can start molding your system, with the help of a tester, that is, because I don't have a 120. If anyone is interested and has the capabilities of extracting the Nav files, PM me!
there is an offial update available from PIoneer circa $200 although it's been discounted to under $150 in some places. However, this crack allows a free update, this basically turns your Z110 into a Z120 buy updating the UI and the maps ![]()
This is good news for all of us Z110/ F10BT users!!
ShortFuse, is it possible for you to look into the update for the european version?
I registered just to give props to shortfuse. Im DL'n all of the files now but im out of town and dont want to risk my navi crapping out on me. ill confirm or deny tomorro when i get bak home. thanx again shortfuse.
Hey abb, I think its too early to tell but this is promising. I wanted you to see this so if it gets to that you can offer some insight. As soon as it develops further, ill let you know.
Thank you, if we can ever get into the file system, let me know, and I will work on itHmmmm, lots of replies, but none to my question. Can the Z120's navigation section be hacked? The file structure should be similar even though it is a different OS, but if it is possible to get into the main Navigation section, I can try to convert my Nav mod over to the Z120. If this is possible and someone can send me the files, I can start molding your system, with the help of a tester, that is, because I don't have a 120. If anyone is interested and has the capabilities of extracting the Nav files, PM me!
Z120 and Z110 running the 2010 upgrade are exactly the same. The 2010 upgrade updates the OS to 2.000 making the two identical. Currently, there are two drives. The NAND and NAND2. What we care about, really is the APL folder. Everything that runs is in there. The OS is in the PLATFORM file, which is a WinCE ROM file. It's pretty similar to Windows Mobile ROM files. I'm going to ask people on XDA who do WinMo hacks for help decoding it. Windows Mobile 6 is also WinCE 5.0 (version 5.2) so there should be a lot of interoperability between the two.
What is your opinion on the possibility of UI hacks based on what you have seen so far?
Without disassembly knowledge, it's not going to be easy. It's not impossible, but so far, the only way I see it being possible is through reverse engineering. Maybe if we map out the system well enough we can see some modifications. At the current level, the things we can do now seems somewhat limited. Of course, as we go along and start unpacking files we can get somewhere. The biggest danger is the lack of a proper bootloader. If we mess something up, there's no recovery option. It's too easy to brick the device. Step 1, of all, is decode the PRG files.
I'm hoping so. But to be honest, we'd have to invent something that's never been done on WinCE (PPC/WinMo) before. If it was already done I'd try to plug it in, but we'd be doing it from scratch. We would need FLAC to work via DirectShow with a DMO wrapper.
Did you take a look at the first post with the file table for NAND2? Is that what you need?
I'm not exactly sure what I'm looking for here... The only thing I've done so far is hack the v1.x to 2.0 password protection.
Thanks Shortfuse for breaking it down to me.
Yeah, I looked at it, but it is totally different to what I am used to. Can you copy and extract all those files from the AVIC?
It won't do you any good... All NAND2 has is Map Data, XM Radio bitmaps, sound effects, symbols and voices. The real data can be found on the updates, the APL folder. This is where you'll get your UI elements and mods.
The most probable thing we can do is reskin it. Under APL\MENU you can find a IMAGE.img file which contains all 2885 bitmap files used for the menus. There are 2500+ 32k bmps. There are 300+ 2M bitmaps. I'm assuming that means color, not resolution. I'm still working on extracting those.
The RFF files seem to be layout files. I haven't been able to decode it manually. It seems to have been made with Pioneer Navistudio 3.01. I have the program but I can't seem to get into it. I think it's looking for a portable Pioneer device (Japan Pioneer Unit).
You can grab the 3.2 version here: http://pioneer.jp/car/navistudio/navist ... /step.html
I hope you know Japanese...
Btw, this is what a Japanese unit's GPS screen looks like
woohoo! it worked..cant wait to see what kinds of mods come out now!
ShortFuse, is it possible for you to look into the update for the european version?I'm not exactly sure what I'm looking for here... The only thing I've done so far is hack the v1.x to 2.0 password protection.
The problem is, that for the EU versions (F10BT) there was no 1.001 update offered, so we can't use this as a basis to hack the update.
Strange though, that the 2.003 update is existing for the F20BT too, and so far I compared the EU and US files, it looks exactly the same.
So it might do work using the US 1.001 update files, but I don't want to brick my unit...
That was my question on the previous page too, though there is an update on the AU website for f10bt which is called "Time Zone Fix On The Pioneer AVIC-F10BT" which contain all the files that are contained in the US 1.001 update, there is even an AVICZ110 folder inside that zip even tho it is AVICF10. Be interesting if EU/AU can use that update instead of the US 1.001
Nah, I dont know japanese
. The F/X series has its main/AV files in an APL folder whereas the Navigation section resides in an APL2/IGO folder. It makes sense that the image file is in the APL/Menu folder, but there must be another folder that houses the units navigation scripts. That is what we need to find. Thank you for all the hard work that you are doing in this. If we can get this unit modified, I will be off to purchase one and do all my modding on this unit as well as my X series. Can you send me a copy of the IMAGE.img file?
can some help me out please i got this error message INCORRECT SD CARD. PLEASE INSERT THE CORRECT ONE.
Thank you, how do you open the .img file though? I get an error message that says 'NOT A CD IMAGE' or saying that it cannot find the image file even though it is in the 'open' box. I tried using a couple of programs and none seem to work.
Make sure SD1 from the update is not modified in any way.
That's the million dollar question...
perhaps the .img extension is not for a CD image but rather a drawing or graphic image software program..ie Autocadd or ? ?
No. As I said before, it's a packed file. I'm trying to unpack it. It doesn't use any conventional forms of compression/packing that I can see. Pull out a hex editor and you'll see the filenames at the bottom of the IMG file. (2885 bmps)
