Just did the upgrade. Success! Thanks again.
Cracking the Z110/20BT: F10/F20BT included? Region changing?
Where do I get the 2010 update. I have the crack loaded but dont know where to get the 2- SD card 2010 update?????????
I tried that the link. It downloads a file that wont open. I am on a MAC so I wonder if it needs a windows application to open
Download the v1.001 update from Pioneer.Replace \AVICZ110\EU090APL.VER and \AVICZ110\APL\RenewalIFLib.dll with the files attached.
Copy the AVICZ110 folder with the patched files to the root of an SD card.
Insert the SD to your Z110BT and it should start updating automatically.
I already installed v1.001 from Pioneer but I can't get your FAKE v1.002 to install. The HU doesn't recognize the SD card as an update card, just a simple SD card. I have the AVICZ110 folder in the root directory, and it has the two files replaced.
I have no idea what to do next.
I did try and upgrade from Z110 to Z120 anyway, just to see if the v1.002 update took but it just didnt tell me it did. Unfortunately, I can't get pass the PASSWORD prompt. Even if I use all characters and fill up the box.
Please let me know what to do next.
UPDATE:
I just found out my 32GB card is fake and the update did not exist on my card when updating. I am assuming this is why it didn't work. I will get a genuine card and try the update later. EBAY sellers are sometimes EVIL!!!!
My card is genuine and i still cant get my z110bt to recognize the sd card as an update card. it recognized the firmware patch as an update the first time, but when the update was complete it still showed version 01.0000. did i miss something?
its a rar file, u need unrarx to extract the bit torrent file. Then use transmission to download. Good Luck.
Found out what i was doing wrong. I had the wrong folder in the root. the update worked perfectly. this crack is confirmed. thanx again shortfuse
Hey I'm getting the same thing with the update as 1.0000 and I cant even load the SD card 1 because when I do, it asks for the code but nothing works. I then tried to redownload the original 1.001 from pioneer and put the SD card in there but nothing happened. I noticed that when I initially downloaded the patch, it downloaded with the music going on simultaneously, but when I checked the version update, it said 1.0000. I even reset the unit and tried it over again but it wont update.What am I doing wrong. Any info will help. Thank you.
I only have a 1-1gb and 2-2gb sd cards can I load sd1 files 1 and 2 on on card and sd1 files 3 and 4 on another card and sd2 file on the third card and load it? What about loading it off of a single 4gb USB flash drive hooked to the USB port from the iPod connection.
Props to you guys SHORTFUSE THX Much
Enjoy..
None of this was my hard work it for sure took a team.
AVIC411 FTW
Download this file. Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse.zip
http://avic411.com/forum/download/file.php?id=9893 know the location of the file where you downloaded the file to on your hard drive.
Now Download this file from pioneer. 1.001000.zip
http://ds1.downloadtech.net/cn1010/firmware/1.001000.zip know the location of the file where you downloaded the file to on your hard drive.
Now open up your c:\drive and make a new folder called update.
Now in the folder c:\update extract the contents of both of the downloads into the folder c:\Update
Use winrar or what ever app you like that will uncompress files.
You should now have two folders with files now in the c:\updates folder.
c:\updates\1.001000 This has lots of files and folders in it.
and
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\ This will have three files in this folder.
Replace the file, in the following location
c:\update\AVICZ110\EU090APL.VER
with this file
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\EU090APL.VER
c:\update\AVICZ110\APL\RenewalIFLib.dll
with this file
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\RenewalIFLib.dll
Format SD (Right click sd card under my computer and format) format in FAT32 the card needs to be 4gb or larger to complete all steps.
Now Copy the folder
c:\update\AVICZ110
Lets say your sd card is j: drive.
You will now have one folder on the j: drive.
j:\AVICZ110 (Plus all the contents of the folder.)
Now insert the SD to your Z110BT and it should start updating automatically.
Now how to do the update to os version 2.0
Once downloaded with your favorite utorrent client and unrared, you will have two folders that represent two separate SD cards.
You must install a torrent application, before the torrent file below will do you any good. Below are clients for both mac and windows.
Windows Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=win
Mac Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=mac
The update OS torrent file can be found here http://avic411.com/forum/download/file.php?id=9668
You can do all this from one sd card or two.
Once torrent is downloaded.
You will have a folder CNSD-110FM default location under c:\doc settings\your username\downloads
Open the folder c:\doc settings\your username\downloads\CNSD-110FM you will see two more folders
default location
c:\doc settings\your username\downloads\CNSD-110FM\SD1
and
c:\doc settings\your username\downloads\CNSD-110FM\SD2
Open these folders and extract contents with winrar to
c:\uploads\CNSD-110FM-SD1
c:\uploads\CNSD-110FM-SD2
TIME for another FAT32 format
Format your SD card in fat32 right click on the sd card and select format under my computer.
Copy content of folder c:\update\CNSD-110FM-SD1
and put it on the root of the SD drive.
lets say sd drive is is j:\ drive it really could be any letter f:\ u:\ c:\ k:\ .. I don't know the driver letter for your SD card. ( You do have a SD card reader RIGHT?) ![]()
you will have two folders and one file on j:\ drive
j:\Firmware (folder) plus all the content of the folder
j:\Update (folder) plus all the content of the folder
j:\CARDINFO.cif (file)
now take the sd card and put it in the z110bt
This will start the upgrade it will ask for serial.. just type leters until you can type no more.. (no numbers) letters only.Then continue. This takes about 25 min..
After OS install version 2.0 has been installed, the bluetooth needs to be updated two times.
With the same card you just updated the os with do the following steps.
a) press (Home button) to display top menu.
touch (system settings)
c) touch (bluetooth settings)
d) confirm bluetooth version is 2.50
e) scroll to bottom of list touch ( firmware update)
f) confirm update
g) after finish takes maybe 5-6 min confirm 3.10 version is now on unit under bluetooth setting page
h)once update finishes click ok. now eject sd card.
Get new SD card or format the existing sd card
i) copy content of c:\update\CNSD-110FM-SD2 folder onto the root of the new or cleanly formated sd card
j) press (Home button) to display top menu.
k) touch (system settings)
l) touch (bluetooth settings)
m) confirm bluetooth version is 3.10
n) scroll to bottom of list touch ( firmware update)
o) confirm update to 3.11
If I missed something please let me know.
Thx agian guys.
funny, when it asked for the passcode, I kept trying even though it said password incorrect, then it took. I guess it just needed a little persistence.Oh, and I did the bluetooth update once and it updated it to 3.11. Not sure what happened but it seemed to work.
I'm totally lost & can't figure this out. It seems like it should be simple enough, but I'm totally blank here...
How do you replace the files is there a step by step on how to do this entire process for the not so technical folks?
please look up above us 2 post up.. I have updated the how to.
Thank all those who worked very hard to make this happen and find new ways for us to enjoy our navis. I personally only stuck with pioneer navis because of the support from this forum, otherwise I wouldnt have converted to kenwoods long time ago because I primarily am an audiophile. Again, thanks:
shortfuse
vblue
rgarjr and filezz for simplification. And anyone else I forgot.
Your contributions will not go unnoticed.
anyone has the update for f10bt? (european version of z110)
I have been working on trying to get the torrent file open and cant get it opened. I have downloaded may torrent programs and nothing works. I have about 7 hours into trying to get all of this going and I know it is prolly a 45 minute deal HELP please
Ok, Downloaded BitLord and it is doing nothing but counting the time I have been connected and nothing is downloading. Does it take time? It has been 14 minutes with 0% downloaded. Does it have to wait for someone to connect that has it to share from? I show 0 peers connected. Please direct me on what to do.
thanks
I sent private message to you.
shortfuse
vblue
I second that!!!!!!
Great work getting this to work.
The RAR files are parts of a whole; it isn't really 4 separate files. When you extract the first one with WINRAR, the program will put all the files together and produce the necessary directories.
Also, you CANNOT use an SD card smaller than 4GB for the contents of CNSD-110FM-SD1.
The contents of CNSD-110FM-SD2 can fit on your 1GB.
And, NO, you cannot use anything else but the SD card slot.
Read filezz post for directions on how to install.
Ok can someone tell me what I am doing wrong. I replaced the original files from the official pioneer update with the two files from the crack,then put the folder with the cracked files on an Sd card but when I try to update it finishes 100% then says the update failed. After this happens the system continues to restart and try the update process over and over again, failing repeatedly. Has anyone else had this problem?
Getting to 100% means the files were successfully copied from your SD card to the internal flash of the HU. There may be an issue with one or more of the files. Sounds like file corruption.
I would get another copy of the update, REMOVE and replace the two files within the update (do not overwrite them), format the SD card, copy over the necessary files to the SD card, and try again.
I'll add my thanks to the great efforts done on the Z110/Z120.
It is funny that large corporations are scared of the open source world. The Pioneer for me is now (v2.0) a bit more friendly - but still *woefully* lacking.
A friend in the EU has the Z (F) version, and after almost a year (first with a buggy Kenwood), is moving to Sony (http://www.pocket-lint.com/news/35338/s ... tom-satnav).
I only wish a company could help to push its product more into the main stream (allowing custom upgrades - to systems like Nav).
Hopefully this sets off a bit of outside dev that can do for Pioneer - what they cannot do for themselves. A good, more open system has a real value...
Ok thanks that worked.
I have been working all day trying to get these stupid RAR files to open. I show the files quantity is there but I try to open it and it tells me "the archive is ether in unknown format or damaged". everything seems to be in order. I just dont know what else to do.
One thing I did extract the torrent and and got the four separate RAR files from my MAC and put them on a flash drive and have been trying to open them on a windows computer. They are Host OS windows if that matters
