okay i got the 1.001v, how do i dl the .img file (3.8gb) ?
Cracking the Z110/20BT: F10/F20BT included? Region changing?
anyone have Australia region map version?
Open RenewalIFLib.dll in a hex editor. Go to 0x1AAC. Change 03 to 00.
Let me know if that works for you guys.
you dont explain it very well when you say "Open RenewalIFLib.dll in a hex editor. Go to 0x1AAC. Change 03 to 00" how do you go on finding the 0x1AAC lol do you mean 00001aa4 .. explain more please. i used to use the program but forgot how to use it.
Hey guys I am new to this... I just want to make sure I understand. I have the Z120BT. The file that Pioneer put out for my unit is the CNSD-210FM. Will this hack/upgrade give me that software?
Thanks.
Thanks.
Yes. You need to install the hacked 2.004 update, then insert SD1 from CNSD-210FM. Enter a 16 char alpha only password when prompted - such as "PASSWORDPASSWORD". The key to sucess here is the hacked 2.004, which is merely Pioneer's 2.003 (downloadable from Pioneer's site) with 2 files replaced. Don't use the instructions in this thread to patch the files yourself. They are readily available for download in other threads. Those files can be used for either EU. AU, or US updates.
anyone have middle east (qatar+bahrain+ region map version
for avic f30bt
How about f20bt europe?
I update with cnsd-210fm too
It's then possible to install igo?
Hi guys,
I am new in here
My devise is avic-z120bt and i want to upgrade to avic-z130bt or avic-f30bt.is there anybody to help me? and is this possible to change region settings my devise,because i get it in US,but live in Europe
1. Read this thread. Everything is there. If you have a specific question, then ask it. "Help Me" is not very specific.
2. Which region settings? The DVD player? Not likely, I believe it is in the drive's firmware, not the AVIC app software. If just maps, install the EU version of CNSD210-FM.
3. Stop posting the same message multiple times. It won't get any more help and it will annoy everyone else. Even if it worked, you'd have to a bunch of fragmented responses over a bunch of threads.
For example, the radio frequency settings, I cant get radio stations that are even, only odd stations are set on the radio.
I cant change AM/PM setting to 24 hrs mode
I would appreciate if you could help me with this two.
I apologize for posting several times, probably the mouse was jammed on the button, which resulted in that. Sorry again.
Great question, and I don't know the answer. Have you already installed the EU version of CNSD-210FM? That will answer the question of whether the tuner frequencies are set by the tuner application, or if it is in hardware/firmware. As you have found out US FM frequencies in the US are odd and separated by .02 Mhz. I also think that the allowed frequency band is slightly different - it's been a while since I researched this. If it is different, it only affects a few of the possible station positions at the low/high ends - so no big deal.
So far I don't think anyone who has loaded EU or AU software onto a US Z1x0 has reported back whether the FM and/DVD settings changed. If loading EU software doesn't fix it, then it can not be changed. Please post the results so you can help others with the same question.
AFA 12/24 hr time display, go to Settings/System Settings/Regional Settings/Time and change Time Format. I wish they also had an "OFF" option. Most of us already have a clock on the dash display...although I suspect this one is more accurate.
I have not installed the EU version, I have installed the US version, since I was not sure that it will not conflict with the device I have. You think if I install EU version on the top of US version, it will work?
Sorry, I don't think you can over-write the same version level. AFAIK, US and EU are the same version number - just different maps and other stuff. I was thinking you had a US Z120 (not upgraded).
There may be some way to hack the HU using TestMode to set the version number. Or it might be possible to hack the version number in the EU CNSD-210FM upgrade to be greater than 3.0. But either of those could be dangerous - could brick the HU if done incorrectly. You might get some help with the "real" hackers on this thread:
http://avic411.com/i...11/page__st__30
They might be able to guide you in reverting your HU back to the original (factory) software. It turns out that the HU has two file partitions. The upgrade only changes one. So I believe it is possible, in TestMode, to copy the old one over the new one. I just can't tell you how to do it.
Once you get that done, you can install then install the ShortFuse hack and then the EU CNSD-210FM.
Thanks so much!!!
Hi guys, first time owning a Pioneer and now attempting to update my Z120BT to the latest Z130BT. Is there a direct link to download/torrent this packge? I am a bit confused by the various options and the discussion on updating Z110BT to Z120BT first. Please help!
