Cracking the Z110/20BT: F10/F20BT included? Region changing?
By ShortFuse · Sep 04, 2010in Hacks/Mods💬 290 posts👁️ 108,600 views
Page 6 of 12
Posted Sep 14, 2010 · 18:49 UTC#126
I bought a remanufactured Z110 and updated it to a Z120 and have less than $700 into all of it. looks and works like brand new and saved over half the cost. It was sealed from pioneer. I see them just as good as new because they are gone through and tested be fore leaving the factory.
Posted Sep 14, 2010 · 20:16 UTC#127
I took a deep breath, and tried the hack on my F10BT (EU). And it worked :) I was able to install the hacked US 1.001 , then the EU 2.0 update with a random password.
Thanks ShortFuse for the hack!
It seems, that the application part is the same for both variants.
The only strange thing is that after I tried to install the 2.003 update, it still says 2.0000 although it copied the files, and it seemed that it finished correctly (reseted / restarted itself as it should). If I try to reinstall the update, nothing happens.
The unit seems to be fully functional, so it's fine for now.
THAT'S Great NEWSSS, Where can we find the EU2.0 FILES? I Downloaded the US CNSD-110FM FIles But i guess I need, the EU Files? PLease Help. Can you Explain how to do this...
THXS in Advance!
Posted Sep 14, 2010 · 23:46 UTC#128
Installing the 2.0 and I get a message "wrong sd card installed" at 13%. First step went fine, when it asked for the password I entered in random letters with no problem, and it started installing. 4GB SD Card with 3 files in the root per the instructions. Any ideas?
Posted Sep 15, 2010 · 01:53 UTC#129
Just updated my F10BT as well with the patched 1.001 update and the AU maps updated to 2.000 without a hitch! :D Though the second SD card didn't want to update the bluetooth for some reason, im not sure why, but that's no biggy.
Thank you very much for all your effort! :D
Posted Sep 15, 2010 · 04:59 UTC#130
Well did you try and update the BT with the 1st SD like you're suppose to?
Posted Sep 15, 2010 · 06:40 UTC#131
Where can we find the EU2.0 FILES? I Downloaded as well the US CNSD-110FM FIles But i guess too we need, the EU Files? PLease Help
THXS in Advance!
Posted Sep 15, 2010 · 07:28 UTC#132
My bad, forgot you had to do it manually. Thanks mate!
Posted Sep 15, 2010 · 19:16 UTC#133
********* Is it safe to upgrade to the Firmware Update Version 2.003 After Using the Cracked 2010 Upgrade for the Z110bt*****
THanks!!!
Posted Sep 16, 2010 · 05:06 UTC#134
Very nice. All the crack does is crack the upgrade check. It doesn't touch any other files. What are the versions available for the EU version?
1.000 stock (can't get the files)
2.0000 EU 2010 Upgrade (i would want to take a look at those)
Anything else? Any 1.x updates or 2.x updates?
Dude, that was super risky though. If that's the case, this might be a universal crack for more devices than just Z110/Z120/F10/F20
*first post updated with this new information*
Posted Sep 16, 2010 · 05:40 UTC#135
No risk, no fun :D
For EU there is only the 2.0 EU update(F10->F20) and the 2.003 update available (the 2.003 EU has exactly the same files as the 2.003 US)
Nothing more.
What made me think that the hack should work, is that the US 1.001 update is also exactly the same as the AU 1.001 update as saiwogjai also mentioned. And also most of the 2.0 update is the same, excluding the maps, and some files which seem to store version numbers regarding the maps.
I have no clue about the files of other systems, but if the file-check is the same, you might be right.
But I think it is necessary to hack the 2.003 update too, for future updates, as it probably overwrote the hacked files on the unit. (I just have no idea why it does not show for me right version - does it show for US 2.003?)
The only thing I made maybe wrong is, I did first only the 3.1 BT update, then as I had the 2.003 and the 3.11BT update on the same card, it automatically installed the 2.003 first, before I could start the 3.11BT update.
Regarding mods, I havent found anything yet to get to the bitmaps, the image.img file is not a jffs2 filesystem image, I tried.
Posted Sep 16, 2010 · 06:08 UTC#136
No risk, no fun :D
Nothing more.
Actually, there is a 1.004 update for the F10BT. I don't know where it came from, but I got it from here:
viewtopic.php?f=34&t=29177&p=230536#p230536
We should probably make another forum for hacks based on system versions. It's no fun jumping from one site to another. By the way, I took a look at the U310BT/AVIC-F310BT and it turns out they use a very similar file system. They even have a RenewalIFLib.dll which I already took a look at. ;-)
This is making me realize that we should be comparing these similar files since hacks can be cross-device compatible (not hardware specific).
PS: I know what you're saying about hacking the 2.003 file, but in reality, I can easily make a fake 2.004 :)
Posted Sep 17, 2010 · 04:28 UTC#137
Next step, TESTMODE
According to the service manual we can get to test mode by:
Start-up by operation of the product.
1. Enter the following password while +B, ACC are ON (Normal application start-up status).
2. When the password is correct, restart begins and test mode menu is displayed.
1. Press [HOME] key.
2. Press keys in the order,
while pressing [HOME] key.
3. Release [HOME] key.
Start-up by SD card.
1. Download GGS1080 from the Service Site.
2. Decompress the file.
3. Copy the decompressed file to the SD card root.
4. Insert the SD card to the product and turn ACC on.
TestMode is actually an application built into the software. It's called TestMode.exe
It's packed inside EU090PLT.PRG
We need to unpack this file
Posted Sep 17, 2010 · 04:33 UTC#138
Yeah, we've been trying to find a copy of GGS1080.
I'm guessing the Service site is on Pioneer's intranet which requires us to either
A) Hack their network, which is uncalled for (I'M not going to Federal Pound-Me-In-the-Ass prison just for testmode)
or
B) Get a Pioneer tech/employee to slip us a copy.
Your thoughts?
Posted Sep 17, 2010 · 04:36 UTC#139
or
Your thoughts?
Unpack EU090PLT.PRG, extract TESTMODE.EXE, reverse engineer/patch.
Posted Sep 17, 2010 · 04:39 UTC#140
or
Your thoughts?
I'm not gay but I think I love you.
Posted Sep 17, 2010 · 05:39 UTC#141
Well, how about this:
ViewBin... EU090PLT.PRG
Image Start = 0x8EB00000, length = 0x017C2A1C
	Start address = 0x8EB01000
Checking record #165 for potential TOC (ROMOFFSET = 0xFF241584)
Checking record #241 for potential TOC (ROMOFFSET = 0xFF6F1580)
Checking record #403 for potential TOC (ROMOFFSET = 0xFFDA85A4)
Checking record #426 for potential TOC (ROMOFFSET = 0x00000000)
Found pTOC  = 0x902c09fc
ROMHDR ----------------------------------------
   DLL First           : 0x01C301CA
   DLL Last            : 0x02000000
   Physical First      : 0x8EB00000
   Physical Last       : 0x902C2A1C
   RAM Start           : 0x90B00000
   RAM Free            : 0x90B35000
   RAM End             : 0x9BD00000
   Kernel flags        : 0x00000002
   Prof Symbol Offset  : 0x00000000
   Num Copy Entries    :          3
   Copy Entries Offset : 0x8EF8DFB8
   Num Modules         :        215
   Num Files           :         45
   MiscFlags           : 0x00000002
   CPU                 :     0x01c2 (Thumb)
   Extensions          : 0x8EB03950
ROMHDR Extensions -----------------------------
   PID[0] = 0x00000000
   PID[1] = 0x00000000
   PID[2] = 0x00000000
   PID[3] = 0x00000000
   PID[4] = 0x00000000
   PID[5] = 0x00000000
   PID[6] = 0x00000000
   PID[7] = 0x00000000
   PID[8] = 0x00000000
   PID[9] = 0x00000000
   Next: 00000000
COPY Sections ---------------------------------
   Src: 0x8FBAE364   Dest: 0x90B06000   CLen: 0xC99      DLen: 0x2BCB8
   Src: 0x8F574BB8   Dest: 0x90B33000   CLen: 0x442      DLen: 0x4E4
   Src: 0x8FECEF64   Dest: 0x90B34000   CLen: 0x9C       DLen: 0x1D8
MODULES ---------------------------------------
   11/16/2009  07:19:16      410624  nk.exe
   11/16/2009  07:19:03       10752  aerhd.dll
   11/16/2009  07:01:00       11264  atserisr.dll
   11/16/2009  07:01:56      519680  coredll.dll
   11/16/2009  07:01:56      229376  filesys.exe
   11/16/2009  07:01:56      726528  gwes.exe
   11/16/2009  06:45:41        2560  device.exe
   11/16/2009  06:45:40       36352  devmgr.dll
   11/16/2009  06:45:41        6144  regenum.dll
   11/16/2009  06:45:41       13312  busenum.dll
   11/16/2009  06:45:40        9216  pm.dll
   11/16/2009  06:45:18       21504  notify.dll
   11/16/2009  06:46:00       80384  fatfsd.dll
   11/16/2009  06:46:01       10752  diskcache.dll
   11/16/2009  07:01:56       36352  fatutil.dll
   11/16/2009  06:45:10       69120  shell.exe
   11/16/2009  06:45:10        7680  shellcelog.dll
   11/16/2009  06:45:10        6144  toolhelp.dll
   11/16/2009  07:01:56      384512  commctrl.dll
   11/16/2009  07:01:55       66048  commdlg.dll
   11/16/2009  06:46:02      218624  gb18030.dll
   11/16/2009  07:01:56      123392  connmc.exe
   11/16/2009  07:01:56       34304  rnaapp.exe
   11/16/2009  06:45:17        8704  prnport.dll
   11/16/2009  07:01:56        4096  prnerr.dll
   11/16/2009  06:45:11       79872  fsdmgr.dll
   11/16/2009  06:46:02       19456  mspart.dll
   11/16/2009  07:01:56      105984  waveapi.dll
   11/16/2009  06:45:37       27648  audevman.dll
   11/16/2009  07:01:56       27136  gsm610.acm
   11/16/2009  07:01:56       15360  msfilter.dll
   11/16/2009  06:45:20       13824  ceddk.dll
   11/16/2009  07:01:56      206848  netui.dll
   11/16/2009  06:45:27      113664  ppp.dll
   11/16/2009  06:45:22       14848  asyncmac.dll
   11/16/2009  06:45:21       23552  cxport.dll
   11/16/2009  06:45:19       53760  iphlpapi.dll
   11/16/2009  06:45:17        5632  winsock.dll
   11/16/2009  06:45:16       36864  ws2.dll
   11/16/2009  06:45:25        8192  ws2instl.dll
   11/16/2009  06:45:25        8704  wspm.dll
   11/16/2009  06:45:25        9728  nspm.dll
   11/16/2009  06:45:26       30720  ssllsp.dll
   11/16/2009  06:45:12       12288  secur32.dll
   11/16/2009  06:45:14      113664  schannel.dll
   11/16/2009  06:45:15       47616  credsvc.dll
   11/16/2009  06:45:15        5632  credprov.dll
   11/16/2009  06:45:24       86016  afd.dll
   11/16/2009  06:45:22      133632  ndis.dll
   11/16/2009  06:45:19        6144  ndispwr.dll
   11/16/2009  06:45:26        7168  autoras.dll
   11/16/2009  06:45:26       27136  dhcp.dll
   11/16/2009  06:45:23      322048  tcpstk.dll
   11/16/2009  07:01:56       64512  tapi.dll
   11/16/2009  07:01:56       41472  unimodem.dll
   11/16/2009  06:45:28      135680  redir.dll
   11/16/2009  06:45:28       36864  netbios.dll
   11/16/2009  07:01:55      273408  crypt32.dll
   11/16/2009  06:45:13       41984  msasn1.dll
   11/16/2009  06:45:43       27648  serial.dll
   11/16/2009  07:00:58       18944  usbd.dll
   11/16/2009  07:00:58       17920  usbhid.dll
   11/16/2009  07:00:57       14848  usbmsc.dll
   11/16/2009  07:00:57       20992  usbdisk6.dll
   11/16/2009  06:45:58       28672  hidparse.dll
   11/16/2009  06:45:59        8704  kbdhid.dll
   11/16/2009  06:45:59        4608  conshid.dll
   11/16/2009  06:45:59        5120  MouHid.dll
   11/16/2009  06:45:42        6656  mmtimer.dll
   11/16/2009  06:46:32      171520  ole32.dll
   11/16/2009  06:46:33      180224  oleaut32.dll
    4/02/2004  08:46:34      432128  mfcce400.dll
    6/04/2004  08:31:08      282624  olece400.dll
   11/16/2009  07:01:57      119296  mlang.dll
   11/16/2009  07:01:57      131584  shlwapi.dll
   11/16/2009  07:01:57       28160  IECEExt.dll
   11/16/2009  06:47:30     1163264  msxml3.dll
   11/16/2009  07:01:57      450560  wininet.dll
   11/16/2009  07:01:57      285184  urlmon.dll
   11/16/2009  07:01:57       43008  aygshell.dll
   11/16/2009  07:01:57      282112  ceshell.dll
   11/16/2009  06:49:43        9728  shcore.dll
   11/16/2009  07:01:58       16384  control.exe
   11/16/2009  06:52:14        6656  ctlpnl.exe
   11/16/2009  07:01:58      215552  cplmain.cpl
   11/16/2009  07:01:58       50176  intll.cpl
   11/16/2009  07:01:58        9216  connpnl.cpl
   11/16/2009  07:01:58       22016  stguil.cpl
   11/16/2009  07:01:57     1286656  quartz.dll
   11/16/2009  07:01:57      384512  msdxm.dll
   11/16/2009  06:53:53       18944  msacmce.dll
   11/16/2009  06:53:59       11264  msadpcm.dll
   11/16/2009  06:53:59       10752  imaadpcm.dll
   11/16/2009  06:54:00       10240  msg711.dll
   11/16/2009  06:53:59       13824  msgsm610.dll
   11/16/2009  06:53:54       10240  icm.dll
   11/16/2009  06:53:53        5120  msrle32.dll
   11/16/2009  06:53:34       25600  msdmo.dll
   11/16/2009  06:54:00        5120  acmdwrap.dll
   11/16/2009  06:53:34       76800  mp3dmod.dll
   11/16/2009  06:53:36      905216  wmvdmod.dll
   11/16/2009  06:53:36      252928  wmadmod.dll
   11/16/2009  06:53:37      346112  wmsdmod.dll
   11/16/2009  06:53:56       73216  ddraw.dll
   11/16/2009  06:53:55      234496  ddcore.dll
   11/16/2009  06:53:56       89600  ddhel.dll
   11/16/2009  06:53:33      203264  ceplayer.exe
   11/16/2009  07:01:57       56320  repllog.exe
   11/16/2009  06:55:38        7168  udp2tcp.exe
   11/16/2009  06:55:37       49152  rapisrv.exe
   11/16/2009  07:01:57       58368  wceload.exe
   11/16/2009  07:01:57       13824  unload.exe
   11/16/2009  06:55:37       11776  rra_stm.dll
   11/16/2009  06:55:37        3072  eventrst.exe
   11/16/2009  06:55:38        2560  system.cpl
    7/01/2004  04:00:00      403968  sqlcese30.sys.dll
   11/16/2009  07:19:04        5120  ErrHandApi.dll
   11/16/2009  07:19:04       15360  ErrHandServ.dll
   10/31/2006  17:48:52       12288  resusage.dll
   10/31/2006  17:48:50       17408  dresusage.dll
   10/31/2006  17:48:50        6656  AstLogApi.dll
    7/18/2008  12:17:46       11776  logsaver.dll
   11/16/2009  07:19:05        5120  dwatchlatency.dll
   11/16/2009  07:19:05       10752  ALD.dll
   11/16/2009  06:45:36      137216  ddi_nop.dll
   11/16/2009  06:23:52       38400  NSystemInfoLib.dll
   11/16/2009  02:16:06      260608  NStandardLib.dll
   11/16/2009  02:16:06       73216  NEventBaseLib.dll
   11/16/2009  06:24:36      230912  NPCommonLib.dll
   11/16/2009  06:24:56      219136  FontLib.dll
   11/16/2009  06:25:24      723456  GraphicLib.dll
   11/16/2009  06:24:43       23040  IPILib.dll
   11/16/2009  02:16:06        6656  7z.dll
   11/16/2009  06:28:06       33792  NPVehicleHandler.dll
   11/16/2009  06:25:39       77824  NPuComHandler.dll
   11/16/2009  06:26:35      190464  NPSysCtrlHandler.dll
   11/16/2009  06:25:55       47104  NPRDSTMCHandler.dll
   11/16/2009  06:25:29       14336  NPPortLib.dll
   11/16/2009  06:26:47       63488  NPPnpHandler.dll
   11/16/2009  06:25:49       52736  NPMSNDirectLib.dll
   11/16/2009  06:26:53       25088  NPKeyHandler.dll
   11/16/2009  06:26:10       51200  NPInetHandler.dll
   11/16/2009  06:27:38      289280  NPGpsSnsHandler.dll
   11/16/2009  06:27:15       39936  NPGPSEngine.dll
   11/16/2009  06:27:10      177664  NPBTHandler.dll
   11/16/2009  06:26:02       14848  NPAviPodLib.dll
   11/16/2009  06:26:00       49664  NPAvDecLib.dll
   11/16/2009  06:25:44       30208  NPAudioLib.dll
   11/16/2009  06:28:21       38400  NEventWatcher.exe
   11/16/2009  06:30:37     1110528  TestMode.exe
    6/17/2009  08:22:02      215552  voHEAACDec.dll
    2/20/2009  07:46:22       18944  voVidDec.Dll
    2/13/2009  05:17:02        5632  BHSurfMgr.dll
    2/13/2009  03:10:32       92672  voAACDec.dll
    4/08/2009  06:49:10       45568  voAsfFR.dll
    4/24/2009  05:21:20       80896  voAudioFR.dll
    4/08/2009  06:49:10       32768  voAviFR.dll
    4/17/2009  05:36:36       18432  voCCRRR.Dll
    2/13/2009  05:19:34       83456  voCCRRRS.dll
    4/20/2009  01:37:10      281600  voFltFR.Dll
    3/12/2009  06:45:58      233472  voFltVR.Dll
    2/13/2009  05:28:44      113152  voMP3Dec.dll
    3/11/2009  09:51:28       45568  voMP4FR.dll
    3/17/2009  07:05:06      220160  voWMADec.dll
    4/21/2009  06:50:08       76288  h264decdll.dll
    4/21/2009  06:50:36       92672  mpeg4decdll.dll
    5/02/2009  08:07:44       83968  wmvdecdll.dll
    3/24/2009  02:28:28      152576  voPreview.dll
    3/17/2009  09:58:28       13312  voADPCMDec.dll
    5/20/2009  12:27:10       55296  voFltBuf.dll
    6/08/2009  15:30:54      267264  ddi_powervr.dll
    6/08/2009  15:30:42       66560  pvr_kernelm1.dll
    6/08/2009  15:30:50        7680  um3partyif.dll
    6/08/2009  15:30:50       23040  clcdckmif.dll
   11/16/2009  07:01:04       18432  VideoProcessNew.dll
    6/08/2009  15:30:48      193024  libGLES_CM.dll
    6/08/2009  15:30:48       27648  libpvrWCEWSEGL.dll
    6/08/2009  15:30:50       38912  IMGEGL.dll
    6/08/2009  15:28:10       72704  pvr_kernel.dll
    6/08/2009  15:28:16      410112  pvr_mved1.dll
   11/16/2009  07:00:55       43520  wavedev.dll
   11/16/2009  07:00:56      136704  usbotg.dll
   11/16/2009  07:00:56      136704  usbotg1.dll
   11/16/2009  07:00:57       22016  usbmsfn.dll
   11/16/2009  07:00:56       30720  USBSerialFn.dll
    3/18/2008  11:48:04       99328  UsbClientSwitch.exe
    3/18/2008  11:48:04        9216  cplswitch.cpl
   11/16/2009  07:00:58       14848  ipod.dll
   11/16/2009  07:01:02      773632  gps.dll
   11/16/2009  07:01:01        4608  vgd.dll
   11/16/2009  07:01:00       57344  atlasserial.dll
   11/16/2009  07:00:55       26624  touch.dll
   11/16/2009  07:00:58       43520  SDBUS.dll
   11/16/2009  07:00:59       30720  SDHC.dll
   11/16/2009  07:00:59       12800  SDMemory.dll
   11/16/2009  07:00:59       23040  SDIO_UART.dll
   11/16/2009  07:01:00       13824  CEATA.dll
   11/16/2009  07:00:55       14848  dsp.dll
   11/16/2009  07:01:01       36864  spidll.dll
   11/16/2009  07:00:54       17408  utldrv.dll
   11/16/2009  07:00:54       28160  sdmlc.dll
   11/16/2009  07:00:54       14848  PLOG.dll
   11/16/2009  07:01:02        5120  PIO.dll
   11/16/2009  07:01:02       10752  I2C.dll
   11/16/2009  07:01:03       14336  PdrdDriver.dll
   11/16/2009  07:01:03       13824  InfoMan.dll
   11/16/2009  07:01:03        4608  pwmdrv.dll
    7/10/2009  02:32:22       16384  usbwcm.dll
    2/23/2009  22:02:10      197632  ENTRFSD.dll
    2/23/2009  22:09:12      175104  ENTRUTL.dll
   11/16/2009  07:01:11        4608  launchapp.exe
    6/27/2008  04:34:38        4608  LastModeApi.dll
   11/16/2009  02:16:07      111104  GpsTmc.dll
    4/10/2009  12:17:30       98304  pbtctrl.dll
    4/10/2009  12:17:36       68608  pbtdata.dll
FILES ----------------------------------------
    11/16/2009  06:44:47  __R_          0      11680                ceconfig.h (ROM 0x901827A8)
    11/16/2009  07:19:19  _HRS          0     137110                 wince.nls (ROM 0x90185548)
    11/16/2009  07:19:19  _HRS          0      18598               initobj.dat (ROM 0x901A6CE0)
    11/16/2009  07:19:19  _HRS          0      36864                   boot.hv (ROM 0x901AB588)
    11/16/2009  07:19:19  _HRS          0     274432                default.hv (ROM 0x901B4588)
    11/16/2009  07:19:19  _HRS          0      36864                   user.hv (ROM 0x901F7588)
    11/16/2009  07:19:19  _HRS          0       7283                initdb.ini (ROM 0x90200588)
     7/01/2004  04:00:00  _HR_          0        134                 close.2bp (ROM 0x90027ED0)
     7/01/2004  04:00:00  _HR_          0        134                    ok.2bp (ROM 0x90027F58)
     7/01/2004  04:00:00  _HR_          0       1030                 stdsm.2bp (ROM 0x900988E8)
     7/01/2004  04:00:00  _HR_          0        838                viewsm.2bp (ROM 0x8EE618E0)
     7/01/2004  04:00:00  _HR_          0       2038                 stdsm.bmp (ROM 0x8FE2F808)
     7/01/2004  04:00:00  _HR_          0       1654                viewsm.bmp (ROM 0x8EF8D8C0)
     9/05/2006  10:31:38  _HRS          0     170960                rsaenh.dll (ROM 0x902021FC)
     7/01/2004  04:00:00  _HRS          0       8542              sysroots.p7b (ROM 0x9022BDCC)
     7/01/2004  04:00:00  _HRS          0     128844                tahoma.ttf (ROM 0x9022DF2C)
     7/01/2004  04:00:00  _HRS          0        739               copyrts.txt (ROM 0x90098CF0)
     7/01/2004  04:00:00  __RS          0       3116              asterisk.wav (ROM 0x8EF983D0)
     7/01/2004  04:00:00  __RS          0       3388                 close.wav (ROM 0x900222C0)
     7/01/2004  04:00:00  __RS          0       2970              critical.wav (ROM 0x8F835458)
     7/01/2004  04:00:00  __RS          0       2682               default.wav (ROM 0x8FFFD584)
     7/01/2004  04:00:00  __RS          0       3946                 empty.wav (ROM 0x8ED23090)
     7/01/2004  04:00:00  __RS          0       9204                exclam.wav (ROM 0x9024D678)
     7/01/2004  04:00:00  __RS          0       5656                infbeg.wav (ROM 0x9024FA6C)
     7/01/2004  04:00:00  __RS          0       1778                infend.wav (ROM 0x8FAED8BC)
     7/01/2004  04:00:00  __RS          0       2088               infintr.wav (ROM 0x8FD6E7B0)
     7/01/2004  04:00:00  __RS          0        834               menupop.wav (ROM 0x8EE61C28)
     7/01/2004  04:00:00  __RS          0        360               menusel.wav (ROM 0x8FACE88C)
     7/01/2004  04:00:00  __RS          0       3388              openprog.wav (ROM 0x8FD102BC)
     7/01/2004  04:00:00  __RS          0       1836              question.wav (ROM 0x8F83D88C)
     7/01/2004  04:00:00  __RS          0       8508               startup.wav (ROM 0x90251084)
     7/01/2004  04:00:00  __RS          0       2712               windmax.wav (ROM 0x8EEB1568)
     7/01/2004  04:00:00  __RS          0       2866               windmin.wav (ROM 0x8FFFA4C8)
     7/01/2004  04:00:00  __RS          0       3388              recstart.wav (ROM 0x8F00F2B4)
     7/01/2004  04:00:00  __RS          0       3388                recend.wav (ROM 0x8F3D02A8)
     7/01/2004  04:00:00  _HRS          0         24              ceplayer.lnk (ROM 0x8FC33FE8)
     7/01/2004  04:00:00  _HRS          0         24              eventrst.lnk (ROM 0x8ED01FE8)
     7/01/2004  04:00:00  _HRS          0      10752                 celog.dll (ROM 0x902531C0)
    11/16/2009  07:59:24  _HRS          0     262144       snapshot_mainos.dat (ROM 0x90255BC0)
    11/16/2009  02:27:40  _HRS          0     128844           tahoma_1_07.ttf (ROM 0x90295BC0)
    11/16/2009  02:27:40  _HRS          0       5360             PExtended.ttf (ROM 0x902B530C)
     1/22/2009  07:26:12  __RS          0       4096               mmvoflt.bin (ROM 0x902B67FC)
     1/22/2009  07:26:12  __RS          0       4096               mmvoflt.bak (ROM 0x902B77FC)
     3/18/2008  11:47:36  __R_          0       7168               GbcCtrl.exe (ROM 0x902B87FC)
     3/13/2009  15:32:20  __R_          0      26112                 GpsMC.exe (ROM 0x902BA3FC)
Done.
How do you feel now?
Oh and this:
TestMode.zip
Posted Sep 17, 2010 · 06:01 UTC#142
   Num Modules         :        215
   Num Files           :         45
   PID[0] = 0x00000000
   PID[1] = 0x00000000
   PID[2] = 0x00000000
   PID[3] = 0x00000000
   PID[4] = 0x00000000
   PID[5] = 0x00000000
   PID[6] = 0x00000000
   PID[7] = 0x00000000
   PID[8] = 0x00000000
   PID[9] = 0x00000000
   Next: 00000000
Done.
Welp.
I'm a 5-year Marine Corps Systems Engineer with 7 industry-level IT certifications, and am now a Computer Science major.
In short:
chicken's done.
pic related, it's my face right now.
Posted Sep 17, 2010 · 06:06 UTC#143
haha, i extracted TestMode already. I can repackage the PRG file now that I know how it works. I just feel like running haret on it and seeing if i can just port android for it. =P
Posted Sep 17, 2010 · 06:11 UTC#144
Ok so what does this mean?
Posted Sep 17, 2010 · 06:37 UTC#145
If I can get into TestMode, i can downgrade at will. It means we can play around with the system and not have to worry about bricking it. I'm trying to figure out how to trigger it.
Hmm, what's this?
A function called GetPBrakeStatus in NPVehicleHandler.dll?
Posted Sep 17, 2010 · 15:53 UTC#146
Short: Just throwing a little more love your way.......
Am I correct in guessing that Pioneer is using pretty much the same software for their other products (X910/X920), F series???
You have forced me to begin following this on my Android phone.....
Posted Sep 17, 2010 · 16:04 UTC#147
Yes for the 920 but the 910 and F series use different software. Regardless those units have been hacked for a while so this is irrelevant.
Posted Sep 17, 2010 · 16:20 UTC#148
Hmm, what's this?
I like the sound of that....
So basically, if things go awry, you're saying that you could boot into TESTMODE, and run one of Pioneer's updates to get things back in check? Granted if we can figure out how to boot into TESTMODE on a SD card...
Dude... good work Short-Fuse!!!
You've been steady, pulling rabbits out of the hat...
Posted Sep 17, 2010 · 17:27 UTC#149
Short, gimme your PayPal and RL addies. Want to send you $$$, beer and hookers 8)
Posted Sep 17, 2010 · 18:33 UTC#150
Hmm, what's this?
Seems like we will not need a bypass anymore? ;)
Man, running Android with haret sounds so cool :) it would require a lot more development though, especially without the exact specs, adresses, protocols to use the HW.
I would be already happy if using iGO or other apps would be possible, or using an Eye-Fi card and have internet access through an accesspoint...
Page 6 of 12
