Guys Thanks for all the detailed help.
I am havine one small problem though. When I tried to install the 1.002 i end up with a repeating loop that keeps rebooting my unit and telling me the the installation failed. Any thought on how I can get this to quit and allow me to get the SD card out.
Props to you guys SHORTFUSE THX Much
Enjoy..
None of this was my hard work it for sure took a team.
AVIC411 FTW
Download this file. Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse.zip
http://avic411.com/forum/download/file.php?id=9893 know the location of the file where you downloaded the file to on your hard drive.
Now Download this file from pioneer. 1.001000.zip
http://ds1.downloadtech.net/cn1010/firmware/1.001000.zip know the location of the file where you downloaded the file to on your hard drive.
Now open up your c:\drive and make a new folder called update.
Now in the folder c:\update extract the contents of both of the downloads into the folder c:\Update
Use winrar or what ever app you like that will uncompress files.
You should now have two folders with files now in the c:\updates folder.
c:\updates\1.001000 This has lots of files and folders in it.
and
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\ This will have three files in this folder.
Replace the file, in the following location
c:\update\AVICZ110\EU090APL.VER
with this file
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\EU090APL.VER
c:\update\AVICZ110\APL\RenewalIFLib.dll
with this file
c:\update\Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse\RenewalIFLib.dll
Format SD (Right click sd card under my computer and format) format in FAT32 the card needs to be 4gb or larger to complete all steps.
Now Copy the folder
c:\update\AVICZ110
to the root of an SD card.
Lets say your sd card is j: drive.
You will now have one folder on the j: drive.
j:\AVICZ110 (Plus all the contents of the folder.)
Now insert the SD to your Z110BT and it should start updating automatically.
Now how to do the update to os version 2.0
Once downloaded with your favorite utorrent client and unrared, you will have two folders that represent two separate SD cards.
You must install a torrent application, before the torrent file below will do you any good. Below are clients for both mac and windows.
Windows Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=win
Mac Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=mac
The update OS torrent file can be found here http://avic411.com/forum/download/file.php?id=9668
You can do all this from one sd card or two.
Once torrent is downloaded.
You will have a folder CNSD-110FM default location under c:\doc settings\your username\downloads
Open the folder c:\doc settings\your username\downloads\CNSD-110FM you will see two more folders
default location
c:\doc settings\your username\downloads\CNSD-110FM\SD1
and
c:\doc settings\your username\downloads\CNSD-110FM\SD2
Open these folders and extract contents with winrar to
c:\uploads\CNSD-110FM-SD1
c:\uploads\CNSD-110FM-SD2
TIME for another FAT32 format
Format your SD card in fat32 right click on the sd card and select format under my computer.
Copy content of folder c:\update\CNSD-110FM-SD1
and put it on the root of the SD drive.
lets say sd drive is is j:\ drive it really could be any letter f:\ u:\ c:\ k:\ .. I don't know the driver letter for your SD card. ( You do have a SD card reader RIGHT?)
you will have two folders and one file on j:\ drive
j:\Firmware (folder) plus all the content of the folder
j:\Update (folder) plus all the content of the folder
j:\CARDINFO.cif (file)
now take the sd card and put it in the z110bt
This will start the upgrade it will ask for serial.. just type leters until you can type no more.. (no numbers) letters only.Then continue. This takes about 25 min..
After OS install version 2.0 has been installed, the bluetooth needs to be updated two times.
With the same card you just updated the os with do the following steps.
a) press (Home button) to display top menu.
touch (system settings)
c) touch (bluetooth settings)
d) confirm bluetooth version is 2.50
e) scroll to bottom of list touch ( firmware update)
f) confirm update
g) after finish takes maybe 5-6 min confirm 3.10 version is now on unit under bluetooth setting page
h)once update finishes click ok. now eject sd card.
Get new SD card or format the existing sd card
i) copy content of c:\update\CNSD-110FM-SD2 folder onto the root of the new or cleanly formated sd card
j) press (Home button) to display top menu.
k) touch (system settings)
l) touch (bluetooth settings)
m) confirm bluetooth version is 3.10
n) scroll to bottom of list touch ( firmware update)
o) confirm update to 3.11
If I missed something please let me know.
Thx agian guys.
