Step by step update from z110bt to z120bt
By filezz · Sep 09, 2010in Hacks/Mods💬 222 posts👁️ 83,395 views
Page 1 of 9
Posted Sep 09, 2010 · 05:08 UTC#1
Props to you guys SHORTFUSE THX Much
Enjoy..
None of this was my hard work it for sure took a team.
AVIC411 FTW
Download this file. Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse.zip
Pioneer.Z110BT.Upgrade.Unlocker-ShortFuse.zip know the location of the file where you downloaded the file to on your hard drive.
Now Download this file from pioneer. 1.001000.zip
http://ds1.downloadtech.net/cn1010/firmware/1.001000.zip know the location of the file where you downloaded the file to on your hard drive.
Now open up your c:drive and make a new folder called update.
Now in the folder c:update extract the contents of both of the downloads into the folder c:Update
Use winrar or what ever app you like that will uncompress files.
You should now have two folders with files now in the c:updates folder.
c:updates1.001000 This has lots of files and folders in it.
and
c:updatePioneer.Z110BT.Upgrade.Unlocker-ShortFuse This will have three files in this folder.
Replace the file, in the following location
c:updateAVICZ110EU090APL.VER
with this file
c:updatePioneer.Z110BT.Upgrade.Unlocker-ShortFuseEU090APL.VER
c:updateAVICZ110APLRenewalIFLib.dll
with this file
c:updatePioneer.Z110BT.Upgrade.Unlocker-ShortFuseRenewalIFLib.dll
Format SD (Right click sd card under my computer and format) format in FAT32 the card needs to be 4gb or larger to complete all steps.
Now Copy the folder
c:updateAVICZ110
to the root of an SD card.
Lets say your sd card is j: drive.
You will now have one folder on the j: drive.
j:AVICZ110 (Plus all the contents of the folder.)
Now insert the SD to your Z110BT and it should start updating automatically.
Now how to do the update to os version 2.0
Once downloaded with your favorite utorrent client and unrared, you will have two folders that represent two separate SD cards.
You must install a torrent application, before the torrent file below will do you any good. Below are clients for both mac and windows.
Windows Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=win
Mac Utorrent client can be found here.http://www.utorrent.com/downloads/complete?os=mac
The update OS torrent file can be found here CNSD-110FM.rar
You can do all this from one sd card or two.
Once torrent is downloaded.
You will have a folder CNSD-110FM default location under c:doc settingsyour usernamedownloads
Open the folder c:doc settingsyour usernamedownloadsCNSD-110FM you will see two more folders
default location
c:doc settingsyour usernamedownloadsCNSD-110FMSD1
and
c:doc settingsyour usernamedownloadsCNSD-110FMSD2
Open these folders and extract contents with winrar to
c:uploadsCNSD-110FM-SD1
c:uploadsCNSD-110FM-SD2
TIME for another FAT32 format
Format your SD card in fat32 right click on the sd card and select format under my computer.
Copy content of folder c:updateCNSD-110FM-SD1
and put it on the root of the SD drive.
lets say sd drive is is j: drive it really could be any letter f: u: c: k: .. I don't know the driver letter for your SD card. ( You do have a SD card reader RIGHT?) :mrgreen:
you will have two folders and one file on j: drive
j:Firmware (folder) plus all the content of the folder
j:Update (folder) plus all the content of the folder
j:CARDINFO.cif (file)
now take the sd card and put it in the z110bt
This will start the upgrade it will ask for serial.. just type leters until you can type no more.. (no numbers) letters only.Then continue. This takes about 25 min..
After OS install version 2.0 has been installed, the bluetooth needs to be updated two times.
With the same card you just updated the os with do the following steps.
a) press (Home button) to display top menu.
B) touch (system settings)
c) touch (bluetooth settings)
d) confirm bluetooth version is 2.50
e) scroll to bottom of list touch ( firmware update)
f) confirm update
g) after finish takes maybe 5-6 min confirm 3.10 version is now on unit under bluetooth setting page
h)once update finishes click ok. now eject sd card.
Get new SD card or format the existing sd card
i) copy content of c:updateCNSD-110FM-SD2 folder onto the root of the new or cleanly formated sd card
j) press (Home button) to display top menu.
k) touch (system settings)
l) touch (bluetooth settings)
m) confirm bluetooth version is 3.10
n) scroll to bottom of list touch ( firmware update)
o) confirm update to 3.11
If I missed something please let me know.
Thx agian guys.
Edited Oct 21, 2010 by JasonH
Posted Sep 09, 2010 · 05:54 UTC#2
Sticked.
Posted Sep 10, 2010 · 20:17 UTC#3
How's it going? the first part worked great on the update. Now im trying to do the second half but the link to the torrent is a really small file 15kb and when extracted there is only one file called CNSD-110FM.torrent that still is only 15kb am I doing something wrong? Thanks so much. Anyone who helps me get this done I don't mind throwing a little something via PayPal to help out the cause.
Posted Sep 10, 2010 · 20:21 UTC#4
have you installed utorrent?
utorrent will know what to do with the small file, when you double click the 15k file.
The 15k file is a pointer to all the people that are seeding and doing peer to peer. Without a torrent application the 15k file is as good as trash.
You must install utorrent or some other torrent software.
I added link above in first post.
Posted Sep 10, 2010 · 20:37 UTC#5
Ahh.. that makes a ton of sense. Thank you.
Posted Sep 10, 2010 · 22:20 UTC#6
I'm getting a error that says invalid torrent file. Ive tried it every possible way for the last couple of hours. Not sure what I'm doing wrong.
Posted Sep 10, 2010 · 23:17 UTC#7
when you download the file. of the os 2
two things need to happen
1) winrar needs to be installed. http://www.rarlab.com/rar/wrar393.exe you will be able to open the rar file CNSD-11FM.rar
2) copy the file inside the rar file to the desktop and double click on it.
Posted Sep 10, 2010 · 23:27 UTC#8
I have winrar , did what you said and its not working. Winrar opens and the 15kb file is sitting there with a torrent extension on it. I click on the file and its asking me what program to use to open the 15kb file. I installed BitTorrent and its now downloading...
Posted Sep 10, 2010 · 23:36 UTC#9
the file you downloaded is a rar file. It has a torrent in it..
avic411 does not allow torrent files to be uploaded to the forums so it was put in rar format.
use winrar to get the torrent file to the desktop. you must extract the torrent file out of the .rar file
right click on the download and tell extract and tell it to extract to desktop or the uploads dir.
Now you can either double click the torrent file
Posted Sep 11, 2010 · 01:26 UTC#10
BIG PROPS to shortfuse & everyone else involved.
This is great & I love my unit all over again, but even more this time around! And you can't beat the price either!
FANTASTIC job everyone!!! :mrgreen:
Posted Sep 11, 2010 · 05:20 UTC#11
One word.... Fantastic! Follow the instructions carefully and to the T, everything is accurate. If it doesn't work, you did something wrong. I took my time,double checked and read every step thoroughly. Good luck and thank you.
Posted Sep 13, 2010 · 08:00 UTC#12
Thanks so much, I was about to crack down and purchase the update, again thanks
Posted Sep 14, 2010 · 15:49 UTC#13
thanks,it work!
Posted Sep 16, 2010 · 13:16 UTC#14
its been a few weeks since i've looked around here. Soo glad to know that there is a step by step process for updating the z110 unit. Its been on my 2 do list to purchase and upgrade but after reading this, i'm not forking out $200 if i don't have too ..
glad to know that these steps work flawlessly to make your z110 a z120 ..
Posted Sep 17, 2010 · 01:25 UTC#15
I can't figure out what I'm doing wrong. I have winrar and winzip. I am unable to extract the .torrent file using either program. I have the utorrent program installed. I am getting an "access denied" error when I try to extract the file to my desktop (or any location). I am an administrator on my computer. Please help!
Thank you in advance!
EDIT: Nevermind, I figured out the problem with downloading the torrent.
Posted Sep 17, 2010 · 02:10 UTC#16
I'm having issues with the 1.000 -> 1.001 update. The link to download the .zip from Pioneer yields a corrupted zip file and I can't seen to find the update files anywhere else. When I patch it with the two files and try an update, it just says "Installation failed" on my HU. Any suggestions or can someone provide the 1.001 files for me to patch? I should be good if I could just get this update to work! :?
Posted Sep 17, 2010 · 21:20 UTC#17
Works great the update in my AVIC-Z110bt, The GUI is awesome,if you follow the instructions everithing works fine. However the CNSD-OMM013, Optional Mexico Map (2009), didn't work anymore it said "Wrong Version", and for me is important because I live in México, I don't know if the 2010 version for Z110BT is going to work or I need the Avic-z120bt version of mexico maps. Any help is Welcome.
One question, in the future I have to download the updates for Z120BT or Z110BT?
Posted Sep 18, 2010 · 20:58 UTC#18
Just wanted to say WOW and THANKS! First I did the bypass then installed my Z110BT. Today I did the OS upgrade and it installed without a hitch. I used an 18GB micro SD card w/adapter for the main upgrade and a separate 2GB SD card for the final Bluetooth upgrade. I must say I miss the custom backgrounds we had with the D series, but this Z is such an improvement as far as the other things it supports (Bluetooth, USB stick, etc) it's well worth the price!
Thanks again EVERYONE!
Posted Sep 19, 2010 · 16:02 UTC#19
Everything went smoothly...liking it!
Posted Sep 19, 2010 · 17:10 UTC#20
Thanks SHORTFUSE
Everything worked great
Note: Bluetooth must be turned on to update
Posted Sep 19, 2010 · 19:02 UTC#21
Trying to update per instuctions. with sd1 update not progressing it says invalid sd card format any ideas. can't even get out of update. tried to disconnect deck and reconnect and still trying to update. any thoughts would help
Posted Sep 20, 2010 · 00:11 UTC#22
worked like a charm. no problems at all. just followed the directions to a 't' and am now rocking the updated version.
Thanks to all who made this possible!
Posted Sep 21, 2010 · 00:37 UTC#23
ok so I have done everything and it works great!!!!!! only 1 small problem I cant get the bluetooth 3.11 to work. When I put sd2 onto an sd card and i put it into the deck it will not allow me to click update, update will not even highlight. Any ideas?
Posted Sep 21, 2010 · 11:00 UTC#24
First, does your phone show as currently paired with the AVIC? If not, try pairing it.
Another idea...Maybe it can't update if there is an ongoing connection with the phone, so try turning the phone off.
Keep playing with it, you'll get it. And when you do, post the solution. We need to make the instructions fool-proof.
Edited Nov 07, 2010 by RonS
Posted Sep 21, 2010 · 11:18 UTC#25
Thanks for the advise I'll let you know what I find out.
Page 1 of 9
