Step by step update from z110bt to z120bt
By filezz · Sep 09, 2010in Hacks/Mods💬 222 posts👁️ 83,395 views
Page 3 of 9
Posted Nov 06, 2010 · 14:23 UTC#51
I am also trying to download the torrent but nobody seems to be seeding :(. If anyone could seed I would be most appreciative.
Thanks!!
Posted Nov 06, 2010 · 14:56 UTC#52
Hello,
i've tried multiple times and fails every time. Ive even redownloaded the files and tired from scratch ..... Any help would be great
This update is very simple. Assuming your files are not corrupt, which I doubt, then it must be something you are doing wrong. Since I can't tell from your post, why don't you spell out, in precise detail, exactly the steps you did to create your SD card. You can leave off the download and unzipping part.
Your SD should have one, and only one, directory in the root: \AVICZ110. This should contain:
Directory of SD \AVICZ110
  • <DIR> APL
  • <DIR> BOOT
  • <DIR> FONTS
  • <DIR> PLATFORM
  • EU090APL.HTM
  • EU090APL.VER
  • EU090BOT.HTM
  • EU090BOT.VER
  • EU090FNT.HTM
  • EU090FNT.VER
  • EU090PLT.HTM
  • EU090PLT.VER
...And a bunch of other sub-directories and files. I just listed these to be sure your copy to the SD was at the correct level in the directory structure. I assume yours was correct or you wouldn't have gotten as far as you did.
If the update still doesn't work, try another SD card, preferably a different brand.
Edited Nov 07, 2010 by RonS
Posted Nov 06, 2010 · 14:59 UTC#53
Thanks!!
Just an update I was using Vuze to download the torrent and that was not working and then I tried using utorrent and that worked perfectly. Just thought I would pass that along. Off to go and buy some SD cards!
Posted Nov 08, 2010 · 14:29 UTC#54
Cant update to 1.001 i downloaded the necessary files several times and once i put the sd card in it simply starts playing WAV audio files. Tried a different sd card but was the same brand. Im also using a micro sd with an adapter if that changes anything. I have downloaded the files and tried several times and everything is FAT32 formatted did both a quick format and a full format but getting same results.
Posted Nov 08, 2010 · 16:22 UTC#55
found out what the issue was with the initial update to 1.0001. Turns out the radio was already updated to 1.001 but on the system information screen it displays 1.0000. in order to see the that it is update to 1.001 you just got to the system information screen that displays 1.000 and hold the icon in the upper left corner and it will show the true system information. So if anyone is having the issue with the first update and it is simply playing the audio files from the SD card that just means that it has already been update so you can proceed to update to 2.0. Everything successful Great update.
Posted Nov 09, 2010 · 02:14 UTC#56
Got this done today, Worked just as stated.
Thanks !
Edited Nov 09, 2010 by Carlos F250
Posted Nov 09, 2010 · 06:59 UTC#57
Thanks for the great write-up, seeders pretty please?
txs
Posted Nov 10, 2010 · 04:00 UTC#58
Will this work if I already had updated firmware to 1.0001? Pioneer sent me an SD card with it and I had installed it a few months ago.
Posted Nov 10, 2010 · 06:05 UTC#59
Nevermind answered my own question. Everything worked great. Thanks a lot you guys!!!
Posted Nov 12, 2010 · 04:33 UTC#60
Hello,
I have A Z110BT running the version 1.0 firmware i never did the update to 1.001 and i came across this article so i figured i would give it a shot so i downloaded all the files and setup the first sdcard with the modded update just replaced the two files and when i run the update on the radio is does thru its thing and gets all 19 done at 100% then sits for 30 sec or so and then goes to updated failed. i've tried multiple times and fails every time. Ive even redownloaded the files and tired fro scratch ..... Any help would be great
I'm having this issue as well. It tries to restart the process to update automatically in a loop until i manually eject the sd card. any ideas?
Posted Nov 12, 2010 · 14:02 UTC#61
Yes, you're doing something wrong!
How could we possibly know what with so little information. You didn't even say which update you are trying. This thread is titled "Step by step update from z110bt to z120bt".
Assuming you mean the 1.001 update, start over with a different SD. Do the original Pioneer v1.0001 update first - with no modified files. If that works, install ShortFuse's files into the correct directories in the SD and do it again. With his patch, the verion should be v1.002 (or was it 1.003, can't remember).
If you can't get the plain old Pioneer v1.001 to work, then:
1. it is already installed
2. you aren't following the instructions correctly
3. user SD is bad
4. your AVIC is broke
Edited Nov 12, 2010 by RonS
Posted Nov 12, 2010 · 16:20 UTC#62
3. user SD is bad
haha. i fall into the stupid category of #2 for installing the patched v1.001. I was putting the RenewalIFLib.dll file into the first directory instead of the APL directory. everything went smoothly when I followed the directions. :) thanks ShortFuse!
Posted Nov 12, 2010 · 23:58 UTC#63
OK, issues here...I followed the instructions to a "T" and cant get past the first part. What am I doing wrong?
You should now have two folders with files now in the c:updates folder.
c:updates1.001000 This has lots of files and folders in it.
and
c:updatePioneer.Z110BT.Upgrade.Unlocker-ShortFuse This will have three files in this folder
Im not ending up with 2 folders in the "update" folder that I added. Im ending up with...
1 folder (avicz110)
1 file (EU090APL.VER)
the read me file and RenewalIFLib.dll
inside the Avicz110 folder is plenty of other things but not the shortfuse file
I have repeated the process over and over but no luck. Maybe its how Im extracting it?
I click the download links/save/my desktop
after both have finished dl'ing I right click them winrar opens and I choose to extract them to c:update
Thanks in advance, dont beat me up here!
Posted Nov 13, 2010 · 00:04 UTC#64
and
1 folder (avicz110)
you're just extracting the files in the folder within the zip. the 3 files (EU090APL.VER, RenewalIFLib.dll, and Read Me) are to be in their own folder according to HIS directions. this part doesn't matter so much as it is just organization. what IS important is that you move the RenewalIFLib.dll file into the APL directory of the AVICZ110 folder. if you do it correctly it will ask you if you want to replace the existing file. say YES. do the same for the EU090APL.VER file except this will be on the ROOT of the folder AVICZ110. once again, if done correctly you will be prompted with the request to replace it. say YES. Then, drag the AVICZ110 folder onto the SD card. voila!
Posted Nov 13, 2010 · 00:45 UTC#65
Success! Thanks so much. now on to the OS update...stay tuned, this could get ugly! Thanks again
Posted Nov 13, 2010 · 02:56 UTC#66
Its all good! Thanks to all who made this possible, your hard word is definately appreciated!
Posted Nov 14, 2010 · 16:21 UTC#67
Wow preciate it...took right away.
Posted Nov 14, 2010 · 17:31 UTC#68
Let me add to the chorus of thanks. Very smooth upgrade.
Are there any further updates/upgrades available after this? I am assuming this upgrade already has the latest maps & POIs.
Posted Nov 15, 2010 · 01:43 UTC#69
No and you assume correctly.
Posted Nov 15, 2010 · 07:21 UTC#70
Hi, two things:
1: I am trouble finding seeds - or maybe I'm not doing it right - is anybody else having issues?
2: I did the first 1.000 to 1.001 but it still says 1.000 on the info screen
Regards
Posted Nov 15, 2010 · 12:50 UTC#71
Hi, two things:
Regards
#1 - Can't help you there.
#2 - Did you follow the Pioneer update instructions (pdf file on Pioneer web site), step 5? This has been covered here many times . To see the internal version number:
  • Press the “HOME†key
  • Select the “Settings†tab
  • Select “System Settingsâ€
  • Select “Service Informationâ€
  • Press & hold left upper corner of the “Service Information†screen for a few seconds
If it doesn't say:
  • PlatformVersion: 1.001000
  • Application Version: 1.001000
then you didn't do it right. That is, unless you used ShortFuse's patch, in which case it would be 1.002000
Edited Nov 15, 2010 by RonS
Posted Nov 17, 2010 · 17:28 UTC#72
Don't forget, when updating the Bluetooth Firmware, your Bluetooth must be ON. If it is OFF, the "update firware" button will be greyed out.
I just finished the upgrade and installed the Version 2.003 that I downloaded from Pioneer Website. Now just to refamiliarize myself with the unit's interface. Can't wait to get back to the states so I can start using the Navigation unit. Currently in Turkey and using a stand alone Garmin Unit for the mean time. Too bad the AVIC-Z120BT doesn't use Garmin Maps. Those are all hacked.
Edited Nov 17, 2010 by spontaneous02jg
Posted Nov 18, 2010 · 20:00 UTC#73
ok, i have something confusing me. the SD1 file has 4 parts to it. opened 2 of them with winrar and they are both about 3.6GB with the same files inside. do i only use part one? or did something not DL correctly?
SD2 only has the one file in it. not multiple parts. so no confusion there.
Edited Nov 18, 2010 by skittlesRgood
Posted Nov 18, 2010 · 22:13 UTC#74
Edit: Nevermind I got it.
Edited Nov 18, 2010 by IvoryG
Posted Nov 18, 2010 · 22:55 UTC#75
You only need to extract the 1st file with WinRAR. It will know it's a multi-part archive. If you do all 4 parts individually, you WILL end up with 4 identical folders. Just choose 1 folder and delete the rest.
I did the same thing and it had me confused too.
Edited Nov 18, 2010 by RonS
Page 3 of 9
