Trying to download the torrent tonight, but nobody is seeding. Hopefully if I leave it open overnight it will pick up a few. Otherwise, anyone mind hoping on and seeding the file so I can get it?
Step by step update from z110bt to z120bt
Props to you guys SHORTFUSE THX Much
If I missed something please let me know.
Yeah, you forgot to mention how AWESOME YOU GUYS ARE~!
THANK YOU~!
Seeding right now. My seedbox has been acting up lately, sorry for the issues.
Woo Hoo....thanks. Went over to a friends and saw it was done when I got back. Thanks so much!
I will have to add when it came to the serial number portion...don't put in one string of letters. "aaaaaaaaaaa". I did just that and it came with "input password again?" When I changed it to "dklalfkjfklaflkj" (or something along those lines) it took it right away.
Mine wouldnt take aaaaaaaaaaaaaaaaaaaaaaa for the pass either. I put zzzzzzzzzzzzzzzzzzz and it took.
Thanks for the hard work guys. Update worked great!
Thanks again! I bought the update 2 months ago and then saw this page. I decided to use the hack and it works fine. Now I have an update card from pioneer that hasn't been used...
Throw it on ebay, you'd probably get most of your money back....
Hi is this working for the EU version to !?? (Avic-F10BT).
Unfortunately no seeders of the torrent anymore, I would like to get the new EU maps. ![]()
I clicked on the first link in the first message and it says it is a broken link. What has happened?
someone please host the file/link....
Yes it seems like the first link is down...
You guys, we JUST moved to new forum software... links are gonna be broken until the OPs fix them. Shortfuse just needs to re-upload his file.
I fixed the link.
I fixed the link.
The torrent file link still isn't working, for me atleast. Anyone else?
Update: I used the SD card torrent link from the other thread and downloaded the it successfully. It is in the process of installing right now. Will update of outcome.
Update 2: just finished all of the updates... they worked flawlessly. I went ahead and added 2.003 which also updated without a hitch. Thanks to everyone who worked on figuring this out! This forum has been a lifesaver since I got the unit last year.
I fixed the link.
Thx
havent lurked here for a few months and i was about to order the upgrade and just decided to check here and i couldnt believe i was reading someone cracked it! everything installed without any problems and i just selected a random string of numbers and it took just fine.
thanks to the people making it easy for us to do this. i will continue seeding the torrent.
Thanks for your appreciation and bandwidth ![]()
did exactly what the instructions said...it loaded untill 99% and says to insert correct sd card... any ideas? i restarted and it pops up the same screen to insert correct sd card. did the entire process over and im getting the same error. now nothing works. :/
I tried the First update... no dice. No update.
Fat32, copied the files as described.
I did find that if i have the z110 look at the SD card for audio it finds some sample WAV files. So i know it can read it fine.
advice?
I see from another thread that you finally got it to work. Good for you. Can you elaborate on the fix so you might help others who are similarly "challenged"?
BTW, please don't post nearly identical "HELP" messages in two places. You updated one with a "never-mind", but left this one hanging.
Hello,
I have A Z110BT running the version 1.0 firmware i never did the update to 1.001 and i came across this article so i figured i would give it a shot so i downloaded all the files and setup the first sdcard with the modded update just replaced the two files and when i run the update on the radio is does thru its thing and gets all 19 done at 100% then sits for 30 sec or so and then goes to updated failed. i've tried multiple times and fails every time. Ive even redownloaded the files and tired fro scratch ..... Any help would be great
Torrent link is not working for me.
Please send me the new link! or let me know if you start feeding it.
I need the upgrade!!!
Thanks a lot in advance
