Step by step update from z110bt to z120bt
By filezz · Sep 09, 2010in Hacks/Mods💬 222 posts👁️ 83,395 views
Page 4 of 9
Posted Nov 19, 2010 · 03:28 UTC#76
You only need to extract the 1st file with WinRAR. It will know it's a multi-part archive. If you do all 4 parts individually, you WILL end up with 4 identical folders. Just choose 1 folder and delete the rest.
I did the same thing and it had me confused too.
ooohhh ok. that makes sense. i figured it was something like that and went ahead with the update. it went just fine. only problem is im not sure if i like the new user interface lol.
Posted Nov 20, 2010 · 14:38 UTC#77
thanks i did this whole process yesturday and interface looks nicer, only thing about it tho im not sure if anyone else had this issue. My clock / GPS was correct before the update and now its incorrect. Although Navi works fine with current position etc, the clock is wrong and its pretty annoying how it relies on GPS for time. Is there a quick fix? please dont say its a "dashboard-take-apart-disconnect-cable" issue. I mean its only the clock but id like to have it correct u know? lol
Posted Nov 20, 2010 · 15:12 UTC#78
Did you ever try the user manual? Download the PDF file so you can search quickly, instead of relying on us.
Is it just the hour that is off? If so, make sure it is set for the right time zone, and the DST setting is correct for where ever you are located. You adjust by touching: Settings / System Settings / Regional Settings / Time.
Edited Nov 20, 2010 by RonS
Posted Nov 20, 2010 · 17:30 UTC#79
that did it thanks!, for noobs like myself i suggest a general thread topic "clock adjust AVIC z120bt" cz its not so obvious thanks again
Posted Nov 20, 2010 · 19:57 UTC#80
Yeah, thats why it comes with a big book with an index. You aren't serious, are you? If we had a sticky thread for every setting/feature, then, you know what they'd call this site? An OPERATION MANUAL.
Posted Nov 24, 2010 · 04:22 UTC#81
So, i followed everything and checked many times and here is what is happening. The first portion of the upgrade went fine. The problem i am having is the install of the OS version 2.0. I copied the files as stated and the SD drive has the three files as stated, i load the SD and it went through it's process and got to the serial number and i entered all letters as directed. The load said it would take 30 minutes, but after it reached 58% and 12 minutes remaining it stated i had an incorrect SD card and to insert the correct one. I tried restarting twice and each time it freezes at 58% and says to install correct SD card. What could i be doing wrong?
Posted Nov 24, 2010 · 09:43 UTC#82
I think that's a dashboard-take-apart-disconnect-cable issue.
Posted Nov 25, 2010 · 10:18 UTC#83
Hello Guys im having problems upgrading the OS! ive follwed the directions to the best of my ability! when i put the sd card in my avic it begins upgrading then gets to 58% then say "Wrong SD card" can anyone tell me what i am doing wrong? i downloaded the torrent from utorrent then i i got the two folders CNSD-110FM-SD1 & updateCNSD-110FM-SD2. i extracted the files from the CNSD-110FM-SD1 using win.rar then i copied them to the SD card! the update goes for about 58% then stops and tells me to insert the correct SD card!! ive erased everything and started from scratch, but im still having the same problem!! PLEASE HELP GUYS!!!
Posted Nov 29, 2010 · 03:44 UTC#84
It just floors me to think, that someone could make it through the upgrade process, yet turn around and ask for a sticky on how to adjust the time....
I have my "blonde" moments also.... But maaaannnnnn....
Come on?????
LMAO!!!!!
Posted Nov 29, 2010 · 03:46 UTC#85
Although your error message, is pretty much to the point,.... I HAVE to ask the OBVIOUS....
Have you tried a different SD card?
Check this out as well...
http://avic411.com/index.php?/topic/29150-cracking-the-z11020bt-f10f20bt-included-region-changing/page__st__195
Edited Nov 29, 2010 by dawgbone
Posted Nov 30, 2010 · 00:38 UTC#86
Sorry for the newbie question. I have searched for a new torrent because the link keeps trying to take me to Limewire of which is closed now. I can't seem to find the same torrent anywhere else. Where can I find it?
Thank you in advance.
Posted Nov 30, 2010 · 19:17 UTC#87
Ok I am at the OS2.0 update on my z110bt. But when I open the file for "c:uploadsCNSD-110FM-SD1" There are files labeled part1 part 2 part 3 part 4 and only part 1 will unrare with the files
j:Firmware (folder) plus all the content of the folder
j:Update (folder) plus all the content of the folder
j:CARDINFO.cif (file)
So I transfered these to the sd card and inserted after doing part one.
When I try and update after about halfway it states wrong sd card please insert the correct one. What did I do wro
Posted Nov 30, 2010 · 21:58 UTC#88
First, you did download all 4 parts, right? You only need to unrar the 1st part, they are all linked within the archives, so if you used WinRAR, it will extract all the files into a single folder.
Just to be sure that you have all the files on the SD, insert it in a PC and check Properties. What is the used size of the SD?
It should be 3.6 GB.
Try again, maybe with a different SD.
Edited Nov 30, 2010 by RonS
Posted Dec 01, 2010 · 01:29 UTC#89
Did anyone solve this? I asked the exact same question a week ago and not one reply. I really enjoy looking at all the cool things the talented ones out there do, but i am bummed that after i joined and hoped to utilize the cool upgrades, no one will help me figure out why the sd card error keeps doing exactly as descibed in this post. I am now on the verge of buying the upgrade just so i can have my system back. Please help anyone who can solve this 58% then error issue.
Posted Dec 01, 2010 · 04:31 UTC#90
OK, i figured it out on my own! When you format the SD card to FAT 32 be sure to select default allocation size. I found that the file size on the SD1 file on my card was set to the smallest value and once i re-formatted to the default allocation size, it worked fine! I have no idea what that does, but hey, i'm all good and love the upgrade! Thanks to all those who worked to provide the details and take the time to provide the solutions to the issues raised on this site!
Posted Dec 01, 2010 · 04:39 UTC#91
Maybe its because the same question has been asked and answered so many times. You expect a different answer?
How can anyone here know what you are doing wrong with so little info?
Unfortunately, many of those posters never follow up with what fixed it for them.
So, other than repeating the exact same advice, my response is go back and try again. Read the instructions and make sure you understand every step. Either you have missed something, or you have a hardware problem.
Posted Dec 03, 2010 · 15:57 UTC#92
No one is seeding this - does anyone have the file that I can download?
CNSD-110FM
Posted Dec 05, 2010 · 16:14 UTC#93
Trying to update per instuctions. with sd1 update not progressing it says invalid sd card format any ideas. can't even get out of update. tried to disconnect deck and reconnect and still trying to update. any thoughts would help
Did you ever figure out how to solve this problem I am stuck !?!? Please if yo have any information Email me or respond
[email protected]
Posted Dec 06, 2010 · 03:16 UTC#94
I was having the same problem as any of you. Once I tried to load th OS system it would get half way and then tell me to insert the correct SD card. I formated the card many times and still came up with the same screen. I then re downloaded the torrent and all its files. Reinstalled the files on to the same SD card. And IT WORKED!!!! The new OS looks cool but I'll have to wait until tomorrow to play with cause I spent all day trying to fix this problem. Just wanted to share.
Posted Dec 06, 2010 · 21:38 UTC#95
Silly question, but after following the steps in the first post do you still need to to do the 2.03 update?
Posted Dec 07, 2010 · 18:25 UTC#96
No you dont if you follow step by step the first post bro , you will be fine. Its easier to use two SD Cards but all this could be done by 1 SD. The whole process will take about 30 min , unless you have the same problem I did at first and my download was corrupt. But after re downloading every thing went through with out a flaw.
Posted Dec 13, 2010 · 14:26 UTC#97
CNSD-110FM
I can't find it either. If you get it before me would you mind passing on that information. Thanks.
J
Posted Dec 13, 2010 · 15:39 UTC#98
Good Morning Guys,
When I load the SD card, it asks for a password. I have tried many different sequences (no numbers). It keeps asking me to input password?
Does this mean the file is corrupt? Any advice would be great.
Posted Dec 13, 2010 · 17:13 UTC#99
Good Morning Guys,
Did you install ShortFuse's hack?
Posted Dec 23, 2010 · 13:15 UTC#100
This is unbeleivable! I was in the market to upgrade my map data and I figured there had to be something on this forum! Thank you sooo much!
Page 4 of 9
