Cracking the Z110/20BT: F10/F20BT included? Region changing?
By ShortFuse · Sep 04, 2010in Hacks/Mods💬 290 posts👁️ 108,600 views
Page 8 of 12
Posted Oct 08, 2010 · 23:10 UTC#176
Unfortunately no seeders of the torrent anymore, I would like to get the new EU maps. :)
it was DHT screwed for me
Posted Oct 09, 2010 · 23:32 UTC#178
Tried the instructions and the update stopped at 20% with a "incorrect SD card failure" Tried again with different SD cards and it still gets stuck at 20%. Redownloading the image doesn't seem to change either. Is there anyway to unbrick the unit or something else to try?
Posted Oct 09, 2010 · 23:38 UTC#179
Does the unit start the update process when you power up with the SD card or is it now bricked? Make sure you format the SD card to FAT32 and dump the files on there.
Posted Oct 10, 2010 · 00:18 UTC#180
If I powercycle the unit with the SD card in, it will start the update process again for about a minute and then say the SD card is incorrect. I went and bought a new 4Gb SDHC card and did a low level format in FAT32 just to make sure it wasn't my card. =(
Posted Oct 10, 2010 · 23:45 UTC#181
So after extracting the contents of SD1 on my desktop (and not on c:\update) and copying the contents to the SD card, I was able to get one of my Z110BT units to upgrade. On my other Z110BT, (which had also failed at 20%) I went into service mode and selected the "Clear User Info" portion. Now when I boot the unit, I get a "An error occurred when updating" message. It gives me the option to click "Retry" but it just returns me to the error message as soon as I click it. Is there a way of starting the process over again?
Posted Oct 11, 2010 · 14:16 UTC#182
How did you get into service mode?
Posted Oct 11, 2010 · 15:33 UTC#183
hi all
so there's no way for me to get updated file via torrent any more?
anyway or anyone can help me to get the file for updating?
would really appreciate it, thank you!
K.J
Posted Oct 11, 2010 · 17:32 UTC#184
hi all
K.J
the torrent still works but you must have "DTH" enabled in utorrent.
and I tried to get updated to work on the "EU" ver but it did not!
was told that there was no usable software ...
its possubel that the Flach back with the first software!
tried all possible variations to get it work, and force write in "service mode" (mode right-left ...) so it says 2000. in almost all parts but it refused to start, so may be that Pioneer has a few diodes to set the version of the device you are using hardware that prevents regional change, Sony has this on several of its units.
However, this should go o see via schedule or on the motherboard near the CPU, some
diodes or jumpers are not soldered ...
Posted Oct 11, 2010 · 22:38 UTC#185
Started the unit and Pressed "HOME" "L/R, L/R, L/R, L/R" and then the "clear user data portion"
Posted Oct 13, 2010 · 11:55 UTC#186
Shortfuse... It looks like to get into Service Mode/Test Mode all you have to do is once the unit is powered up. Hold the Home button then press the right arrow, left arrow, right arrow, left arrow, right arrow, left arrow, and release the Home button. This will reboot the unit and you will be in Service Mode/Test Mode according to the Service Manual. I tested this and it worked without a problem. At first I made the mistake of thinking it was left right left right left right... There is a file management option in the Service Mode which appears to let you copy and paste in the directory structure. I'm not sure if this means that if we had some files on an SD card if we could replace the same system files using the File Management section in Service Mode. Hope this helps any. :' )
Posted Oct 14, 2010 · 20:58 UTC#187
Real TESTMODE File!! 8)
TESTMODE GGS1080.rar
Posted Oct 14, 2010 · 21:20 UTC#188
And what does this do?
Posted Oct 14, 2010 · 21:54 UTC#189
You asked for it, now I have successfully found it! :-D
2. How to Start-up Test Mode
Start-up by operation of the product.
1. Enter the following password while +B, ACC are ON (Normal application start-up status).
Start-up by SD card.
1. Download GGS1080 from the Service Site.
2. Decompress the file.
3. Copy the decompressed file to the SD card root.
4. Insert the SD card to the product and turn ACC on.
2. When the password is correct, restart begins and test mode menu is displayed.
1. Press [HOME] key.
2. Press keys in the order,
while pressing [HOME] key.
3. Release [HOME] key.
But it's just a faster way to get into test mode (you do not have to hold the Home button, Left, Right .....)
Posted Oct 15, 2010 · 05:21 UTC#190
You know what, it's funny because I actually posted that information here:
viewtopic.php?f=57&t=34478&start=135#p230618
Over 6 weeks ago, but I completely forgot about it. I disregarded it because I didn't understand what +B and ACC meant, but I didn't even try out the combination.
It seems like we can do some hacking without bricking. =D
Edit: Just saw you posted the key.
Very nice! Where'd you get it?
But how do you access the SD if the machine is bricked and won't open?
Posted Oct 15, 2010 · 06:27 UTC#191
I'm not sure but should go through the USB?
I think that you can always open o access the SD card even if you happen to make a misage, i haw accidentally delete o mixing software (old with new) and try to upgrade my device, but it just will not! have tested your files o mixed them with the new but to no success :-( However, successful transfer some files manually now, so I've seen a glimpse of the new software, (forced Writing, and evriting looks ok but, ("no applicate program") but it does not work at all as it should, check it in the info on the stereo you get the answer remains that it is an AVIC-F10 do not really know what to do:-S I can drive back the upgrade (org Program), it starts automatically! but neither one of the files except the hacked...
Service Manuals:
F10
Download AVIC-F10BT.pdf (25.3 MB) for free on uploading.com
F20
Download AVIC-F20BT.pdf (4.3 MB) for free on uploading.com
pass "avic411"
Posted Oct 15, 2010 · 15:08 UTC#192
Soooo... are you saying that if you managed to get the system to a point that it will not boot...you can always get to TESTMODE by using the GGS1080, and re-apply the non-hacked update? And everything works again?
And can you actually boot from the USB, in the event that you cannot open the touchscreen to insert a SD card?
This would be very kewl if so...
Posted Oct 15, 2010 · 22:02 UTC#193
Subscribed! Following this. Thanks to the OP for all your work on this and anyone else that has contributed!
Posted Oct 16, 2010 · 01:15 UTC#194
hey i purchased the CNSD-110FM upgrade online and supidly didnt realise that it would be different for different countries :oops:
is there any way i can get the AUSTRALIA version without having to buy it again? seeing as i have a legitimate media number and the 2 SD cards...
thanks
Posted Oct 20, 2010 · 10:08 UTC#195
my unit has lost "nand data parts code" (no_set)
I check on the self-check program say it!(Nand Flash) !!ERROR!!
can I somehow transfer these files manually from the upgrade?
where will these be that case? "NDATA" is empty on the device.
it refuses to start updating automatically:
All files located on SD card.
j: Firmware (folder), plus all the content of the folder
j: Update (folder), plus all the content of the folder
j: CARDINFO.cif (file)
any ideas?
Edited Oct 20, 2010 by 4x12Tum
Posted Oct 22, 2010 · 19:51 UTC#196
any ideas?
now I have sent in my stereo for repairs
Posted Oct 26, 2010 · 05:34 UTC#197
Yes, this is a special 1.001000 update. It's actually marked as 1.002000 which is why it updates.
In reality, you can do it all with just one SD card. The updates can be found on torrents. SD1 is 4GB. SD2 is just 2 megabytes.
Hi, i still dont know where to download the SD1 and SD2 files. What is the files called? Can someone please help?
Posted Oct 26, 2010 · 15:32 UTC#199
Awesome....
Posted Oct 26, 2010 · 23:41 UTC#200
HOLY CRAP! Froze at 98% and said
INCORRECT SD CARD. PLEASE INSERT THE CORRECT ONE.
My heart jumped. I found out the issue. I fixed it and it installed now. I'm going to test it and play with it now.
Bluetooth AVRCP isn't working but I just remembered I haven't done the bluetooth upgrade. I'm doing that now...
Yeah, that was it. It's working now. This definitely not worth the $200. I'm making a file now.
this is the problem i have how do i fix it??
Page 8 of 12
