Upgrade from v2 to v3..(EU UNITS ONLY)
By CdRSKuLL · Mar 06, 2010in General💬 64 posts👁️ 33,748 views
Page 2 of 3
Posted Jun 04, 2010 · 18:08 UTC#26
You should make sure you have everything downloaded before starting.....
1.. Wince - This is used to update the operating system of your] headunit
2.. Testmode - This is used to access the unit so you can get to the files.
3.. Flashdisk - This holds the pioneer application which you see when you start the unit off.
You need to install them in this order. Make sure you have a 2GB SD card and have the folder 'flashdisk' ready to copy over via the windows CE desktop on your unit. This is why Testmomde is used, so you can get to the desktop.
hope this helps
Posted Jun 13, 2010 · 10:19 UTC#27
Hi
Will I be able to use LeetLauncher if I upgrade to v3?
Posted Jun 17, 2010 · 11:51 UTC#28
Hello, OK now i have version 3.02000.....
New wince , new FM100 (my flash disc), and new upgrade from Pioneer website.
But map for Europe are very old (before updating was from 2007, now are from 2008) but Tele Atlas, Ceda and diferent has map 2010 for IGO8.3 When i changed map on flash disk to new map does not work and are not in list :/ But there are same typ maps for IGO 8.3.
Do you now anybody were is problem ? On Czech website i read then i need cracked IGO when i have not crack IGO is not posible changing maps ?
But is posible reinstal IGO ? or what with this ???
Here on the web is enithing about cracket ezrider, but when i reinstal ezrider navigation dostnt work completly (was only funcrion audio and video)
Can be possible ... then here in cracked FM 100 (to version 3.00300) is maeby cracked IGO, but when i in next step update to version 3.2000 i rewrite IGO without crack ???????
thank you
Posted Jun 18, 2010 · 20:36 UTC#29
just from memory to use a new map you need to change the launcher or the program to start it off. think thats right.. it has been a few months since I did it. Have a search on here I'm sure there's something about it. It's where I found it :-)
Steve
Posted Jun 28, 2010 · 08:27 UTC#30
Sorry but i dont understand you.
You have AVIC F700/900 Europe with new maps (2009/2010) ? And wat did you changed map and ???? and what ???
Ezrider ? Copplet IGO ? Or what ? and where a can search this ????
On Pioneer website is now new maps (SD card) with 2010 CNDS-200FM but here is not nothing about this :/
Posted Jul 06, 2010 · 12:03 UTC#31
Hi Steve,
Do you know if it would be possible to reverse the process should something go wrong on not work? to be honest im not very good with these things and also unlucky! im wondering if i can go back to original setup if all fails, or eventually use an original upgrade to the cnsd-200fm for instance.
Jim
Posted Jul 06, 2010 · 12:46 UTC#32
back up your existing avic disk and store it somewhere safe.
Posted Jul 06, 2010 · 12:50 UTC#33
Posted Jul 06, 2010 · 12:51 UTC#34
and how do I do that? (pls excuse my ignorance!)
Rgds
Jim
Posted Jul 06, 2010 · 12:53 UTC#35
Honestly, if you aren't willing to at least search the forum to find out how to back up your existing files, maybe upgrading isn't something you should be doing..
Posted Jul 06, 2010 · 13:10 UTC#36
One thing im not is lazy! beleive me i have looked but cant seem to find...
tnx anyway!
Posted Jul 11, 2010 · 10:21 UTC#37
The units just like a computer really. You have your operating system, in this case Windows CE and pioneers software.
As standard the unit is set to load the pioneer software as default, you can if you wish use the testmode sd to bypass this default and go to the operating system. From here you can 'backup' the flashdrive folder. (flashdrive is just the name of the folder) This is the pioneer software.
The most important thing is upgrading the WinCE part. This is like formatting your laptop and reinstalling windows 7. Once this is done you can play around with the pioneer software. :-)
Let me know how you get on. I'm still yet to install my unit in my car... tis a very special Murcielago kitcar it's going in.... one day :-)
Steve
Posted Jul 13, 2010 · 11:49 UTC#38
Hi Steve,
Thanks for this great tutorial, tried it yesterday evening, works like a charm :D
I'm a happy f900 eu user now...
Posted Aug 03, 2010 · 23:10 UTC#39
Another thank you - brilliant tutorial and worked no probs for me.
Going to try the additional Pioneer update tomorrow eve.
Posted Aug 09, 2010 · 01:31 UTC#40
Anyone done this with an Australia unit (with aussie maps)?
If not am i able to install the 3.0 firware and keep the old maps?
Cheers.
Posted Aug 13, 2010 · 07:36 UTC#41
1. latest WinCE version from 3.0202 EU.. http://www.cdrpro.co.uk/wince.zip
2. Testmode 2.3.. http://www.cdrpro.co.uk/testmode.zip
2. Copy of 3.000303 Flash drive.. viewtopic.php?f=34&t=26625&p=182800#p182768 (I had to use the par files to correct the croupt data)
3. Upgrade 3.00202 from pioneers website.. http://www.pioneer.eu/files/support/avi ... 020200.zip
In this you mentioned you need a copy of 3.000303 flash drive aswell as upgrade version 3.00202 from pioneers website. Do i really need to get both of these or what?
Posted Aug 14, 2010 · 18:13 UTC#42
yep.. the 3.000303 is what you update the unit to first as this is what's available. Then you upgrade again using pioneers FREE update for all those running version 3.
There is however a new version update which I've not managed to get hold of yet, soon as I do I will put some update instructions up. :-)
Steve
Posted Aug 16, 2010 · 08:18 UTC#43
ok cheers, do you know if there is much difference between the 2 versions? Its just I read earlier in the topic that some people had problems when installing pioneers free version over the top.
Posted Aug 16, 2010 · 08:44 UTC#44
I think there's a changelog on pioneers website with details of the update. I'm after the latest update at the moment, anyone care to share.. for experimental purposes only mind ;-)
Posted Aug 16, 2010 · 11:43 UTC#45
is it version 4.0 you are trying to get?? I am also trying to find that but as yet nothing has been posted and cant find any torrents etc.
Posted Aug 22, 2010 · 10:00 UTC#46
Hi, i have "vf_claire_r40_83swf11_165_04.dat - CRC failed" when i unrar the file, how to solve that ? Thanks for your helping
Posted Sep 02, 2010 · 16:30 UTC#47
I have a problem with WinCE. Does anyone can help me. Mine was successful make 15 steps. My unit starts format Flash disk, but about 30 secunds (44 percent of all formats) Screen goes black and thats all. What do to. Are there any other options for updating WinCe. I attaced a video file.
1. format an SD card on your PC using the FAT32 file system
2. Check that your SD has no files on it
3. Copy from the files WINCEIMG.BIN and WINCEIMG.CKS from the above zip to the root dirctory of your new SD card
4. Verify the only files on the new SD card are WINCEIMG.BIN and WINCEIMG.CKS
5. Boot your avic into the service mode using the next steps
6. Power on the AVIC
7. When the boot screen appears, Press and hold in the Menu, Map and Eject buttons
8. Press the reset keep pressing in the eject button , Menu, Map.
9. You will see Blue screen with the words "Please push reset key again", you can now let go of the keys
10. Enter the password, Press UP, UP, DOWN, MENU, LEFT, RIGHT
11. You will now be in the service menu.
12. Its a good idea to test the Bluetooth while you are here so do that if you like. NOTE: Option 2 in the bluetooth menu will bot work with a special cable
13. Go into the WINCE Upgrade menu
14. Insert the SD card we made in the first 6 Steps
15. Select the first option, "WINCE by SD/MMC (Format). This will reformat "My Flash Disk"
Posted Sep 06, 2010 · 11:06 UTC#48
mines doing exactly the same, step 15. from
16. The Winceimg files will now copy into flash. This takes about 5 mins to complete. On the bottom of the scree you will see this as it's done.
17. Wait till you asked to restart
18. Press the reset button again.
i downloaded the 3 files from viewtopic.php?f=32&t=31236 which comes to 1.49gb, i put that onto the sd card and copy that to the My flash disk and wait 20 mins but when i restart nothing happens.
what am i doing wrong? now i put the 3 files on the sd card and copy them onto My flash disk but when i restart i get my splash screen then nothing
i saw on another post that on the sd card you should have 19 icons http://www.imagebam.com/image/5fa19542574343
but i only got the three from the downloads
help please
thanks
Posted Sep 12, 2010 · 14:11 UTC#49
Thanks a lot.
Your wince brought my F910 back to booting from the SD. Reinstalling all the files got the whole system back in track.
Posted Sep 30, 2010 · 20:49 UTC#50
Hi everyone,
Great forum and thanks for all your efforts.
I just carried out the update, all as recommended and went fine. Then I applied the Pioneer update, went fine.
Everything works but the unit stopped remembering the last used audio source. That is, when I listen to the radio and switch off the engine, go buy a pack of fags or whatever, turn the engine on, and it always starts in USB mode and plays folder 1, song 1. I can of course manually switch to radio, but before I do, I have song 1 in folder 1, always.
It actually starts driving me nuts. What do I do? Is there some config file where I can tell the unit to remember that I was listening to radio before getting out?
Thanks for all suggestions.
benski
Page 2 of 3
