First thanks for the many posts and advice (some of which I have copied and pasted in here).. i thought I would just post this to help others..
This upgrades a F700BT / F900BT from Firmware 2 to 3.020200 for FREE..
ok.. 1st I would collect the files you need.
used on my F900BT Europe (UK) version
This is for a EU unit..
1. latest WinCE version from 3.0202 EU.. http://www.cdrpro.co.uk/wince.zip
2. Testmode 2.3.. http://www.cdrpro.co.uk/testmode.zip
2. Copy of 3.000303 Flash drive.. viewtopic.php?f=34&t=26625&p=182800#p182768 (I had to use the par files to correct the croupt data)
3. Upgrade 3.00202 from pioneers website.. http://www.pioneer.eu/files/support/avi ... 020200.zip
You will need 1 SD 2GB Card to do this.
1st upgrade your WinCE Version
1. format an SD card on your PC using the FAT32 file system
2. Check that your SD has no files on it
3. Copy from the files WINCEIMG.BIN and WINCEIMG.CKS from the above zip to the root dirctory of your new SD card
4. Verify the only files on the new SD card are WINCEIMG.BIN and WINCEIMG.CKS
5. Boot your avic into the service mode using the next steps
6. Power on the AVIC
7. When the boot screen appears, Press and hold in the Menu, Map and Eject buttons
8. Press the reset keep pressing in the eject button , Menu, Map.
9. You will see Blue screen with the words "Please push reset key again", you can now let go of the keys
10. Enter the password, Press UP, UP, DOWN, MENU, LEFT, RIGHT
11. You will now be in the service menu.
12. Its a good idea to test the Bluetooth while you are here so do that if you like. NOTE: Option 2 in the bluetooth menu will bot work with a special cable
13. Go into the WINCE Upgrade menu
14. Insert the SD card we made in the first 6 Steps
15. Select the first option, "WINCE by SD/MMC (Format). This will reformat "My Flash Disk"
16. The Winceimg files will now copy into flash. This takes about 5 mins to complete. On the bottom of the scree you will see this as it's done.
17. Wait till you asked to restart
18. Press the reset button again.
You have now re-flashed your AVIC but "My Flash disk" is empty. We now need to reinstall the Files
Next re-install the Flash Drive
You will need 2gb SD Card for the next part
1. Extract the testmode.zip to the root of the SD Card
2. Extract the archive avic f900_700_500 ver_3.000300.rar to the root of the SD card
Your SD Card root directory will look like
Testmode
My Flash Disk
3. Boot from the SD Card in your F900BT unit, you will be presented with the Windows Mobile desktop.
4. Open Explorer and locate the "MY Flash Disk" on the main unit (not the My Flash Disk on the Storage Card) and delete everything from inside it. ONCE YOU HAVE REACHED THIS POINT,DO NOT SWITCH OFF UNTIL YOU HAVE COMPLETED THIS TUTORIAL.
5 Navigate to the Storage Card and into the "My Flash Disk" directory. Select EDIT and SELECT ALL, then select EDIT and COPY. Navigate back to your "My Flash Disk" inside the main unit and select EDIT and PASTE.
Wait 15 minutes for it to complete, and once done you can restart the unit. You can then update to 3.020200 using the standard Pioneer update.
NOTE - I couldn't manage to tap on my EDIT button at the top of the screen until I had calibrated the screen (think the option was in contol panel) so.. start button, control panel.. or settings, something like that ![]()
Steve
[added info via Reebs (post 5)]
Just a quick note, regarding corrupted downloads.
If you download these archives (the 'copy of the flash drive' ones) as they are, you'll find that they simply will always be corrupted. This isn't a corrupt download, so download again will not help. Sadly, it seems the author of these files kinda screwed up in a silly way.
rar will expect the files to have certain names. and will fail if they are incorrect, as they are here. I had problems with the italy file, as well as one other (which I cannot remember right now). This was caused by rar decompressing the files in the wrong order, and falling over every time.
The solution is simple. Rename the files, like so:
avic f900_700_500 ver_3.000300(part1).rar --> My Flash Disk.part2.rar
avic f900_700_500 ver_3.000300(part2).rar --> My Flash Disk.part3.rar
avic f900_700_500 ver_3.000300(part3).rar --> My Flash Disk.part1.rar
It sounds crazy, but it worked for me, using the Linux unrar command line interface (I could've used a GUI program as well, but I *really* wanted to make sure it was all okay) I confirmed it all extracted okay. I also tested with the provided par files, all is well after being renamed.
Any chance this could be added to the main post? Doing this seems to make the par files redundant. rar does have CRC checking built in, so unless it complains, you won't be needing the par files.
