Hello all,
After more than three months of change and with the agreement of ille.dy.trying, I offer my modified version of the mod IDT3.0 Seeing me served basis.
The change are as many visually (correction / modification / creation of buttons, icons and other images) at the level of certain options may well be unprecedented and asked me several weeks of development for some ( here I have no training in programming or even scripting in Computer Science)
This is the revision of my mod b. The release of MB-IDT3.0-3 and the revision has been distributed only in France and Europe.
What is new :
- Smart zoom does not suit me (given the closest too far away etc.) so I partly "reprogrammed" I also added two sliders to adjust the angle of view, I also cee the option to disable the camera roundabout.
- For Speedcams, I created a slider "Warn Distance" which lets you choose the maximum distance from which the alerts are triggered (voice and display the alert).
- Change in operating tones:
Added a new mod "Overspeed Limit (Live), beep from the overspeed warning once activated
The two other types of beeps (Overspeed Limit and When Approaching) depend on the slider "Beep Distance"
- The pace of the beeps "When Approaching" varies depending on the distance of approach speedcam
- New option for Overspeed Limit when speeding (integration and personal modification from a Gurjon mod)
- Fix a "mistake" when the pioneer Smart zoom was activated, the display of a Lane Info, a camera movement occurs but never returned to normal. Now after the disbanding of the Lane Info, back view as you will have it set in the menu Smart Zoom.
- The distance Poi search around the cursor has been increased (thank you to Marlyse, a member of my small forum French)
- If no GPS signal when you started to roll, once the signal OK, the card begins to move with the vehicle position, normally no need to click on the button "MAP"
- Fixed a mod "Multiplan" and Changing the mod "Multicalc"
- Modification audio option, "Key" has been changed. Now when this option is Off, the sound of warning speedcam (voice and beeps) and overspeed alerts (beeps) work always.
- Auto down/up Speedcam Alert windows position when the Big Lane Info appear/desappear
- Spécific 2D car by "Martin83" (member of my forum)
- New car position on 3D/2Dheadup for to allow the display of the new position of trip statistics. In Route mode, if it does not appear, the progression navigation and lane info displayed in the same place.
- Creating a quick menu available from the map, it can be closed manually or automatically depending on the setting chosen.
The quick menu includes various options, including the activation/deactivation:
Smart-Zoom
RoundAboutCam (depends on Smar-Zoom)
Mobil Speedcams
Overspeed Limit
Change direct auto/day/night mod
Spécific option for building (This option existed in the data.zip (with the basis of a basic and quick menu without much interest) but was not used. I changed it because it did not keep his distance setting appartition of the buildings, now it's ok)
and Other ....
etc. the list is too long
- Many visual aspects and options have been amended (see attached pictures)
Use:
- Most of the buttons at the top card are dual function (short or long click click)
- In the pages displaying a green arrow, it skips directly to the page of similar function (Multicalc <-> Multiplan, ditto for Cruise Dial).
The red arrow, allows a direct return to the map, while the gray arrow in the top right allows most of the time to return to the previous page.
- Short clic on "Elevation" info for GPS status
- Statistic = Short Trip click on the speedometer
- Trip The Computer = long click on the speedometer
- Menu = short phone calls click on the icon LV
- Direct call to the number in the home (the map is displayed) = Long click
- Operation Display and Hiding num street and trip statistic is the same as before, but now increasingly it is possible to select via the Map Menu, these data are displayed by default.
The pictures that follow are not meant to crtiquer the excellent work of IDT. They are there to show you quickly change between the mod IDT3.0 and my version MB-IDT3.0-3b.
When there are two superimposed images, the first is the mod IDT3.0 and the next mod MB-IDT3.0-3b
Please, read the instructions for intallation available in the archive downloaded.
F500 users must edit the file sys.txt to activate the line "type =" PIONEER749xx "and off the line" type = "PIONEER746xx"
If you wish donate:
MB-IDT3.0-3b_CAFr-MSN translate file for CA-Fr user (Quebec)
MB-IDT3.0-3b_EuroFr-TMC translate file for Fr user
