Do I need a modded copy of ezrider for this? If so where do I get the new version of ezrider?
Many places in this forum, so just search and you will find it. ![]()
Where can I download this mod ? please help me... thanks..
Looks like the file link has been wiped during the forum transition. ![]()
PM Jason, the forum administrator.
hello
You can find him on this forum: http://avicmb.xooit.fr/index.php
Please note that there is a newer version to his mod called mod MB-IDT3.0-4.
Search the forum.
Search the forum.
Actually the thread is here but the content is all missing. i had the same problem with my thread. If the original poster clicks edit on the post the content is all there. But it has to be brought up into edit mode and saved again.
http://avic411.com/index.php?/topic/28136-mod-mb-idt30-4-all-in-one-up-june-27-10-3dcars-add-on/
I want to fix smartzoom but if Misterblues work is the only one that has gotten it working I would like to take a look at it. If you have the downloaded files please let me know.
Alex, I will PM you the link.
Chuck.
Alex, the mail said "The member cannot receive new message ...", so I put it below:
Hey Alex,
As promise, please find below the link to mb's mod v4, in which the smartzoom works wonderfully.
MisterBlue mod from IDT3.0-v4.zip
Thanks for a follow-up.
Cheers!
Chuck.
Hey Alex,
Cheers!
Chuck.
Ugh... I bet they lowered the quota with the new forum software. I will check it out.
Thanks for the link...
Alex
Hello, can any one Upload the lastest Version? I search about 1 hour here ![]()
Try this.
http://www.4shared.com/file/oRmF2k-M/Install_MB-IDT30-4_Rev_c.html
@oval.... THANK YOU!!
No problem ![]()
Dear MisterBleu,
Can you tell me how to get your mod in dutch?
I have copied the dutch lan-file incl. the mod specific therms at the end(see under), now the basic items are in dutch because i renamed the dutch langfile in UK but the mod specific items are still in english.
What must i do to fix this?
;Mod
SPEED="Snelheid"
ALTITUDE="Hoogte"
Building Distance="Afstand Gebouwen"
Start Recording="Start Opnemen"
Track Log Options="Tracklog Opties"
Load route="Laad Route"
close="dichtbij"
CLOSE="Sluiten"
Custom="Voorkeuren"
Custom Settings="Instellings Voorkeuren"
Audible Warning="Geluids Waarschuwing"
Visual Warning="Visuele Waarschuwing"
Spoken Warning="Gesproken waarschuwing"
Spoken Alert Volume="Spraak Waarsch. Volume"
Warning Beeps="Waarschuwingstonen"
Beep Distance="Afst. Waarschuwingstonen"
Over Speed Limit="Snelh. Overschrijdings Limiet"
Over Speed Limit (Direct)="Snelh. Overschrijdings Limiet(Direct)"
Beep Warning Settings="Instell. Waarschuwingstonen"
Navigation Text Color="Tekstkleur Navigatie"
Main Color="Standaardkleur"
Outline Color="Omtrekkleur."
Auto Fading Buttons="Knoppen Automatisch Dimmen"
Fade Percentage="Dim Percentage"
POI Settings="Poi Instellingen"
Map Visual Setting="Visuele Kaart Instellingen"
Custom Camera Alert Settings="Aangepaste Camera Instellingen"
Blocked Roads="Geblokeerde Wegen"
Road Signs="Routebeschrijving"
Sign Boards="Wegbewijzerings Borden"
Lane Info="Rijbaan Begeleiding"
Turn Restriction="Omdraai Beperking"
Elevation Sign="Hoogtemeter"
Speed Limit Sign="Snelheidslimiet Bord"
Select Day(s)="Select. Dagen"
Do you want to reset your current trip?="Wilt u uw huidige reis te resetten?"
Full="Compleet"
CURRENT SPEED="Huidige Snelheid"
MAX SPEED="Max. Snelheid"
AVERAGE SPEED="Gem. Snelheid"
TOTAL DISTANCE="Totale Afstand"
DRIVING TIME="Reistijd"
TOTAL TIME="Totale Reistijd"
Arrival Time="Aankomst Tijd"
GPS time="GPS Tijd"
Speed Limit="Snelh. Limiet"
Navigation Progress="Navigatie Voortgang"
Track logs="Tracklogs"
Delete all="Verwijder Alle"
Export All short ver="Export Alle Korte Versie"
Scenic="Panorama"
Scenic/Panoramic_View="Panorama"
Fast="Snel"
Short="Kort"
Easy="Makkelijk"
Economical="Economisch"
Blue="Blauw"
Red="Rood"
Grey="Grijs"
Saffron="Safraan"
White="Wit"
Black="Zwart"
Green="Groen"
None="Geen"
Please wait ...="Wacht AUB ..."
Cruise Dials="Navigatie Info"
Around address="Rond Adres"
Traffic Flow="Verkeersinformatie"
No Traffic Flow Events="<Geen Verkeersinformatie>"
House Numbers="Huisnummers"
Statistics trip="Reis Statistieken"
Distance AutoZoom Event:="Afstand Autozoom Event :"
Distance View Carpos:="Afstand View Carpositie :"
Tilt Down:="Omlaag Kantelen :"
Tilt Up:="Omhoog Kantelen :"
RoundaboutCam="Rotonde Camera"
Auto Replan Route="Autom. Route Herplannen"
Calculation Algorithm="Berekenings Methode"
Off Route Sensitivity="Buiten-de-route gevoeligheid"
Recalculation Delay="Herbereken vertraging"
Guidance Superiority="Stembegeleidings Prioriteit"
Spoken Alert="Gesproken Waarschuwing"
Guidance Voice="Stembegeleiding"
Master & Beeps="Volume & Toon"
Tolerance:="Tolerantie :"
Warn Distance="Waarsch. Afstand"
Quick Menu Off="Snelmenu Uit"
Auto & Manual="Autom. & Handmatig"
Manual="Handmatig"
Tolerance Type="Tolerantie Type"
Alert="Waarschuwing"
Sound 1="Geluid 1"
Sound 2="Geluid 2"
Sound 3="Geluid 3"
Sound 4="Geluid 4"
Sound 5="Geluid 5"
Sound 6="Geluid 6"
Sound 7="Geluid 7"
Sound 8="Geluid 8"
1 beep="1 Toon"
5 beeps="5 Tonen"
Always="Continu"
OverSpeed Limit Settings="Snelh. Overschrijdings Instell."
Restart="Herstarten"
NOTE:\n Program will be restarted, Are you sure ?="\n programma wordt opnieuw gestart, Weet U het zeker ?"
I have fixed the language issue because the 2 first Items are for the Speed button and the elevation image but are no text items but both images, so after deleting the first 2 items (see above reply)from the ;Mod section of the language-file everything went wel.
The only question left is how do i get the Speed and Elevation sign in Dutch and is it difficult to add NL to the country selection?
Regards,
Navigarie.
Can you re-host the files please
please someone can give a availble link to this mod ? thx
