@ chuck88,
Tonight I used my car. I did a course with a navigation with route , I went to the "Route Menu" and then I went into the mode "Multiplan" and I had no problem repeating voice ?! I did the same thing by showing how "Multicalc" worked well too.
The problem you reported me wonder because I made 20 beta, tested by beta testers of my forum Euro/Fr and tested by myself. When I put online version MB-IDT3.0-3 one has had this problem it was corrected in my small revision "a" and as nothing is ever perfect in the revision "b "I fixed the problem with the "Key" from "Sound Menu" that disabled, and also divided the sound of all speedcam alerts (beeps and voices) and also cut the beeps of the "Warn When speeding" .
I waited for my mod is sufficiently "clean" before nominating your continent (I tested my revision "b" for almost a month), so your problem surprises me, I do ' did not and none of the users of my forum does bring me a problem like that ?!
Have you cleaned your folder "save"? the problem is still present?
for this question :
Can somebody tell me what is "Zoom in after find" under Smart Zoom menu?
When this option is enabled, there is a distant view of the card at the time of validation of a destination on the map and then slowly returns to the values you have set (tilt and distance view)
"Restore Smart Zoom" after 10 seconds?
This option returns the values you selected in the Smart Zoom Options after zooming (in or out) on map with the stick or touch control of AVIC.
