mod MB-IDT3.0-4 All-In-One UP June 27 '10 - 3DCars Add-On !
By misterblue · Jun 07, 2010in Completed Mods/Themes💬 50 posts👁️ 16,535 views
Page 1 of 2
Posted Jun 07, 2010 · 13:14 UTC#1
hello,
I present the new version of this mod version 4
New option :
- All In One MSN, TMC or no MSN/TMC
- Map Changer (I slightly modified and and corrected the presentation) select and validate Naveteq Map only if have at least on map Naveteq in map_nt folder (Content\map-nt)
- Male or Female select Speedcam Voice (created myself, US/UK male-female, FR female is synthétique and FR male is my)
- Correction of various minor bug in version 3.03b
- Modification of the slider "Master" volume of Quick menu (best setting)
- Changing the Multiplan option : deselection route is problematic and according to those who are viewing the colors do not always match. I deleted the route displayed deselection and the recalculation was unnecessary.
- Fixed loading saved itinerary
- Changes in the functioning of the buttons "add Start, add Dest, Continu and Via" of Cursor Menu
-> Simple click = change/create a route, staying in the Cursor Menu.
-> Long click on "add Dest, add Start and Continu" = direct validation of change and direct access to the navigation map
- Correction/modification for BlockRoad option.
-> Simple click (symbol +) = add block road
-> Simple click (symbol - ) = edit block road selected
-> Long click (symbol -) = delete block road selected
EDIT :
- Correction of my option "3D" Landmark in my quick menu. Now this option also disables the display of the buildings (this is my own option, it has nothing to do with the original option of little quick menu iGo origine)
Why All In One :
I decided to propose a single version of my data.zip. It is compatible with US/UK/FR/Can-FR for Map Display specific info (speed, Elevation, quick menu, Cursor Menu).
Speedcam voice type also depends on this option (US/UK or FR/CA/Can-FR)
It's possible to enlarge choice. This takes time, I can add Spain and Dutch Country. Consider making a donation ;-) and I will complete the mod.
Now you have the choice between a Single or Full Display buttons on map.
-> Full = MSN or TMC (depending of Avic Country)
-> Single = No MSN or No TMC
all details of previous version include here
Installation_MB-IDT3.0-4 READ AT FIRST !!!
Self-extraction archives
pack Install_MB-IDT3.0-4_REV_a (contains my schemes v3) updated jun 10 '10 -old version-
pack Install_MB-IDT3.0-4_Rev_b (contains my schemes V3 and new sys.txt but not install it, it's unnecessary if it init add-on MB-3DCars) updated jun 22 '10 corrected minor error (correct speedLimit sign for UK, US and Quebec user...) -old version-
pack Install_MB-IDT3.0-4_Rev_c (contains my schemes V4 & 4-2) update 06/27/10 details a little lower
My mod does not contain more speedcam voice. Download the ones you need. Several package of voice can be installed
pack Install_MB-IDT3.0-4_Audio_SpeedCamVoices_FR-CanFR (if you need it)
pack Install_MB-IDT3.0-4_Audio_SpeedCamVoices_US-UK (if you need it)
pack Install_MB_Lang_FR
pack Install_MB_Lang_Can-FR
pack Install_MB_Lang_FR updated jun 22 '10 (up for add-on MB-3DCars)
pack Install_MB_Lang_Can-FR updated jun 22 '10 (up for add-on MB-3DCars)
Standard-extraction archives
pack Install_MB-IDT3.0-4b (contains my schemes v3) updated jun 22 '10 corrected minor error (correct speedLimit sign for UK, US and Quebec user...) -old version-
UPDATE jun 26 '10
MB-3DCars Add-on is available for my mod, is here
If you want me to continue modification :
Donate
Posted Jun 07, 2010 · 20:33 UTC#2
Do not be shy! this mod works really well ;-)
It is not simply a version IDT3.0 skin with a few more options. Many original options have been changed, others of the original iGo were added and others are completely personal, such as SpeedCam alert voice and beeps that are not cut so that the "Keys" sound option is disabled.
Posted Jun 09, 2010 · 15:23 UTC#3
This looks great. I'm currently using an old version of IDT's mod with the 3.0 upgrade on my F90BT, but some things have gotten wonky on my unit. IPOD sometimes doesn't get recognized, have to reconnect it, and the unit thinks my car is about 50-100ft behind where it actually is!
I'm going to combine this mod with the 3.1 firmware upgrade here:
viewtopic.php?f=34&t=32351&start=150
Hopefully will get to try this something early next week and will report my results.
Posted Jun 10, 2010 · 13:43 UTC#4
UPDATE of 10/06/10 to 3:40 p.m.
MB-IDT3.0-4a
- Fix : when a saved routei s loaded or when a route is in progress, once in the target menu, the menu offers a global view of the map. Previously and since version 3.0-3x the view was zoomed and centered on the position of the vehicle. Following remarks on this, I shall give up the global views ;-)
- Fixed display and management of the MSN icon following the return of Labgate (thank you to him, canadian member of my forum). Now displaying icons on map MSN or TMC is that depending on the model of your AVIC. I made this choice to prevent you from crashing your AVIC happens, for example, when entering the functions MSN with AVIC Euro.
If AVIC Euro = only the TMC icon will be displayed (as the Simple Mode or Full), and even if you choose a "Country" U.S., CA or Quebec.
If your AVIC is other than Euro = only the MSN icon will be displayed (as the Simple Mode or Full), and even if you choose a "Country" U.S. or UK.
If you already installed version 3.0-4, you do not need to install all the files of the pack, but only data.zip and sys.txt.
For others, refer to page up and read Installation_MB-IDT3.0-4
Pack Install_MB-IDT3.0-4_REV_a
ADD-ON online comming soon (being finalized) and will move independently from the rest, IDT3.0-MB-4x is ready to run;). However it is better to be already in version 3.0-4a
Posted Jun 15, 2010 · 18:29 UTC#5
Hi misterblue,
You removed all *.ogg in the audio folder (data.zip drops from 11 MB to 7 MB when comparing to your last version). Is this because in you mod you use only synthetized voices for guidance?
Thanks.
Posted Jun 17, 2010 · 16:24 UTC#6
See first post
install Voice Speedcam pack you want (read "Installation_MB-IDT3.0-4" for more details)
Posted Jun 22, 2010 · 16:48 UTC#8
UPDATE jun 22 '10
standard archives of my pack and MB-IDT3.0-4 revision b are availables in first post :wink:
Posted Jun 25, 2010 · 15:52 UTC#9
An update "revision C" will soon be online. It will correct the problem display buttons for the UK/US/CA user (thank you Ovalball) Fr and Quebec user ok.
Posted Jun 27, 2010 · 19:31 UTC#10
UPDATE Jun 27 '10, MB-IDT3.0-4c
This update corrects the issue of displaying the buttons on the left (arrival, departure, ect ..) in "Cursor Menu" that were not properly (symbol + or - or gray) for users UK/US/Canada (Fr and Quebec ok in previous version).
Thank you for allowing me to ovalball warned of this problem.
This is now fixed!
Due to recently moving, I decided to change my previous schemes to better differentiate a road type orange with lighter orange from the orange color corresponding to the current route.
I also decided to make a variant with current route is based on a green (other than that indicating the route type "Short" in "Multiplan" mode)
Screen later :wink:
download in first topic
new version of MB-3DCars Add-on is available compatible with my mod, is here (clic on link :wink: )
EDIT : screen of my scheme
Based on my personnal definition of color applied on 3D and 2D mode
version 4 = route color orange
version 4-2 = route color green
For install, copy directly the Content folder of archive in My Flash Disk\APL2\iGo\ of your avic.
Auto-extractible archive
pack Install_MB-Schemes-4&4-2
Standard archive
Posted Jun 27, 2010 · 21:03 UTC#11
This is now fixed!
Screen later :wink:
dowload in first topic
Thank you mister blue for updating your data.
Posted Jun 27, 2010 · 21:49 UTC#12
This is ok, do not thank me :mrgreen:
I wanted this version of my mod is unique for several country :wink:
Posted Jul 06, 2010 · 17:15 UTC#13
love your mod, having a slight rebooting problem when my ipod touch is hooked up, is anyone else here having the same issue ? Thanks
Posted Jul 07, 2010 · 09:43 UTC#14
Here, as on my forum, users of this mod I have not reported a problem reboot using their iPods ou iPods Touch.
You are the first.
This problem occurs only with use of my mod or other mod as well?
Normally this is managed by the applications of APL folder.
Posted Jul 08, 2010 · 14:19 UTC#15
Links are dead...
Posted Jul 09, 2010 · 14:50 UTC#16
Whenever i use MB-IDT3.0-4 mod my moto droid is not recognize and i have no VR.
Whenever i use ABB'S mod my moto droid is recognize but i have no VR.
Whenever i use Diaftia's mod everything works, I find that strange, is there a explanation for this?
Posted Jul 09, 2010 · 15:13 UTC#17
The VR option is not an important factor in any mod as it is clearly unreliable and NEVER dials the number that you call or plays the song you say. The unreliability was even recognized by Pioneer as a lot of reviews have targeted this. I have never even realized that it was not fuctional with my mod nor have I ever really cared. If you can get it to work with your voice, then you are probably one of the few in the WORLD!!
Posted Jul 09, 2010 · 16:27 UTC#18
When using Diaftia's mod my VR works good with my phone and ipod, im a southern boy I definitely have to speak proper when using VR search.
Posted Jul 10, 2010 · 19:57 UTC#19
Sorry, I'm not able to help you, this feature is not available for Europe (where I live). My mod is partly based on the mod IDT3.0 skin1 I changed a lot of features and options. Besides, he does not seem that this function is directly related to the navigation interface.
Posted Jul 16, 2010 · 04:07 UTC#20
MB, i changed last line of code in 3DCars/ui/3DCars_800_480.ui so that it reads "Cancel" instead of "Annuler"
Thought you might want to also..
Posted Jul 16, 2010 · 08:12 UTC#21
ok, thank you for the info. Reply in the main subject.
If you have further comments or questions regarding the operation of this add-on, remember to ask about the main subject
Posted Jul 28, 2010 · 15:32 UTC#22
is it possible for me to change some of the icons? Some are currently in French and I would like to change them into english...are these all within data.zip?
SOme of the icons that i have seen so far that i would like to change are:
vitesse (on main map screen)
arrivee
etape
continuer
thnx
Posted Jul 28, 2010 · 15:40 UTC#23
arrivee
etape
continuer
thnx
Open data.zip and search through *.UI files under \ui_pioneer\800x480\ui and \ui_pioneer\common\ui, with the french words as keywords.
Posted Jul 28, 2010 · 16:00 UTC#24
arrivee
etape
continuer
thnx
Hi,
thanks...i just tried that, but could not find anything which matched what i was looking for. I even renamed all the .ui files to .txt then Windows 7 could search inside each file the words...but still couldn't find anything.
I'm assuming that these are actual bmp files, which means that i would need to edit them in photoshop or something?????
thnx
Posted Jul 28, 2010 · 18:08 UTC#25
It is possible that the texts are embedded in the icons.
Instead of doing the tedious changes yourself, if you make the comment to Misterblue, I think that he will certainly fix that in the upcoming update.
Page 1 of 2
