mod MB-IDT3.0-4 All-In-One UP June 27 '10 - 3DCars Add-On !
By misterblue · Jun 07, 2010in Completed Mods/Themes💬 50 posts👁️ 16,535 views
Page 2 of 2
Posted Jul 28, 2010 · 18:24 UTC#26
Dear Misterblue......
:D
Is it possible to adjust some of the existing icons into english?
So far I have come across the following:
vitesse (on main map screen)
arrivee
etape
continuer
many thnx.
Posted Jul 28, 2010 · 21:07 UTC#27
Post a picture of your problem, please.
This mod contain an option for choose country (read first post, explain "All In One" and see your Map Setting Option), there is nothing to change in the data.zip.
Posted Jul 29, 2010 · 05:34 UTC#28
all fixed!!
Many thanks for the info.....it would help if i read the instructions in full
:oops:
Posted Jul 29, 2010 · 07:50 UTC#29
no problems. Often users are very eager to use a mod and do not read all the details of the first subject :wink:
Posted Jul 29, 2010 · 14:55 UTC#30
Misterblue,
Do you have any intention to improve the smartzoom behavior of the mod? Can you point me to the codes and/or files that is responsible for the smartzoom processing during navigation maneuvers (turns)?
I wish that I could improve the smartzoom behavior within Abb's Chrome mod V3.
Thanks.
Posted Jul 29, 2010 · 15:16 UTC#31
The improvement SmartZoom took me a really long time. It would take too long to detail all the changes I make to make this option acceptable to use. I never liked to use this option (Pioneer mod and other mod), but since I changed I use it all the time (I say this in all sincerity, not because it is me who have improved this option).
ABB is expected to arrive to copy my changes, I'm pleased that I will copy my changes and to be incorporated in his mod :wink:
Posted Jul 29, 2010 · 15:48 UTC#32
Hi Misterblue, excellent job, very detailed as i like!!
I was wondering how to edit some bmp with special feautres like: the time on map, altitude on map, and speed on map, it's translucent, and when I convert it with iPAQ 31x to RGB or aRGB or PNG to edit with PS, lost its features.
How I can edit these files?
I'm at work right now, but later I'll comment work I'm doing.
Files:
Thanx!!
PS: I made myself a few minutes, I'm changing some things, some of them just to suit my taste, and others could serve many others.
I live in Argentina, and here we have the same signs and units that in the UK, so I'm changing the files to make it compatible with South America, also Spain (all latin languages), overwriting the UK files.
This includes:
- a new Spanish Language file, including all your terms added, and improved the originals.
- Speed Cam Audio in Spanish, male and female with loquendo voices (in process)
- Icons in Spanish (Speed, Altitude) trying!
- I made a new sheme, adapted here, where the mountains are shown in brown and not white like "snow".
- I edit mapchanger_800_480 to switch between 2 versions of teleatlas maps (older and newer), because in my region we have only teleatlas maps, and for some places newer maps are worst than older, so I decide to preserve the 2 version putting older version in map-nt and newer in map as default.
And other things about my "almost" apple red theme downloaded here about 1 year ago, I don't think anyone be interested.
So if you want to add this to your mod, and you're a meticulous man to do so, we are all grateful.
You could add a new "Country" (or region be better) as "LATIN AMERICA" in addition to US, UK, FRA, CAN, Quebec. This I couldn't, because I don't know about script programming.
What do you think?
I'll help you as much as I can.
Posted Jul 29, 2010 · 16:27 UTC#33
I do not understand why you wanted to change these pictures?
Files:
I will soon propose a new version of my mod. If you want to help to integrate the Spanish language, you can send me by MP making fun of speedcam voices (male female, all sentences) and your language file for GPS menu.
I'll add them to my next version of mod and the menu will choose "Spanish" (I'll make the necessary buttons and icons).
Posted Jul 29, 2010 · 16:48 UTC#34
"misterblue"I do not understand why you wanted to change these pictures?.....
because, these files are in english or french, according to the language selection. mine should say VELOCIDAD for speed, and ALTITUD for elevation
Posted Jul 29, 2010 · 17:00 UTC#35
ok, do not bother with it, I will myself these pictures in spanish :wink: , no problem and thank's for your help to add that language in my mod.
Posted Jul 29, 2010 · 17:01 UTC#36
I leave you a few questions to think and answer later:
- What happened with IDT's fuel calc? you don't want any more? I liked
- What about turn off the screen (totally, no black screen!) by pressing the off button on the map, instead of displaying the time and date. And for the current state, how I can change the font color to red, just to match with the interior of my car
Posted Jul 29, 2010 · 17:04 UTC#37
no no no, thanx to you!! merci monsieur!
Posted Jul 29, 2010 · 17:45 UTC#38
Menu->Settings->System Settings->SCREEN OFF.
Posted Jul 29, 2010 · 20:18 UTC#39
Ok, so...we all know that, but I'm a little lazy and I want to turn off the screen from the map screen.
I asked IDT, and said it may be possible, but at that moment he didn't know how.
someone has figured it out?
Posted Jul 29, 2010 · 20:58 UTC#40
In the next version of this mod, there will be an add-on FuelCalc different, Bandit972, a member of my forum worked hard on this add-on and I'm trying to adapt my mod to integrate it as properly.
this is ok in this mod :wink:
Go to Navigation Setting (icon "map" on the map) and clic on "Custom" the colors of text on map parameter here is the bottom of page.
Posted Jul 29, 2010 · 22:22 UTC#41
Great!! My 3th question was about the off screen with time and date with ds-digi.ttf font. Actually it's white/light gray color...but if you add a really power off screen in your next mod (like said in the 2nd answer) is much better!!
So, working on Spanish Lang and speed cam, probably for weekend i'll send you.
Bye!
Posted Jul 30, 2010 · 08:21 UTC#42
This function can not be a true "Power Off", I found interesting to be able to view the time, date and version of the mod. The colors I used make the display very soft.
I'm waiting for your files, it is ok.
Posted Aug 02, 2010 · 14:26 UTC#43
MB,
Your mod works fantastically in the area of Smartzoom, just what is supposed to be during navigation, like the IDT 3 and ABB's Chrome V2.75. It is a shame that this little wonder doesn't show anymore in Dafitia's or ABB's V3.0.
Some said that they trade the Smartzoom functionality for the sky, but I can hardly accept that, as this truly defeat the purpose of navigation :twisted: .
Thanks.
Posted Aug 02, 2010 · 21:25 UTC#44
I do not know if I understood everything, but the SmartZoom is not only useful to see the clouds. This mode is effective assistance which does not lose its settings, zoom and tilt (configurable in my mod since IDT3.0-MB-3x), it also allows for a more distant view with a different tilt to better see some event on the map (intersection. ..), this function was buggy home (iGo for Pioneer) and I corrected to work properly.
Posted Aug 14, 2010 · 09:27 UTC#45
Could it be selected is Spanish lang?
Does it work on F500?
Javivi
Posted Aug 15, 2010 · 16:43 UTC#46
Dear Misterblue,
I am a absolut Newbie and mybe me question are stubit but after 1 hour searching here I count not find the answer :(
I am using a F9110 (same as F910) and I am happy with the Design of the GUI... Just the Navigation lucks for me a bit overage >My 99€ Navigon has more Features...
Now I saw your mod and I really like it. I read your installation tutorial but is that everithing I have to do? I think I need other Maps as well!? If there are other things to do maybe you could give me a hint :roll:
Btw: I am using the F9110 in a VW Golf with steering whell control. But there are more (today unused) buttons on my steering wheel. Is there a chance to add/modify functions? E.g. Phone functions like open phonebook?
P.S: Is there a german version? I just saw already that question but maybe someone did the translation already!?
Thanks in advance!!!
:roll:
Posted Aug 15, 2010 · 17:50 UTC#47
is anyone else having a problem with the system not saving your favorites and history of your routes??? im having to find myself redoing the setting everytime i start up the car, and putting in my home addy again...i have a F900BT thanks
Posted Aug 15, 2010 · 17:51 UTC#48
:roll:
The only language that I can switch to here on my US version is 'English, French, Spanish'. if German would be available, then I would have made a german version for my mod because I speak german, and I would have loved to have my Avic in German. However, it is kinda pointless to have my Nav section in German and the main section being in english :(
Posted Aug 18, 2010 · 18:53 UTC#49
Hello MSB,
I have installed on my F500, UK version, but i got this error:
FFUIERROR: Parse error [>/layer> expected]
I´m am I doing wrongly?
Javivi
Posted Aug 20, 2010 · 10:24 UTC#50
Hi,
It´s a big mod. When is it a spanish version?
Bye, bye
Page 2 of 2
