Rearview Cam Question
By bigolyt · Mar 22, 2010in General💬 42 posts👁️ 8,368 views
Page 1 of 2
Posted Mar 22, 2010 · 00:49 UTC#1
Im looking to get one, got the unit already installed... how easy is the install? Is it literally plugging the RCA cable into the Brown connection? Or do I need to solder/splice anything into the wire harness? Also, whats a good one for a GMC truck?
Posted Mar 22, 2010 · 01:04 UTC#2
yes just tap into the reverse light wire witch will tell the unit that your backing up and turn ur cam on.
and also ground the black wire.
Posted Mar 22, 2010 · 01:17 UTC#3
Tap into the wire harness from a cable from the backup cam? I think I hooked a cable up to the wire harness from the GMOS-04 harness I have. I do know when I put my truck in reverse it would turn on the black screen (turned that off since I dont have a cam) So would I just need to ground the black wire and hook up the RCA?
Posted Mar 22, 2010 · 03:16 UTC#4
yep thats what i did and i was good to go, tapping into the reverse light wire gives the cam its power.
Posted Mar 22, 2010 · 11:17 UTC#5
If you want to be able to view the camera while driving do not install per the suggestions above. The advice above is the half assed approach most installers take to cut a corner but is not the proper way to wire a reverse camera. If you want full capabilities, you need to wire the power wire of the cam to the switched 12 volt +, the ground wire to any ground, and the reverse wire from the head unit to the reverse circuit on the car, and the RCA video cable from the cam into the rcam input on the rear of the unit. This will give you reverse cam and rear view while you are driving.
Posted Mar 22, 2010 · 14:12 UTC#6
Totally agree.
Posted Mar 22, 2010 · 14:55 UTC#7
IT`S NOT HALF ASSED, I WAS JUST GIVING HIM ADVISE ON USING THE CAM JUST FOR BACKING UP. NOT USING IT WHILE GOING FORWARD. YOU IDIOT
Posted Mar 22, 2010 · 15:31 UTC#8
Come at me again like that ass hole and see if I don't ban your stupid ass from this forum!
Posted Mar 22, 2010 · 16:06 UTC#9
HAHA....
On another note... thanks for the advice VBLUE42. Sounds like it will be more of a hassel to do since I already installed the unit. I'll have to see if the rear view cam is that important to pull the unit out again.
Posted Mar 22, 2010 · 19:43 UTC#10
Has anyone ever found a site where someone tested all these rear view cameras? Everyone seems to look for quality but it appears the only variable is price. Sales folk will steer you to the more expensive units but that does not always mean better image. Unless someone had them all side by side to compare it would be hard to comment. Most people install one and feel the picture is OK and there is not much difference from one to the other. Is there a difference between the $300 Sanyo that has birds eye view and the cheap $99 Boyo camera?
Posted Mar 22, 2010 · 20:48 UTC#11
I had a Boyo VTL-300 license plate frame camera (Black, not chrome) on my older 2004 Ford Expedition, and I was extremely pleased with the images on my old AVIC-N3, even at nighttime. Now on my 08 Expedition, I had another VTL-300 installed with my X910BT, and Im still extremely pleased with the clarity of the picture in both daytime and nighttime. I think I paid $140 for that camera. No need for $250 for the Pioneer backup cam.
Posted Mar 22, 2010 · 20:54 UTC#12
BOYO's are hands down the best cameras for the price that I believe can be had.
Posted Mar 26, 2010 · 22:28 UTC#13
MOD EDIT... Banned do to vulgarity!!!
Posted Mar 27, 2010 · 00:07 UTC#14
GO FUCK YOUR MOMMA!!!
Well we wont be seeing him anymore.
Posted Mar 27, 2010 · 00:29 UTC#15
No big loss, I guess... :)
Posted Mar 27, 2010 · 00:40 UTC#16
Yea you would think a person with that post count would be smarter then to send me the reply that I had to delete prior to banning him. O well, maybe he didn't believe me. Yea no loss though.
Posted Mar 27, 2010 · 01:26 UTC#17
how do i wire the d 3 so its on all the time so i can see the rear view when im going forward?
Posted Mar 27, 2010 · 02:03 UTC#18
Sweet :-D
Posted Mar 27, 2010 · 02:38 UTC#19
Yea right! Joined today with one post asking the same question as the ass clown I just banned. This time maybe you want to watch your step.
Posted Mar 27, 2010 · 12:28 UTC#20
Rearview Cam Question Continued.
Is the camera format NTSC or PAL ?
I am guessing they wouldn't bother changing the Vid format for UK / Aust to PAL for a self contained unit.
Couldnt find any mention of it in the Manual. (I have an Aussie F900BT)
Cheers
Gertsy
Posted Mar 27, 2010 · 12:33 UTC#21
Strike that.. I just checked the Pioneer camera spec.s and its NTSC..
Hmm lots of cheapy License Plate NTSC reverse cameras on ePay.
Might have to give one a go.
Gertsy
Posted Mar 27, 2010 · 15:25 UTC#22
Stay away from the CMOS cams if you want a good picture.
Posted Mar 27, 2010 · 16:28 UTC#23
I kinda feel responsible for all this hahaha...
On a serious note...
The backup cams come with an RCA and a black/red cable. Im assuming you need to splice the red into one of the cables on the wire harness? Probably the 12v red one?
Posted Mar 27, 2010 · 17:36 UTC#24
i just wired my back up cam from being just coming on when i back up to going forward and have the cam on,
i taped into the same 12 volt wire from my bt box. :D
Posted Mar 27, 2010 · 17:49 UTC#25
BT box?
Page 1 of 2
