x920bt initial thoughts after a few hours
By cranbers · Mar 26, 2010in General💬 44 posts👁️ 8,580 views
Page 2 of 2
Posted Mar 31, 2010 · 22:31 UTC#26
I seriously doubt therwill be that huge of an upgrade via software my guess is a new version will be put out so they can make the extra cash and not have to deal with fouled upgrades. Has there ever been an update for any of the z series like the x or f? But hey I could be wrong but I wouldn't hold my breath.
Posted Mar 31, 2010 · 22:42 UTC#27
There were a couple of maintenance updates for the previous Z series to address BT echo and hard drive freezing issues in extreme weather but that was about it. The 120 to 110 update will likely be included with the first map upgrade for the 110.
Posted Apr 02, 2010 · 19:27 UTC#28
has anyone that has used the x920bt also used the z110? I'm curious if the hardware in the z110 is faster and if so by how much. If the x920bt is sluggish compared to the z110 then I'll buy the z110 and upgrade software later, if not I might just go with the x920bt. Any opinions are welcome.
Posted Apr 02, 2010 · 20:41 UTC#29
Well I never seen a z110bt, but I can't imagine the speed is any different. That is, it can't get any faster in my opinion. Touch panel, maps etc are all as quick as you hit the button. That includes poi's, searching. The only thing that does take a few seconds is when your calculating a route. Boot up time is seconds, 15 is what I counted on a timer until interaction screen appears.
It's a great unit. I am really happy, even if the pandora link app or other app isnt out yet.
Posted Apr 02, 2010 · 20:44 UTC#30
There should be no difference between the two in reference to performance. However with the 110 upgraded to the 120 you will have the superior unit. Also the 110 can be had for less then the 920 is going for right now.
Posted Apr 02, 2010 · 22:45 UTC#31
Hey there,
Here is a new video demo which contains a live start up sequence near the end of the video. Seems to be fairly fast. You just have to get past the people doing the video as it gets pretty annoying.
Posted Apr 30, 2010 · 12:35 UTC#32
now that you've had a month or so with this unit, any other thoughts?
Posted Apr 30, 2010 · 21:40 UTC#33
Can anyone tell me how deep the 920bt is? I am trying to mount it in a Nissan Titan that has 6.5 inches. Pioneer's site says the 920 is 6.5 but Crutchfields site says it won't fit, that it's 6.8.
Posted Apr 30, 2010 · 21:48 UTC#34
It will fit. I just installed a 110 in that same vehicle.
Posted Apr 30, 2010 · 21:58 UTC#35
Awesome. Thank you very much! I'm using the Metra DD kit, does it stick out at all? Was it a super-tight fit or more or less normal?
Would you be willing to share any particular "gotchas" with the Titan? I've installed systems before, but not GPS. I'm concerned trying to find the speed-sensor wire and the parking brake wire - was planning on using vampire clips for those. Also did you just ground it to the steel bar that runs behind the dash? I was thinking of clamping it on there.
Thanks again! I'll be an AVIC owner soon enough now.
Posted Apr 30, 2010 · 22:05 UTC#36
It will be tight. In fact, the air duct pipe at the back of the dash caused the back of the unit to rest against it causing the unit to set at a slight angle. We had to Dremel the dash face edges because the angle of the unit was resting against the back of the dash face causing it to stick out slightly out of line with the rest of the dash. Five minutes with the Dremel solved that problem however.
Posted Apr 30, 2010 · 22:09 UTC#37
Crap. Well, that's why I have a Dremel. I think the 920bt might even be a little deeper according to Crutchfield so this should be interesting.
How'd you ground it, and connect the speed/e-brake wires?
Posted Apr 30, 2010 · 22:25 UTC#38
Used the ground wire on the harness and performed the bypass as instructed on this site.
Posted Apr 30, 2010 · 22:27 UTC#39
Huh, I had read that the Titan harness didn't have a ground, I though I was going to have to ground it separately.
So you skipped the speed sensor then? Is it not needed.
Posted Apr 30, 2010 · 22:35 UTC#40
We did not Connect the VSS.
Posted Apr 30, 2010 · 23:25 UTC#41
Ok. I may hook mine up anyway unless it interferes with the bypass. From what I understand it's mainly for driving in long tunnels and such where you lose the lock on your GPS, but supposedly it also gives you a more accurate position even with a lock.
I guess I'm just going to go ahead and install it and see what happens. From what you described it sounds like I will need to dremel a few millimeters off the bottom inside lip of the Metra dash kit so it sits flush, right?
Posted Apr 30, 2010 · 23:59 UTC#42
Yep.
Posted May 01, 2010 · 12:45 UTC#43
The unti is great I love it. The VSS also has a lot to do with the ecomdrive feature I assume. Shouldn't effect the bypass however.
Favorite feature by far is the new way u go through lists iPhone scroll style. Imsure pandora will top it whenever that becomes available.
The f series doesn't compare, the new features of this unit along with the bootup time more then makes up for the molding. Even that isn't really necessary thanks to the shortcut icons u can assign both in the nave screen and via the menu button.
Overall excellent decision I bought it and an excellent rtm product. I bet they have been working on this thing since the f series in 2008 or even before given the polish. This is a first for me and it's hard to imagine what could improve the next model other then nave graphics.
I reallyo Ike the fm radio information that is a first vie seen it. Makes fm more worth it. Seeing the radio station along with the song and artist is very cool. Makes xm joust look silly along with the monthly fee. Pandora link more then makes up for the loss there
I still really like the source selection layout now. It's a great improvement along with the iPod information screen
I used two have xm but i got rid of it when i got this unit. So i didn't get a chance to see how that Works.
Great stuff. Good job pioneer. Woo!
Posted Jun 12, 2010 · 18:51 UTC#44
Oh really, it shows song information (title, artist) in regular FM stations? I wonder why they wouldn't mention that in the product description.
Page 2 of 2
